Hi!
i can't repair FileSystem with testdisk.. i tried to re-generate new FAT32 filesystem into a SD card 32 Giga but give me an error, don't identify the partition as FAT32 (the file are not identical, etc etc) (also in all programs that i use, the card seems a 32 MB and not 32 GB in RAW partition) so I have only a RAW partition of 32 MB, PLEASE HELP ME, i will do a good DONATION for your beautiful software!
Can't Reapair FileSystem FAT32!!! important
Re: Can't Repair FileSystem FAT32!!! important
Clean the SD card connectors and try PhotoRec. If the memory card is seen as 32 MB instead of 32 GB, the problem is hardware. To recover your data, you will have to contact a data recovery company.
rugge89lau
Re: Can't Reapair FileSystem FAT32!!! important
IMPOSSIBLE that the CANON 6d burned 2 SD in 10 minutes... the problem is surely in the Filesystem corrupt...
