Renaming files by date and model Topic is solved
m0atz
#1 Post by m0atz »
Ok so I got a whole load of photos back from photorec - as usual it was the best tool for the job.
Now, I've used the following code to rename by any available timestamp in the exif information:
for i in ./*.jpg; do cp $i ../final/`exiv2 -p s $i | grep timestamp | awk '{ print $4 "-" $5 }'`.jpg; done
and then I've also tried to prepend that with the model number:
for i in *.jpg; do mv $i `exiv2 -p s $i | grep model | awk '{ print $4 }'`-$i; done
Doing this will prepend the file with say "iphone-2014...jpg" but can it be clearer on the model, i.e. some are iPhone 4 and some are iPhone 5 - how can I get it to give the full model description.
Also - is there a way to Append the info as opposed to prepend it and also skip over any errors?
Thanks
Re: Renaming files by date and model
To append the model, try
for i in *.jpg; do mv $i $i-`exiv2 -p s $i | grep model | awk '{ print $4 }'`; done
m0atz
#3 Post by m0atz »
Awesome thank you Mr. Grenier.
