Thanks for that link, I have looked it over before.
So, I choose rdisk, then EFI GPT, then Quick Search.
The results are:
I then Continue,
At this screen I don't know what to do with the Primary or Deleted characteristics, i just don't change them. If I press 'P' for list files, says 'Filesystem seems damaged'. Won't let me load backup either. So I just continue,
Deeper Search takes a while, but I get same results - can't List Files, and can't Write.
If I choose [Write] without Deeper Search I get an error regardless.
That being said,
There is another post on here that is very similar to my situation (the last post claims a solution). But It's over my head and I don't know if it can actually be applied to what I am doing:
http://forum.cgsecurity.org/phpBB3/hard ... t2982.html
