"Filesystem seems damaged" issue
Ultronium
#1 Post by Ultronium »
hello everyone!!
i have a very critical problem going on with my lap top.
i lost a whole partition of my hdd (Seagate ST750LM022), the one that contains ALL MY WORK, PERSONAL FILES EVERYTHING!
i tried too use testdisk, since i used this awesome program before to recover raw system partition successfully, and after a quick search, i had this unfamiliar issue: heads/cylinders mismatch:
i tried to follow the indication and change the value from 16 to 255 in geometry configuration, it seems that it worked , i found the lost partition after after a deep search, but when i list the files, nothing is found:
i really don t know what to do anymore, i don't want to format the partition, my whole life is in there, and recovery tool photorec recovers the files without directories which is inconvenient because i have hundreds of thousands of files in there, (470 GB in the partition)
please help, maybe i missed a step in testdisk procedure.
thank you.
samsung NP300E5A - A02FR
windows: home premium
4GB RAM
Intel i3
HDD : Seagate ST750LM022
Ultronium
Re: "Filesystem seems damaged" issue
#2 Post by Ultronium »
no replay please? im desperate please help me
eclark461
#3 Post by eclark461 »
Ok first you are going to want to recover the files off of the drive
Read up on my last post when it comes active on how to do this.
