the disk is a WD external USB/Firewire/eSATA disk sized 1GB.
Formatted as HFS+ I use it on my PowerPC Mac, but sometimes connect it to a windows XP machine which reads HFs+ via MacDrive. Windows crashed with the disc attached and since then the WDs does not mount (Linx, PC, Mac).
I still hope that all the data is there, but somehow the partition map/superblock/driver (?) is gone.
After start on my Mac testdisks shows:
Disk /dev/disk0 - 82 GB / 76 GiB
Disk /dev/disk1 - 163 GB / 152 GiB (RO)
Disk /dev/disk2 - 2000 GB / 1863 GiB (RO)
>Disk /dev/disk3 - 1000 GB / 931 GiB
Disk /dev/rdisk0 - 82 GB / 76 GiB
Disk /dev/rdisk1 - 163 GB / 152 GiB (RO)
Disk /dev/rdisk2 - 2000 GB / 1863 GiB (RO)
Disk /dev/rdisk3 - 1000 GB / 931 GiB pdisk shows for this disk:
Partition map (with 512 byte blocks) on '/dev/rdisk3'
#: type name length base ( size )
1: Apple_partition_map Apple 63 @ 1
2: Apple_Free Extra 262144 @ 64 (128.0M)
3: Apple_HFS p1 1073741824 @ 262208 (512.0G)
4: Apple_Free Extra 879521136 @ 1074004032 (419.4G)
Device block size=512, Number of Blocks=1953525168 (931.5G)
DeviceType=0x0, DeviceId=0x0
Disk /dev/disk3 - 1000 GB / 931 GiB - CHS 1953525168 1 1
1 P partition_map 1 63 63
2 P Free 64 262207 262144
3 P HFS 262208 1074004031 1073741824
4 P Free 1074004032 1953525167 879521136
testdisk from menu "Advanced" (Partition table gets recognized as Mac. Fine):
Selecting part#3, then superblock gives
Volume header
Bad
Backup volume header
Bad
Sectors are not identical. I do not know how to proceed from here. Maybe someone can help me with this.
Question: Shouldn't there be a driver after partition1? On my built-in discs there is one and there is plenty of free space in part. #2.
Any help appreciated. Thank you in advance!
TH
