I'm trying to recover all files in my drive, but right now there are 60k+ files recovered, but 14 failed (recovery still in progress).
I checked the logs but it does not log which one failed. Is there any way to find out which ones failed?
The only thing that i see in the log are these entries
ERROR: Couldn't set the file's date and time for <filename>
No log entry for failed recovery?
Re: No log entry for failed recovery?
Do you have message like "ntfs_copy: ntfs_inode_open failed", "Cannot find attribute type", "fat_copy: Can't read cluster", "fat_copy: failed to write data" ?
Looks like that was the keyword to search for. I was able to find "Can't create file"
Thanks.
Thanks.
