Yesterday a 9gig mpg file was deleted from my hard drive accidentally.  Automated file recovery software was unable to recover the file so I used photorec and now have thousands of short mpg clips, I assume they are individual partitioned files of the origional mpg.  Is there a method to combining the mpgs together?  They all play but are only a few seconds long each.  The origional video was almost an hour long.
thanks,
chris
						Restoring recovered mpg
Re: Restoring recovered mpg
As long as it's only deleted you can have a try to use TestDisk.
You'll find it at Advanced / Undelete.
Please don't write anything to your disk anymore, otherwise it might be possible that you overwrite your required file.
				CChurchill
Thank you for the advice, Fiona.  Unfortunately TestDisk does not see the file.  I may be incorrect but it seems TestDisk only attempts to undelete files that were placed int he recycle bin and the file I am trying to recover was too big (9 gigs).   It never shows up in the undelete list.
Any additional advice will be appreciated.
Chris
Chris
