I've got a 1.5TB HDD which had the partition information erased by putting into a Drobo box by mistake. Drobo has probably started changing the partition table once the hdd was added as after removing it from drobo and placing into an external hdd enclosure partitions were no longer recognised.
I've managed to run testdisk and it recognised the partition structure, however I am not sure if the file systems it is suggesting are correct.
I know it had three partitions, first being a clone of an imac hdd, while second and third were used for windows machine backups.
Now the testdisk log seems to have found the start and end of each of them but suggests HFSX for the file system.
Disk /dev/rdisk2 - 1500 GB / 1397 GiB - 2930277168 sectors, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/rdisk2 - 1500 GB / 1397 GiB - 2930277168 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=2930277167 (expected 2930277167)
hdr_lba_start=34
hdr_lba_end=2930277134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT differs, FAT sectors=48-64/3151
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 589037568
Mac HFS 409640 589447207 589037568
HFS+ blocksize=4096, 301 GB / 280 GiB
HFSX magic value at 977167452/0/1
part_size 976757816
Mac HFS 977167452 1953925267 976757816
HFSX blocksize=4096, 500 GB / 465 GiB
HFS+ magic value at 1954189312/0/1
part_size 975825672
Mac HFS 1954189312 2930014983 975825672
HFS+ blocksize=4096 + Backup, 499 GB / 465 GiB
P EFI System 40 409639 409600 [EFI]
P Mac HFS 409640 589447207 589037568
P Mac HFS 977167452 1953925267 976757816
P Mac HFS 1954189312 2930014983 975825672
First partition is most likely hfs+ and
as the 2nd and 3rd partitions were 500GB each and recognised by windows I would assume they couldn't be FATs, so probably the only choice is NTFS.
And finally my question - my guess is that they were NTFS and that's what I'm planning to change them to.
If it turns out they were a different format, do I have a second chance, once the partition table has been written with testdisk? I.e. If it doesn't work after will there be much use of doing the change again using testdisk?
I've managed to recover most of the files I needed with photorec so it is more of a practical experiment trying to learn more about hdd recovery.
Thanks for your help in advance.
Drobo formatted partition recovery
Who is online
Users browsing this forum: No registered users and 6 guests
