Recovering Corrupted Files Topic is solved
aazman
#1 Post by aazman »
Ok, so I am somewhat competent with computers. I like to say I know enough to be stupid: I know some things, but am not fluent enough to figure things out myself (which is what finds me here). Thanks for being gentle and holding my hand through this
My flash drive (2GB Centon Bolt DataStick) is corrupt, but the files are important. When I open it in windows, I see:
When I run TestDisk (as admin), It recognizes the drive and such, but says "Bad ending cylinder (CHS and LBA don't match)." When I analyze through and list the files, it finds them, but also with gibberish file names:
When I copy them to my hard drive, 990 files are successfully copied, but again with gibberish file names and unopenable:
It also found over 900 recovered file fragments:
Log follows. Can you please help me recover the files on the flash drive. You can lecture me about not having backups later, but I'd really like to have the files back without wiping the drive and losing them forever...
Wed Aug 20 20:10:56 2014
TestDisk 7.0-WIP, Data Recovery Utility, August 2014
Compilation date: 2014-08-20T21:37:44
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2005925888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2005925888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=301503348736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2005663744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2142240768
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - Hitachi HTS725032A9A, S/N:017091CPCK40PVNKDTK4, FW:PC3O
Disk /dev/sdb - 2005 MB / 1913 MiB - CHS 243 255 63, sector size=512 - CENTON, FW:1100
Disk /dev/sdb - 2005 MB / 1913 MiB - CENTON
Analyse Disk /dev/sdb - 2005 MB / 1913 MiB - CHS 243 255 63
Geometry from i386 MBR: head=64 sector=43
BAD_RS LBA=512 63
FAT16 at 0/8/9
Info: size boot_sector 3917312, partition 3917312
FAT1 : 1-240
FAT2 : 241-480
start_rootdir : 481
Data : 513-3917248
sectors : 3917312
cluster_size : 64
no_of_cluster : 61199 (2 - 61200)
fat_length 240 calculated 240
1 * FAT16 >32M 0 8 9 243 222 43 3917312 [NO NAME]
Warning: Bad ending cylinder (CHS and LBA don't match)
FAT16 at 0/8/9
FAT1 : 1-240
FAT2 : 241-480
start_rootdir : 481
Data : 513-3917248
sectors : 3917312
cluster_size : 64
FAT16 at 0/8/9
FAT16, blocksize=32768, 2005 MB / 1912 MiB
file_pread(5,8,buffer,3917824(243/222/44)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,3917824(243/222/44)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,3917825(243/222/45)) lseek err Invalid argument
file_pread(5,14,buffer,3917826(243/222/46)) lseek err Invalid argument
file_pread(5,3,buffer,3917840(243/222/60)) lseek err Invalid argument
file_pread(5,3,buffer,3917887(243/223/44)) lseek err Invalid argument
file_pread(5,8,buffer,3917903(243/223/60)) lseek err Invalid argument
file_pread(5,11,buffer,3917950(243/224/44)) lseek err Invalid argument
file_pread(5,2,buffer,3919872(244/0/13)) lseek err Invalid argument
L FAT16 >32M 0 8 9 243 222 43 3917312 [NO NAME]
dir_partition inode=0
4132 drwxr-xr-x 0 0 0 20-Aug-2014 16:00 FOUND.000
30 -rwxr-xr-x 0 0 851968 20-Aug-2014 15:59
1698 -rwxr-xr-x 0 0 327680 12-Jan-1980 23:01 !
78 -rwxr-xr-x 0 0 1605632 12-Feb-1980 23:02 A
2454 -rwxr-xr-x 0 0 1081344 28-Feb-1980 23:02 Q
2618 -rwxr-xr-x 0 0 557056 13-Mar-1980 00:03 a
2701 -rwxr-xr-x 0 0 32768 29-Mar-1980 00:03 q
142 -rwxr-xr-x 0 0 1605632 13-Apr-1980 00:04 チ
2702 -rwxr-xr-x 0 0 1081344 29-Apr-1980 00:04 ム
2795 -rwxr-xr-x 0 0 557056 13-May-1980 00:05 ᄀ
2989 -rwxr-xr-x 0 0 32768 29-May-1980 00:05 ᄆ
206 -rwxr-xr-x 0 0 950272 13-Jun-1980 00:06 ￁
2990 -rwxr-xr-x 0 0 425984 29-Jun-1980 00:06 ￑
238 -rwxr-xr-x 0 0 622592 13-Jul-1980 00:07 £
3128 -rwxr-xr-x 0 0 98304 29-Jul-1980 00:07 ￱
270 -r-xr-xr-x 0 0 98304 13-Aug-1980 00:08 ��.
302 -r-xr-xr-x 0 0 950272 13-Sep-1980 00:09 !"#$.%&
3134 -r-xr-xr-x 0 0 425984 29-Sep-1980 00:09 1234.56
X 65535 -r-xr-xr-x 0 0 4294967295 13-Oct-1980 00:10 _BCD.EF
X 65535 -r-xr-xr-x 0 0 25166207 28-Nov-1980 23:11 _����t.uv
414 -r-xr-xr-x 0 0 98304 28-Dec-1980 23:12 ������ヤ.��ヨ
446 -r-xr-xr-x 0 0 131072 20-Aug-2014 16:00 ᄆᄇᄈᄡ.ᄉᄊ
462 -r-xr-xr-x 0 0 32768 20-Aug-2014 16:00 ￁��ᅢᅣ.ᅤᅥ
X 65535 -r-xr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _ᅭᅮᅯ.ᅰᅱ
526 -rwxr-xr-x 0 0 851968 20-Aug-2014 16:00 ��.
3191 -rwxr-xr-x 0 0 327680 20-Aug-2014 16:00 .
558 -rwxr-xr-x 0 0 196608 12-Jan-1981 23:17 !"#$.%&
590 -rwxr-xr-x 0 0 1081344 12-Feb-1981 23:18 ABCD.EF
3202 -rwxr-xr-x 0 0 557056 28-Feb-1981 23:18 QRST.UV
3275 -rwxr-xr-x 0 0 32768 13-Mar-1981 00:19 abcd.ef
X 65535 -rwxr-xr-x 0 0 41943679 20-Aug-2014 16:00 _rst.uv
654 -rwxr-xr-x 0 0 131072 13-Apr-1981 00:20 チツテト.ナニ
670 -rwxr-xr-x 0 0 294912 20-Aug-2014 16:00 ム��モヤ.ユヨ
686 -rwxr-xr-x 0 0 98304 13-May-1981 00:21 ᄀᄁᆪᄂ.ᆬᆭ
702 -rwxr-xr-x 0 0 262144 20-Aug-2014 16:00 ��ᄇᄈᄡ.ᄉᄊ
734 -rwxr-xr-x 0 0 327680 20-Aug-2014 16:00 ￑ᅭᅮᅯ.ᅰᅱ
750 -rwxr-xr-x 0 0 131072 13-Jul-1981 00:23 £¬ ̄¦.¥₩
766 -rwxr-xr-x 0 0 294912 20-Aug-2014 16:00 ￱��￳￴.￵￶
782 -r-xr-xr-x 0 0 98304 13-Aug-1981 00:24 .
798 -r-xr-xr-x 0 0 262144 29-Aug-1981 00:24 ��.
830 -r-xr-xr-x 0 0 262144 29-Sep-1981 00:25 ��234.56
862 -r-xr-xr-x 0 0 262144 29-Oct-1981 00:26 ��RST.UV
X 65535 -r-xr-xr-x 0 0 61866927 20-Aug-2014 16:00 _ᄁ����.��ᆭ
X 65535 -r-xr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _�������.��ᄊ
X 65535 -rwxr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _.
X 65535 -rwxr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _�.��
X 65535 -rwxr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _�"����.��&
1086 -rwxr-xr-x 0 0 65536 20-Aug-2014 16:00 ����3��.56
X 65535 -rwxr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _�������.UV
1150 -rwxr-xr-x 0 0 5242880 29-Mar-1982 00:35 qrst.uv
3276 -rwxr-xr-x 0 0 4718592 13-Apr-1982 00:36 チツテト.ナニ
3924 -rwxr-xr-x 0 0 4194304 29-Apr-1982 00:36 ムメモヤ.ユヨ
X 65535 -rwxr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _ᄁᆪᄂ.ᆬᆭ
X 65535 -rwxr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _�������.ᄉᄊ
X 65535 -rwxr-xr-x 0 0 80805887 20-Aug-2014 16:00 _���ᅢᅣ.��ᅥ
1262 -rwxr-xr-x 0 0 32768 20-Aug-2014 16:00 ���� ̄¦.¥₩
1278 -rwxr-xr-x 0 0 229376 29-Jul-1982 00:39 ￱￲￳￴.￵￶
X 65535 -r-xr-xr-x 0 0 4294967295 13-Aug-1982 00:40 _.��
1326 -r-xr-xr-x 0 0 458752 13-Sep-1982 00:41 ����#$.%&
1342 -r-xr-xr-x 0 0 557056 20-Aug-2014 16:00 1234.56
4052 -r-xr-xr-x 0 0 32768 13-Oct-1982 00:42 ABCD.EF
1374 -r-xr-xr-x 0 0 229376 20-Aug-2014 16:00 QRST.UV
1390 -r-xr-xr-x 0 0 163840 12-Nov-1982 23:43 abcd.��f
1422 -r-xr-xr-x 0 0 1572864 12-Dec-1982 23:44 チ��テト.ナニ
4053 -r-xr-xr-x 0 0 1048576 28-Dec-1982 23:44 ムメモヤ.ユヨ
4085 -r-xr-xr-x 0 0 524288 20-Aug-2014 16:00 ᄀᄁᆪᄂ.ᆬᆭ
X 65535 -r-xr-xr-x 0 0 96470463 20-Aug-2014 16:00 _ᄇᄈᄡ.ᄉᄊ
1518 -r-xr-xr-x 0 0 163840 20-Aug-2014 16:00 £¬����.��₩
1534 -r-xr-xr-x 0 0 557056 20-Aug-2014 16:00 ￱￲����.￵￶
4101 -rwxr-xr-x 0 0 32768 20-Aug-2014 16:00 .
1566 -rwxr-xr-x 0 0 163840 20-Aug-2014 16:00 .
X 65535 -rwxr-xr-x 0 0 103810607 20-Aug-2014 16:00 _"��$.%&
X 65535 -rwxr-xr-x 0 0 4294967295 12-Feb-1983 23:50 _�������.EF
1630 -rwxr-xr-x 0 0 262144 28-Feb-1983 23:50 QRST.UV
1662 -rwxr-xr-x 0 0 98304 29-Mar-1983 00:51 qrst.uv
1678 -rwxr-xr-x 0 0 32768 20-Aug-2014 16:00 ��ツテト.ナニ
1710 -rwxr-xr-x 0 0 262144 13-May-1983 00:53 ᄀ��
1758 -rwxr-xr-x 0 0 1277952 29-Jun-1983 00:54 ￑ᅭᅮᅯ.ᅰᅱ
4102 -rwxr-xr-x 0 0 753664 13-Jul-1983 00:55 £¬ ̄¦.¥₩
4125 -rwxr-xr-x 0 0 229376 29-Jul-1983 00:55 ￱￲￳￴.￵￶
1870 -r-xr-xr-x 0 0 32768 20-Aug-2014 16:00 ABC��.EF
1886 -r-xr-xr-x 0 0 32768 20-Aug-2014 16:00 ��������.��V
X 65535 -r-xr-xr-x 0 0 4294967295 20-Aug-2014 16:00 _�������.��f
1950 -r-xr-xr-x 0 0 65536 20-Aug-2014 16:00 ��������.��ヨ
1966 -r-xr-xr-x 0 0 196608 20-Aug-2014 16:00 ������ᄂ.��ᆭ
2014 -r-xr-xr-x 0 0 262144 20-Aug-2014 16:00 ��������.ᅰᅱ
X 4227 -rwxr-xr-x 0 0 8388608 20-Aug-2014 17:13 ReadyBoostPerfTest.tmp
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended 0 1 1 243 222 43 3917761
5 L FAT16 >32M 0 8 9 243 222 43 3917312 [NO NAME]
write_all_log_i386: CHS: 0/1/1,lba=63
Re: Recovering Corrupted Files
Only FAT32, exFAT or NTFS filesystem is used on big harddisk, not FAT16.
Run TestDisk, Advanced, select the partition, use Type, change the partition type to FAT32, Boot, RebuildBS, if you can see your files, choose Write, confirm, Quit
If it doesn't work, try with NTFS and next with exFAT.
Good luck
aazman
#3 Post by aazman »
Thank you very much for your help :) I was able to follow your instructions, but unfortunately I still cannot recover my files yet :(
I changed partition to FAT32, Boot, RebuildBS, I was able to see my files, but still with gibberish names. I chose Write, confirm, Quit.
The files still have gibberish names and cannot be opened.
Further, when I rerun TestDisk, the partition still appears as FAT16. If I try to change it again to FAT32, in Boot, I see a message:
OK
Warning: valid FAT bootsector but not a FAT32 one!
Bad
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
Third sectors (Second part of boot code) are not identical.
If I RebuildBS from here, I see:
FAT : 16, reserved=1, fat_length=240
dir_entries 0->1 205
dir_entries 0
dir_entries 512
sectors_per_cluster 64
I can see the files (again with gibberish names), but I have no option to Write this time.
I went to try NTFS and exFAT, but I didn't see them in the list of partition options. Should I choose HPFS-NTFS (option 07)? What should I choose for exFAT?
Here is the log for attempting to change the partition type to FAT32:
Thu Aug 21 16:27:32 2014
BAD_RS LBA=512 63
FAT16 at 0/8/9
FAT1 : 1-240
FAT2 : 241-480
start_rootdir : 481
Data : 513-3917248
sectors : 3917312
cluster_size : 64
Change partition type:
1 * FAT32 0 8 9 243 222 43 3917312 [NO NAME]
fat32_boot_sector
FAT16 at 0/8/9
FAT1 : 1-240
FAT2 : 241-480
start_rootdir : 481
Data : 513-3917248
sectors : 3917312
cluster_size : 64
OK
Bad
rebuild_FAT_BS p_fat12 0, p_fat16 1, p_fat32 1
fat_find_type(max_offset=30668, p_fat12=0, p_fat16=1, p_fat32=1, debug=1, dump_ind=0)
FAT16 at 1(0/8/10), nbr=20
FAT16 at 241(0/11/61), nbr=20
FAT32 at 1228(0/27/40), nbr=1
FAT32 at 1942(0/38/61), nbr=4
FAT16 at 3283(0/60/16), nbr=1
FAT16 at 13974(0/229/60), nbr=1
FAT32 at 15325(0/251/25), nbr=21
FAT32 at 18317(1/43/56), nbr=1
FAT32 at 21528(1/94/54), nbr=24
FAT16 at 21675(1/97/12), nbr=1
FAT32 at 21716(1/97/53), nbr=1
FAT32 at 22157(1/104/53), nbr=1
FAT32 at 22605(1/111/60), nbr=1
FAT32 at 23119(1/120/7), nbr=1
FAT32 at 23821(1/131/16), nbr=1
FAT32 at 24790(1/146/40), nbr=5
FAT16 at 25309(1/154/55), nbr=1
FAT32 at 25613(1/159/44), nbr=1
FAT32 at 27042(1/182/24), nbr=4
FAT32 at 27341(1/187/8), nbr=1
FAT16 at 29919(1/228/3), nbr=1
FAT16 at 29957(1/228/41), nbr=1
first_fat 1, second_fat 241
dir_entries 0
dir_entries 512
New / Current boot sector
FAT16
sector_size 512 512
cluster_size 64 64
reserved 1 1
fats 2 2
dir_entries 512 512
sectors 0 0
media F8 F8
fat_length 240 240
secs_track 63 63
heads 255 255
hidden 512 512
total_sect 3917312 3917312
Write new boot!
fat32_boot_sector
FAT16 at 0/8/9
FAT1 : 1-240
FAT2 : 241-480
start_rootdir : 481
Data : 513-3917248
sectors : 3917312
cluster_size : 64
OK
Bad
Try type 7 for NTFS
