Listing files causes crash
paulvbrown
#1 Post by paulvbrown »
Hi!
320G hard drive was in Vista machine. Now in LiveCD Lubuntu, latest testdisk installed:
Architecture: i386
Version: 6.14-1ubuntu1
Entire disk shows as unallocated space (289G) in gparted and has a warning, "/dev/sda: unrecognised disk label"
testdisk seems to go fine, finds the disk. Intel partition type --> Analyze --> reports partition doesn't have endmark 0xAA55, but QuickSearch finds 2 partitions. (20480000 sector "PQSERVICE" FAT32 and 604657664 sector "ACER" HPFS-NTFS)
P(list files) works fine for FAT32 partition, but when used w/2nd partition testdisk crashes and sends me back to command line. =o(
Tried a deeper search, but it did the same.
fwiw, here's the latest log:
Fri Sep  5 15:43:21 2014
OS: Linux, kernel 3.11.0-12-generic (#19-Ubuntu SMP Wed Oct 9 16:12:00 UTC 2013) i686
Compiler: GCC 4.8
Compilation date: 2013-08-23T16:52:16
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size       625142448 sectors
/dev/sda: user_max   625142448 sectors
/dev/sda: native_max 625142448 sectors
/dev/sda: dco        625142448 sectors
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200BEVT-22ZCT0, S/N:WD-WXR0E39H2931, FW:11.01A11
Disk /dev/sdb - 4037 MB / 3850 MiB - CHS 1017 125 62, sector size=512, FW:PMAP
Disk /dev/sda - 320 GB / 298 GiB - WDC WD3200BEVT-22ZCT0
Analyse Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
Re: Listing files causes crash
Please try using TestDisk 7.0-WIP
paulvbrown
#3 Post by paulvbrown »
Argh. Why didn't I try that BEFORE spending the day watching PhotoRec rescue the files one-by-one.
7.0 worked beautifully. THANK YOU!!
