Thanks in advance and sorry for my bad english by the way.
Log:
Using locale 'C'.
Mon Aug 11 01:17:46 2014
Command line: TestDisk /log /dev/sde
OS: Linux, kernel 3.15.8-1-ARCH (#1 SMP PREEMPT Fri Aug 1 08:51:42 CEST 2014) x86_64
Compiler: GCC 4.8
Compilation date: 2014-02-28T19:18:36
ext2fs lib: 1.42.11, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: none
Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WD Ext HDD 1021, FW:2021
Disk /dev/sde - 500 GB / 465 GiB - WD Ext HDD 1021
Partition table type: EFI GPT
New geometry
Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243200 255 63 sector_size=512
Analyse Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243200 255 63
1 P MS Data 2048 3907022840 3907020793 [Games]
NTFS part_offset=1048576, part_size=2000394646016, sector_size=512
write!
file_pwrite(4,32,buffer,3907007967(243199/254/31)) write err No space left on device
Partition: Write error
