There's a big problem with my computer.My computer will not boot anymore.
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
1 * HPFS - NTFS 0 0 15 12 209 63 205996
Bad relative sector.
Warning: number of heads/cylinder mismatches 224 (NTFS) != 255 (HD)
Warning: number of sectors per track mismatches 19 (NTFS) != 63 (HD)
2 P hid. HPFS/NTFS 12 223 20 7258 179 63 116404262
3 P hid. HPFS/NTFS 7258 179 26 20006 239 63 204800438 [NieuwVolume]
4 E extended LBA 20006 233 4 60801 74 63 655361718
X extended 20006 240 1 33010 59 63 208897920
5 L HPFS - NTFS 20007 10 36 33010 59 63 208896310 [NieuwVolume]
X extended 33010 60 1 46141 14 63 210946680
6 L HPFS - NTFS 33010 87 38 46141 14 63 210944942 [NieuwVolume]
X extended 46141 15 1 60801 74 63 235516680
Is it possible to fix this problem?
Problem HDD WD 5000AAKX caviar blue
Re: Problem HDD WD 5000AAKX caviar blue
I am having the same problem, only mine is with external hard drive.
it shows that the information is there such as the hard drive has very little space on it but when i go to the folder where the music files are supposed to be they are not there.
Disk /dev/sdj - 1000 GB / 931 GiB - CHS 31008335 1 63
Warning: number of heads/cylinder mismatches 255 (NTFS) != 1 (HD)
1 P HPFS - NTFS 1 0 1 31008255 0 63 1953520065 [SeaGate]
Warning: Bad starting head (CHS and LBA don't match)
>[Quick Search] [ Backup ]
Try to locate partition
* HPFS - NTFS 1 0 1 31008255 0 63 1953520065 [SeaGate]
>dr-xr-xr-x 0 0 0 26-Aug-2014 16:34 .
dr-xr-xr-x 0 0 0 26-Aug-2014 16:34 ..
dr-xr-xr-x 0 0 0 9-Jul-2014 20:50 .ReadyDLNA
dr-xr-xr-x 0 0 0 14-Feb-2014 20:35 .Trash-1000
dr-xr-xr-x 0 0 0 6-Jul-2014 17:46 .Trash-1001
dr-xr-xr-x 0 0 0 2-Sep-2014 23:59 .Trash-1002
dr-xr-xr-x 0 0 0 30-Jun-2014 00:59 .Trash-999
dr-xr-xr-x 0 0 0 3-Sep-2014 00:06 Kill Them Softly (2012) [108
dr-xr-xr-x 0 0 0 3-Sep-2014 00:03 Untitled Folder
dr-xr-xr-x 0 0 0 3-Sep-2014 00:06 VIDEOS
dr-xr-xr-x 0 0 0 1-Jan-2008 04:38 docs
dr-xr-xr-x 0 0 0 3-Sep-2014 01:14 music
dr-xr-xr-x 0 0 0 22-Dec-2013 22:58 pictures
-r--r--r-- 0 0 454838 26-Jun-2014 02:22 0626140722.jpg
