Size boot_sector bigger than partition
rafah1982
#1 Post by rafah1982 »
I was installing fedora 20 with dual boot with windows 7, and after I resized the win partition, windows stopped booting. The system repair didn't work, as well as other options such as bootexec /rebuildbcd.
In fact, while doing those things, I made things worse and now neither grub nor the windows bootloader recognize any windows partitions.
So I downloaded testdisk and ran it from fedora, and I see this:
TestDisk 7.0-WIP, Data Recovery Utility, August 2014
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
 1 P Windows RE(store)        0  32 33  2349 223 50   37748736
 2 * HPFS - NTFS           2349 223 51  2362 159 37     204800
Error: size boot_sector 918353505 > partition 906389504
Invalid NTFS or EXFAT boot
 3 P HPFS - NTFS           2362 159 38 58782 194 36  906389504
 4 E extended             58782 194 37 60801  80 63   32428080
 5 L Linux                58782 227  6 58846 161  3    1024000
   X extended             58846 161  4 60801  80 15   31401984
 6 L Linux LVM            58846 193 36 60801  80 15   31399936
>[Quick Search]  [ Backup ]
                            Try to locate partition
Take a look at:
Apparently, when rezising the windows partition there was an error in which the boot sector says the partition is bigger than it really is, making it impossible to mount from linux and no bootloader can "see" the partition.
Any ideas on how to fix this?
I thought about resizing the partition to the number of sectors it shoud have according to the boot sector. Another option would be to tell the boot_sector the actual number of sectors that the partition has.
Of course, i have no idea on how to do either.
I would avoid formatting the partition by all means, given that there there is info that i would not like to loose.
Anyone had this issue before??
Thanks a lot!!
Re: Size boot_sector bigger than partition
What's the current size of your partition?
Did you run Deeper Search?
Might be possible that your previous partition would be found?
Also you can check each found partition and pressing p to have a try to list your files.
A boot sector diagnose using RebuildBS makes only sense if you have an appropriate partition which can contain your data.
Please repeat your diagnose and copy and paste the content of your testdisk.log.
rafah1982
#3 Post by rafah1982 »
Hi, Thanks Fiona for the reply.
I partially fixed by running ntfsfix on fedora.
Now the boot sector size matches the partition size and I can mount it with no issues and use my windows files from fedora.
However, I cannot boot it. I believe that when I was trying to solve it through the windows repair system, I destroyed the BCD and the MBR.
I used bootinfoscript and i got this result:
============================= Boot Info Summary: ===============================
 => Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img, but core.img can not be found at this
    location.
sda1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows Vista/7: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /BOOTMGR /BOOT/BCD
sda2: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:        /bootmgr
sda3: __________________________________________________________________________
    File system:       ntfs
    Operating System:  Windows 7
    Boot files:        /Windows/System32/winload.exe /ubuntu/winboot/wubildr
                       /ubuntu/winboot/wubildr.mbr
sda4: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  -
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:        /grub2/grub.cfg
sda6: __________________________________________________________________________
    File system:       LVM2_member
    Boot sector type:  -
    Boot sector info:
fedora-swap': __________________________________________________________________
    File system:
    Boot sector type:  Unknown
    Boot sector info:
    Mounting failed:   mount: unknown filesystem type ''
fedora-root': __________________________________________________________________
    File system:
    Boot sector info:
I want to boot /dev/sda3 that is my windows 7 system.
Any help?
Thanks!!
#4 Post by Fiona »
Nice to read that you didn't loose any data.
I'd need info from testdisk Analyse.
Either log file or screen shot?
It's your current partition structure/table.
So I can judge your current situation and suggest something to make your system bootable.
Perhaps it could be necessary to set your MBR back to standard, so that you can reinstall or repair Grub or using EasyBCD under Windows to configure multiboot.
If windows doesn't want to start, it might be possible that you have to run a windows startup repair.
http://pcsupport.about.com/od/toolsofth ... repair.htm
