The Disk is too small
Sierrab
#1 Post by Sierrab »
Hope that you can help
Background, I had a my C drive crash on Monday, leaving me with only 39gb of files visible in one partition rather than the approx 350 there should be in that partition which should be 500gb or so in size. The disk is 500gb with one partition
Test Disk is reporting that the hard disk was too small plus the message "The following partition can't be recovered"
The files it is reporting are the ones that I can see in Explorer. It is only seeing the 39 gb not the whole disk which is why it is I think it is reporting the disk is too small.
On the other hand windows is reporting that there whole drive is healthy and active and is the correct size
I would be grateful for idiot proof instructions (if there are any available) on how to proceed.
Sierrab
Re: The Disk is too small
#2 Post by Sierrab »
Many, many thanks for entry into the forum
This is ugly. Pleases see the lo and see if there is anything that you could advise.
The drive should contain 350gb of data, but only 30 or so are showing
Thu Oct 30 16:09:12 2014
Compilation date: 2014-10-23T06:49:34
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=500103634432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=500103634432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000203091968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500096991744
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-60M2NA0, S/N:WD-WCC3FA91CYRV, FW:01.01A01
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512 - WDC WD5000AAKX-001CA0, S/N:WD-WMAYUX332578, FW:15.01H15
Disk /dev/sdb - 500 GB / 465 GiB - WDC WD5000AAKX-001CA0
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 60799 254 63 976751937
Change partition type:
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/sdb - 500 GB / 465 GiB - CHS 60800 255 63
NTFS at 0/1/1
NTFS at 0/1/1
filesystem size 976751937
mft_lcn 746478
mftmirr_lcn 29827446
file_pread(5,2,buffer,976764928(60800/205/14)) lseek err Invalid argument
file_pread(5,1,buffer,976764928(60800/205/14)) lseek err Invalid argument
file_pread(5,1,buffer,976764927(60800/205/13)) lseek err Invalid argument
file_pread(5,14,buffer,976764929(60800/205/15)) lseek err Invalid argument
file_pread(5,3,buffer,976764943(60800/205/29)) lseek err Invalid argument
file_pread(5,3,buffer,976764990(60800/206/13)) lseek err Invalid argument
file_pread(5,8,buffer,976765006(60800/206/29)) lseek err Invalid argument
file_pread(5,11,buffer,976765053(60800/207/13)) lseek err Invalid argument
file_pread(5,2,buffer,976766975(60800/237/45)) lseek err Invalid argument
Many hopeful thanks in advance if you can take a look
have a good w/e
S
