Recovering my NTFS and FAT partitions after ubuntu install
fcb0007
#1 Post by fcb0007 »
Hi all,
This is the first time that I am using testdisk and I need your help. Here is what happend: I had dual boot (Windows 7 and Ubuntu) on my laptop. The hard had some NTFS partitions for Windows and recovery. I created one ex2 and one swap partitions for Ubuntu, as well as two FAT partitions for data. It has been like that for a long time. Then yesterday I accidentally formatted the whole disk (fresh Ubuntu installation). As I had some unbacked data on my FAT partitions, I was hoping to recover them. I used Ubuntu live disk and installed testdisk from Universe repository. However, it seems that it cannot recover my partitions. I was wondering if you can help me with this.
Here is content of testdisk log file:
Thu Oct 9 15:08:13 2014
OS: Linux, kernel 3.13.0-32-generic (#57-Ubuntu SMP Tue Jul 15 03:51:08 UTC 2014) x86_64
Compiler: GCC 4.8
Compilation date: 2013-10-29T01:29:29
ext2fs lib: 1.42.9, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 1465149168 sectors
/dev/sda: user_max 1465149168 sectors
/dev/sda: native_max 1465149168 sectors
/dev/sda: dco 1465149168 sectors
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - Hitachi HTS547575A9E384, S/N:J2140054K7LTGB, FW:JE4OA50B
Disk /dev/sdb - 15 GB / 14 GiB - CHS 14883 64 32, sector size=512 - Kingston DataTraveler G3, FW:PMAP
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - WD Ext HDD 1021, FW:2021
Disk /dev/sda - 750 GB / 698 GiB - Hitachi HTS547575A9E384
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1465149167 (expected 1465149167)
hdr_lba_start=34
hdr_lba_end=1465149134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 2048 1050623 1048576
2 P Unknown 1050624 1452777471 1451726848
3 P Linux Swap 1452777472 1465147391 12369920
Analyse Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
I have also attached the screenshot of testdisk analyze. Unfortunately, it seems that it cannot recover my FAT partitions and files in them. Could you please help me?
Thanks a lot
