need some help
Vizionz
need some help
#1 Post by Vizionz »
I have a external western digital essentials drive that is now showing up as raw. when i have tried other harddrive programs it will show the data but there is no file system so cant access it. need some step by step instruction on how to do this with testdisk.i have looked through a few of the examples on the wiki and by google but still not figuring it out.
i do the quick search it shows one partition deeper search will show the same partition. so thats where i am stuck. i can post any info in this thread that you need just need to figure it out. i have like 700 gb worth of data i dont want to lose.
DoctorWD
Re: need some help
#2 Post by DoctorWD »
Hey Vizionz,
It's a little bit hard to say but there is nothing to do with your drive. If the file system shows RAW it will be very hard to get your data back, of course if you are not a hard drive guru. Actually there are some Data Recovery programs. You can try to google them, may be this will help. I guess you didn't make a backup of your drive. So in this particular case the best option will be a Data Recovery Company which will get your info back if it is very important for you.
Here is the link for the Data Recovery Companies:
http://support.wdc.com/recovery/index.asp?wdc_lang=en
If you have any questions, feel free to ask.
Hope this helps,
Doctor_WD
Vizionz
Re: need some help
#3 Post by Vizionz »
i can see all the data on the drive i just cant access it the partition is not formatted like i can use testdisk and see all the folders and files nothing missing
Re: need some help
#4 Post by Fiona »
Might be possible that only your boot sector is damaged?
Can you copy and paste the content of your testdisk.log into your next post?
So I can see your diagnose using testdisk.
You'll find it within your testdisk folder.
You can open it using an editor or wordpad.
Vizionz
Re: need some help
#5 Post by Vizionz »
there was no log when i tested it i followed a tutorial that said choose no log. so should i just do it with a log and then analyze it and that will give me a log ?
Vizionz
Re: need some help
#6 Post by Vizionz »
Fri Oct 10 15:40:08 2014
Compilation date: 2014-10-05T21:22:25
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=490683236352
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=303865790464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=16106127360
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2217836544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1000202241024
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST950042 3AS, S/N:6WR1VALK, FW:0005
Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - ST932042 1ASG, S/N:5TJ0FXWS, FW:DE16
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WD 10EAVS External, S/N:WD-WCAU44592201, FW:1.75
Drive F: - 2217 MB / 2115 MiB - CHS 528 64 32, sector size=2048 - PLDS DVD+-RW DL-8A4SH, FW:HD11
Disk /dev/sdc - 1000 GB / 931 GiB - WD 10EAVS External
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
FAT32 at 0/1/1
Info: size boot_sector 1953519992, partition 1953520002
FAT1 : 38-238446
FAT2 : 238447-476855
start_rootdir : 476856 root cluster : 2
Data : 476856-1953519991
sectors : 1953519992
cluster_size : 64
no_of_cluster : 30516299 (2 - 30516300)
fat_length 238409 calculated 238409
file_pread(6,16,buffer,239086(14/225/2)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,239092(14/225/8)) ReadFile Data error (cyclic redundancy check).
comp_FAT: can't read FAT2
1 * FAT32 0 1 1 121600 254 63 1953520002 [My Book]
FAT32 at 0/1/1
FAT1 : 38-238446
cluster_size : 64
FAT32 at 0/1/1
FAT32 LBA 0 1 1 121600 254 53 1953519992 [My Book]
FAT32, blocksize=32768, 1000 GB / 931 GiB
file_pread(6,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,8,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(6,1,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(6,8,buffer,1953525311(121601/83/18)) lseek err Invalid argument
file_pread(6,8,buffer,1953525439(121601/85/20)) lseek err Invalid argument
file_pread(6,8,buffer,1953525567(121601/87/22)) lseek err Invalid argument
file_pread(6,8,buffer,1953525695(121601/89/24)) lseek err Invalid argument
file_pread(6,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(6,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(6,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(6,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(6,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(6,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(6,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
* FAT32 LBA 0 1 1 121600 254 63 1953520002 [My Book]
1 * FAT32 LBA 0 1 1 121600 254 63 1953520002 [My Book]
Vizionz
Re: need some help
#7 Post by Vizionz »
if you need more info please advice. i am doing a deaper search but it takes forever
Re: need some help
#8 Post by cgrenier »
The error message "cyclic redundancy check" shows that your disk contains bad sector.
You can try to recover some files by running TestDisk, Advanced, List and copy.
The best solution will be to clone your disk to a new empty disk using gnu ddrescue.
DoctorWD
Re: need some help
#9 Post by DoctorWD »
Or you can try to do the same using Acronis Tool. I think you have it with your essentials. Try to clone it and everything will be fine. If this does not help, the only way will be Data Recovery.
Hope this helps,
Doctor_WD
