Hello.
Long story short, my flash drive has become unreadable definitely due to not safely removing. It was formatted FAT32 using an Intel Partition Table. Now, It gives the standard "Do you want to format drive?" message (to which I say no), and I've been running TestDisk over the past week or so. The first event was fixed by rebuilding the boot sector, but this doesn't seem to be the case anymore.
The drive has stopped reading again.
When selecting my drive and selecting the [Intel] Partition Table and [Analyse], it comes up with no partitions and a "Partition: Read Error". Quick and Deeper searches produce nothing, though it states "Read Error" as it scans. [Advanced] also does not detect a partition.
When selecting my flash drive and selecting [None] for my partition table and [Advanced], it comes up with a Primary Unknown Filesystem drive displayed as [> P Unknown 0 0 1 1022 76036 16035840]
Changing the Partition Type to FAT32 and selecting [Boot] produces:
fat32_boot_sector: Can't read boot sector.
Bad
fat32_boot_sector: Can't read backup boot sector.
Bad
Sectors are identical.
I Tried to rebuild the Boot sector. It didn't find a FAT, and after it finished scanning, it said "Can't find cluster size".
Trying to undelete only wields "Can't open filesystem. Filesystem seems damaged."
I've been browsing through the forum trying to find answers, but to no avail. Also, I accidentally deleted my backup awhile ago, and undeletion doesn't really work. I've used PhotoRec to try and recover my files before, but organizing the files again is crazy considering just how many images are on it. I'm avoiding reformating the drive so I can try to recover the file system structure, but I don't have the money to spend on fixing the drive...
Right now I've booted up my PC with PartedMagic. I'm not familiar with Linux PCs, though. I have an image.dd of the drive saved to play with, but I don't know how... Please, any help would be appreciated.
Need Help repairing 8GB FAT32 Flash Drive...
Re: Need Help repairing 8GB FAT32 Flash Drive...
If you want to play with the image.dd file, select this file, right click, "Open with" and select TestDisk.
Thanks for the response! I opened image.dd using TestDisk, and after playing with it for a bit, selected [Intel] Partition Table and [Analyse]. The program said "Partition sector doesn't have the endmark 0xAA55.". What does this mean? (Thanks for your help so far though, here on the forums and by having made the program itself.)
