Hi there - I am new to this and not very up on the technical side, although I have done a considerable amount of reading and learning over the past few days!
I keep all my photos and videos on a 2TB internal disk which suddenly became unreadable by Windows (8).
Using TestDisk for the first time, I found that the boot sector was bad and I successfully used the back up boot data to make the primary partition readable. There is only one partition on the drive, occupying the whole (2TB) disk. I then copied all the (191 932) data files to a portable HDD with no errors.
Even though TestDisk is able to read all the information on the Primary partition, Windows cannot access this partition and sees the disk as a RAW volume which needs formatting. I sense there must be some way of modifying the MBR or MFT (not quite sure what the difference is!) so that Windows can then see all the data which is still on the partition and I can continue using the disk without having to format it. Chkdsk gets as far as 53% and then gives an error saying there is not enough room on the disk to write to it (or something like that!).
The initial TestDisk Log is shown below, which includes me restoring the boot data from the backup. Any help on getting the disk back to good health would be much appreciated!:
Disk /dev/sdd - 2000 GB / 1863 GiB - WDC WD20EARS-00MVWB0
Analyse Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63
Invalid NTFS or EXFAT boot
 1 P HPFS - NTFS              0  32 33 243201  13 12 3907022848
file_pread(7,11,buffer,3907027070(243201/47/45)) lseek err Invalid argument
file_pread(7,1,buffer,3907027070(243201/47/45)) lseek err Invalid argument
file_pread(7,2,buffer,3907028992(243201/78/14)) lseek err Invalid argument
file_pread(7,1,buffer,3907028991(243201/78/13)) lseek err Invalid argument
file_pread(7,13,buffer,3907028994(243201/78/16)) lseek err Invalid argument
file_pread(7,3,buffer,3907029007(243201/78/29)) lseek err Invalid argument
file_pread(7,3,buffer,3907029054(243201/79/13)) lseek err Invalid argument
file_pread(7,8,buffer,3907029070(243201/79/29)) lseek err Invalid argument
file_pread(7,11,buffer,3907029117(243201/80/13)) lseek err Invalid argument
file_pread(7,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
interface_load
Sun Aug  3 20:37:23 2014
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-07-30T07:20:09
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000397852160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=999501594624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000397852160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=999501594624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499737690112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=499970473984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=499971522560
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000395698176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=999500546048
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320AS, S/N:9QM5H4NG, FW:SD1A
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320AS, S/N:9QM4P67Y, FW:SD1A
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320AS, S/N:9QM4P9S5, FW:SD1A
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARS-00MVWB0, S/N:WD-WMAZA1367716, FW:51.0AB51
Disk /dev/sdf - 999 GB / 930 GiB - CHS 121515 255 63, sector size=512 - WD My Book 1110, S/N:WCAV5D450766, FW:2018
Disk /dev/sdg - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512 - WD My Passport 0820, S/N:WXG1A1461717, FW:1007
ntfs_boot_sector
NTFS at 0/32/33
filesystem size           16780535352598200449 3907022848
sectors_per_cluster       32 8
mft_lcn                   0 786432
mftmirr_lcn               0 244188927
clusters_per_mft_record   0 -10
clusters_per_index_record -10 1
Status: Bad
Status: OK
Sectors are not identical.
copy backup boot sector over boot sector
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size           3907022848
sectors_per_cluster       8
mftmirr_lcn               244188927
clusters_per_mft_record   -10
Status: OK
Status: OK
Sectors are identical.
						All data recovered with TestDisk but NTFS HDD unreadable
Re: All data recovered with TestDisk but NTFS HDD unreadable
Deep Search reveals the following errors:
NTFS at 0/32/33
NTFS at 0/32/33
file_pread(7,2,buffer,3907027058(243201/47/33)) lseek err Invalid argument
file_pread(7,1,buffer,3907027058(243201/47/33)) lseek err Invalid argument
file_pread(7,8,buffer,3907027072(243201/47/47)) lseek err Invalid argument
file_pread(7,8,buffer,3907027200(243201/49/49)) lseek err Invalid argument
file_pread(7,8,buffer,3907027328(243201/51/51)) lseek err Invalid argument
file_pread(7,8,buffer,3907027456(243201/53/53)) lseek err Invalid argument
file_pread(7,8,buffer,3907027584(243201/55/55)) lseek err Invalid argument
file_pread(7,8,buffer,3907027712(243201/57/57)) lseek err Invalid argument
file_pread(7,8,buffer,3907027840(243201/59/59)) lseek err Invalid argument
file_pread(7,8,buffer,3907027968(243201/61/61)) lseek err Invalid argument
file_pread(7,8,buffer,3907028096(243201/63/63)) lseek err Invalid argument
file_pread(7,8,buffer,3907028224(243201/66/2)) lseek err Invalid argument
file_pread(7,8,buffer,3907028352(243201/68/4)) lseek err Invalid argument
file_pread(7,8,buffer,3907028480(243201/70/6)) lseek err Invalid argument
file_pread(7,8,buffer,3907028608(243201/72/8)) lseek err Invalid argument
file_pread(7,8,buffer,3907028736(243201/74/10)) lseek err Invalid argument
file_pread(7,8,buffer,3907028864(243201/76/12)) lseek err Invalid argument
file_pread(7,1,buffer,3907028992(243201/78/14)) lseek err Invalid argument
file_pread(7,14,buffer,3907028993(243201/78/15)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 243201 13 12 3907022848
1 * HPFS - NTFS 0 32 33 243201 13 12 3907022848
NTFS at 0/32/33
NTFS at 0/32/33
				starradher
do not format or write if you havent baced up all your data, intended...
see if you can assign the drive a letter also, try on another pc witx xp on it, or linux.
I am currently building a new computer so will try on that one. Not sure what you mean by intended...
Boot sector looks ok now.
Might be possible that your file system is faulty.
If you've already recovered all your data, you can have a try to repair your file system running chkdsk driveletter: /r
within your command prompt.
You'll need administrator privileges.
If it doesn't work for you, you can reformat your disk and copy all your data back.
Many thanks Fiona. Chkdsk did not work on the original computer but I will have a go on the new one once I have finished building it as it has a much more up-to-date motherboard and I sense that the 2TB disk was an issue for the old one!
