Cannot access HP Simplesave 1TB external HDD
cescpistol
#1 Post by cescpistol »
I have an HP Simplesave 1TB external HDD. A couple of months ago, the adapter gave out, so I thought I should just get a new one. So I did, but when I plug it in it just lights up and does not read. I decided to take out the SATA drive and use a dock to connect it to my laptop. When I go to disk management, the drive appears unallocated. Used testdisk to do a quick search, then a deeper search but no partition was detected. I don't know the file system, so I just used the default.
I need the files in the hard drive, so I just can't give up on it. Neither can I simply have it repaired by someone else because the HDD contains sensitive information. I hope you guys can help.
Here's the log file:
Fri Apr 27 09:01:24 2012
TestDisk 6.14-WIP, Data Recovery Utility, April 2012
Compilation date: 2012-04-21T15:07:46
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=481430601728
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=18358468608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=108027904
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HTS545050B9A, S/N:011142BP4N577MNC0BEM, FW:PB4O
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 EAVS-00M4B0, FW:0200
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10 EAVS-00M4B0
Ask the user for vista mode
search_vista_part: 1
file_pread(5,7,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
Store new MBR code
macacox
Re: Cannot access HP Simplesave 1TB external HDD
#2 Post by macacox »
I'm having the exact same problem
Did you find a solution?
solitaryxsoul
#3 Post by solitaryxsoul »
Check this link, it might help under The type of the file system is RAW - Recovery of a damaged FAT boot sector : http://www.cgsecurity.org/wiki/Data_Recovery_Examples
