WD20EARS partition problems
janoatthe
Re: WD20EARS partition problems
#11 Post by janoatthe »
Hello
The log is for quick search after changing the values to 255, at 99% the program locked up .
I am running deep search currently
Mike
Sat May 5 07:51:30 2012
OS: Windows 7 (7600)
Compilation date: 2012-05-01T20:08:09
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=319965626368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=250048479744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=250058801664
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000263577600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=1500291039744
Disk /dev/sda - 320 GB / 298 GiB - CHS 41345 240 63, sector size=512 - ST3320620A, S/N:2020202020202020202020205133304643374354, FW:3.AAC
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST325031 0AS, S/N:9RY3VV8V, FW:4.AA
Disk /dev/sdc - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - ST315005 41AS, S/N:6XW0JTY4, FW:CC34
Disk /dev/sdd - 250 GB / 232 GiB - CHS 484521 16 63, sector size=512 - ST325031 0AS, S/N:6RY4DSTQ, FW:3.AA
Disk /dev/sde - 2000 GB / 1863 GiB - CHS 258401 240 63, sector size=512 - WDC WD20 EARS-00MVWB0, S/N:WD-WMAZ20152192, FW:50.0
Disk /dev/sde - 2000 GB / 1863 GiB - WDC WD20 EARS-00MVWB0
Partition table type: EFI GPT
New geometry
Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243202 255 63 sector_size=512
Analyse Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243202 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907040129)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Data 264192 3907028991 3906764800 [Basic data partition]
janoatthe
#12 Post by janoatthe »
hello Fiona
test disk just finished
I ran deep search with the geometry change of 255 and here is the resulting screen shot and the log.
I have had to split the log into several posts as it is somewhat large.
Mike
Sat May 5 07:59:36 2012
New geometry
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS, blocksize=4096, 2000 GB / 1862 GiB
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/113/34
filesystem size 3906764800
mftmirr_lcn 2
NTFS part_offset=135266304, part_size=2000263577600, sector_size=512
NTFS at 16/113/34
mftmirr_lcn 2
LVM magic value at 1379/241/31
LVM magic value at 2168/13/5
Unknown 412733416 5200775103500263 5200774690766848
WBFS, 2662796 TB / 2421799 TiB
Partition not added.
LVM magic value at 25934/173/29
HFS magic value at 29004/12/44
part_size 2707083441
Mac HFS 465950059 3173033499 2707083441 [‹Ütø]
HFS, 1386 GB / 1290 GiB
HFS magic value at 29004/12/46
cramfs Marker at 74193/40/63
recover_cramfs
MS Data 1191913127 1197300201 5387074 [%(îX„çΚ¯C=ên«½Ú]
cramfs, 2758 MB / 2630 MiB
XFS Marker at 84528/138/45
recover_xfs
MS Data 1357951058 27738143322620371 27738141964669313 [†V0
Ô”Þkó„]
XFS <=6.1, 14201928 TB / 12916578 TiB
This partition ends after the disk limits. (start=1357951058, size=1921552769, end=3279503827, disk end=3907040130)
SYSV4 Marker at 118057/25/20
recover_sysv4
Unknown 1896587299 234309774254114 234307877666816 [µŸªfVm]
SysV4, 119965 TB / 109108 TiB
LVM magic value at 122846/45/37
LVM magic value at 125602/106/17
FAT12 at 128807/101/63
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
MS Data 2069290880 2069293759 2880
FAT32 at 128807/137/24
FAT1 : 32-798
FAT2 : 799-1565
start_rootdir : 1566 root cluster : 2
Data : 1566-786237
sectors : 786240
cluster_size : 8
no_of_cluster : 98084 (2 - 98085)
fat_length 767 calculated 767
FAT differs, FAT sectors=0-16/767
heads/cylinder 240 (FAT) != 255 (HD)
MS Data 2069293109 2070079348 786240 [W98__BOOT]
FAT32, blocksize=4096, 402 MB / 383 MiB
FAT12 at 128807/147/57
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 2069293772 2069296651 2880
FAT12 at 128807/193/39
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 2069296652 2069299531 2880
HFS magic value at 140432/197/51
part_size 1751451796
Mac HFS 2256052541 4007504336 1751451796 [ªï8‘ÞY0 ¼ÁîpPN
ÑiÏ8;#€@F]
HFS, 896 GB / 835 GiB
This partition ends after the disk limits. (start=2256052541, size=1751451796, end=4007504336, disk end=3907040130)
HFS magic value at 140432/197/53
Mac HFS 504600749 2256052544 1751451796 [ªï8‘ÞY0 ¼ÁîpPN
ÑiÏ8;#€@F]
HFS found using backup sector!, 896 GB / 835 GiB
HFS magic value at 143063/132/63
part_size 83519532
Mac HFS 2298315473 2381835004 83519532
HFS, 42 GB / 39 GiB
HFS magic value at 143063/133/2
part_size 83519532
Mac HFS 2214795945 2298315476 83519532
HFS found using backup sector!, 42 GB / 39 GiB
Unknown 2384248340 5326446584 2942198245
FATX, 1506 GB / 1402 GiB
LVM magic value at 149890/251/48
NTFS at 153422/67/34
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 2464722511 2464728684 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 2464728684 2464734857 6174 [Boot]
FAT12 at 153422/167/22
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
no_of_cluster : 2586 (2 - 2587)
fat_length 8 calculated 8
FAT differs, FAT sectors=0-8/8
heads/cylinder 4 (FAT) != 255 (HD)
sect/track 17 (FAT) != 63 (HD)
MS Data 2464734972 2464755710 20739 [NO NAME]
check_FAT: Unusual, only one FAT
FAT32 at 153422/167/23
check_FAT: Bad number of entries in root dir
LVM magic value at 158514/87/52
NTFS at 175926/227/46
mft_lcn 2058
mftmirr_lcn 5162
MS Data 2826259363 2826265536 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 2826265536 2826271709 6174 [Boot]
FAT12 at 175927/72/34
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
MS Data 2826271824 2826292562 20739 [NO NAME]
FAT32 at 175927/72/35
LVM magic value at 188066/238/36
recover_JFS: s_blocksize=2817560477
recover_JFS: s_size 3947538340
recover_JFS: s_fsckpxd.len:345385
recover_JFS: s_logpxd.len:10825424
recover_JFS: part_size 1525009774
MS Data 3065847400 18868358562900950 18868355497053550
JFS 344864123, blocksize=2817560477, 9660598 TB / 8786262 TiB
This partition ends after the disk limits. (start=3065847400, size=1525009774, end=295889878, disk end=3907040130)
LVM magic value at 196191/25/19
NTFS at 198242/98/33
mftmirr_lcn 2
NTFS part_offset=1630599135232, part_size=2000263577600, sector_size=512
mftmirr_lcn 2
MS Data 3184763936 7091528735 3906764800
This partition ends after the disk limits. (start=3184763936, size=3906764800, end=2796561439, disk end=3907040130)
NTFS at 198292/154/39
mftmirr_lcn 2
NTFS part_offset=1631012208640, part_size=2000263577600, sector_size=512
mftmirr_lcn 2
MS Data 3185570720 7092335519 3906764800
This partition ends after the disk limits. (start=3185570720, size=3906764800, end=2797368223, disk end=3907040130)
LVM magic value at 202099/148/23
MS Data 3328997048 18868358826050598 18868355497053550
This partition ends after the disk limits. (start=3328997048, size=1525009774, end=559039526, disk end=3907040130)
XFS Marker at 231087/16/52
recover_xfs
MS Data 3712413714 27738145677083027 27738141964669313 [†V0
Ô”Þkó„]
This partition ends after the disk limits. (start=3712413714, size=1921552769, end=1338999187, disk end=3907040130)
NTFS at 234797/152/12
mftmirr_lcn 2
NTFS part_offset=1931275976704, part_size=2000263577600, sector_size=512
mftmirr_lcn 2
MS Data 3772023392 7678788191 3906764800
This partition ends after the disk limits. (start=3772023392, size=3906764800, end=3383820895, disk end=3907040130)
NTFS at 240528/124/13
mftmirr_lcn 2
NTFS part_offset=1978414153728, part_size=2000263577600, sector_size=512
mftmirr_lcn 2
MS Data 3864090144 7770854943 3906764800
This partition ends after the disk limits. (start=3864090144, size=3906764800, end=3475887647, disk end=3907040130)
NTFS at 240961/162/34
mftmirr_lcn 2
NTFS part_offset=1981976936448, part_size=2000263577600, sector_size=512
mftmirr_lcn 2
MS Data 3871048704 7777813503 3906764800
This partition ends after the disk limits. (start=3871048704, size=3906764800, end=3482846207, disk end=3907040130)
NTFS at 241260/184/13
mftmirr_lcn 2
NTFS part_offset=1984436994048, part_size=2000263577600, sector_size=512
mftmirr_lcn 2
MS Data 3875853504 7782618303 3906764800
This partition ends after the disk limits. (start=3875853504, size=3906764800, end=3487651007, disk end=3907040130)
NTFS at 241455/196/22
mftmirr_lcn 2
NTFS part_offset=1986041315328, part_size=2000263577600, sector_size=512
mftmirr_lcn 2
MS Data 3878986944 7785751743 3906764800
This partition ends after the disk limits. (start=3878986944, size=3906764800, end=3490784447, disk end=3907040130)
NTFS at 241522/6/53
mftmirr_lcn 2
NTFS part_offset=1986586296320, part_size=2000263577600, sector_size=512
NTFS at 241522/6/53
mftmirr_lcn 2
MS Data 3880051360 7786816159 3906764800
This partition ends after the disk limits. (start=3880051360, size=3906764800, end=3491848863, disk end=3907040130)
file_pread(8,1,buffer,3907029168(243201/81/1)) ReadFile The request could not be performed because of an I/O device error.
janoatthe
#13 Post by janoatthe »
file_pread(8,1,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029171(243201/81/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029172(243201/81/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029173(243201/81/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029174(243201/81/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029175(243201/81/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029177(243201/81/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029178(243201/81/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029179(243201/81/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029180(243201/81/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029181(243201/81/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029182(243201/81/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029183(243201/81/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029184(243201/81/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029185(243201/81/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029186(243201/81/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029187(243201/81/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029188(243201/81/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029189(243201/81/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029190(243201/81/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029191(243201/81/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029192(243201/81/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029193(243201/81/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029194(243201/81/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029195(243201/81/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029196(243201/81/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029197(243201/81/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029198(243201/81/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029199(243201/81/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029200(243201/81/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029201(243201/81/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029202(243201/81/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029203(243201/81/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029204(243201/81/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029205(243201/81/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029206(243201/81/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029207(243201/81/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029208(243201/81/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029209(243201/81/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029210(243201/81/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029211(243201/81/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029212(243201/81/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029213(243201/81/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029214(243201/81/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029215(243201/81/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029216(243201/81/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029217(243201/81/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029218(243201/81/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029219(243201/81/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029220(243201/81/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029221(243201/81/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029222(243201/81/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029223(243201/81/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029224(243201/81/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029225(243201/81/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029226(243201/81/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029227(243201/81/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029228(243201/81/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029229(243201/81/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029230(243201/81/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029231(243201/82/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029232(243201/82/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029233(243201/82/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029234(243201/82/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029235(243201/82/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029236(243201/82/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029237(243201/82/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029238(243201/82/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029239(243201/82/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029240(243201/82/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029241(243201/82/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029242(243201/82/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029243(243201/82/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029244(243201/82/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029245(243201/82/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029246(243201/82/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029247(243201/82/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029249(243201/82/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029250(243201/82/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029251(243201/82/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029252(243201/82/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029253(243201/82/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029254(243201/82/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029255(243201/82/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029256(243201/82/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029257(243201/82/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029258(243201/82/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029259(243201/82/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029260(243201/82/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029261(243201/82/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029262(243201/82/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029263(243201/82/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029264(243201/82/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029265(243201/82/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029266(243201/82/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029267(243201/82/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029268(243201/82/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029269(243201/82/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029270(243201/82/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029271(243201/82/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029272(243201/82/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029273(243201/82/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029274(243201/82/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029275(243201/82/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029276(243201/82/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029277(243201/82/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029278(243201/82/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029279(243201/82/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029280(243201/82/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029281(243201/82/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029282(243201/82/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029283(243201/82/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029284(243201/82/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029285(243201/82/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029286(243201/82/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029287(243201/82/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029288(243201/82/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029289(243201/82/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029290(243201/82/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029291(243201/82/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029292(243201/82/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029293(243201/82/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029294(243201/83/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029295(243201/83/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029296(243201/83/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029297(243201/83/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029298(243201/83/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029299(243201/83/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029300(243201/83/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029301(243201/83/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029302(243201/83/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029303(243201/83/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029304(243201/83/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029305(243201/83/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029306(243201/83/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029307(243201/83/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029308(243201/83/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029309(243201/83/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029310(243201/83/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029311(243201/83/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029312(243201/83/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029313(243201/83/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029314(243201/83/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029315(243201/83/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029316(243201/83/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029317(243201/83/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029318(243201/83/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029319(243201/83/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029320(243201/83/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029321(243201/83/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029322(243201/83/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029323(243201/83/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029324(243201/83/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029325(243201/83/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029326(243201/83/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029327(243201/83/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029328(243201/83/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029329(243201/83/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029330(243201/83/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029331(243201/83/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029332(243201/83/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029333(243201/83/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029334(243201/83/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029335(243201/83/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029336(243201/83/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029337(243201/83/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029338(243201/83/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029339(243201/83/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029340(243201/83/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029341(243201/83/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029342(243201/83/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029343(243201/83/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029344(243201/83/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029345(243201/83/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029346(243201/83/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029347(243201/83/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029348(243201/83/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029349(243201/83/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029350(243201/83/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029351(243201/83/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029352(243201/83/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029353(243201/83/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029354(243201/83/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029355(243201/83/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029356(243201/83/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029357(243201/84/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029358(243201/84/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029359(243201/84/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029360(243201/84/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029361(243201/84/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029362(243201/84/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029363(243201/84/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029364(243201/84/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029365(243201/84/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029366(243201/84/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029367(243201/84/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029368(243201/84/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029369(243201/84/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029370(243201/84/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029371(243201/84/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029372(243201/84/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029373(243201/84/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029374(243201/84/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029375(243201/84/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029377(243201/84/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029378(243201/84/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029379(243201/84/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029380(243201/84/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029381(243201/84/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029382(243201/84/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029383(243201/84/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029384(243201/84/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029385(243201/84/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029386(243201/84/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029387(243201/84/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029388(243201/84/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029389(243201/84/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029390(243201/84/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029391(243201/84/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029392(243201/84/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029393(243201/84/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029394(243201/84/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029395(243201/84/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029396(243201/84/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029397(243201/84/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029398(243201/84/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029399(243201/84/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029400(243201/84/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029401(243201/84/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029402(243201/84/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029403(243201/84/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029404(243201/84/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029405(243201/84/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029406(243201/84/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029407(243201/84/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029408(243201/84/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029409(243201/84/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029410(243201/84/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029411(243201/84/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029412(243201/84/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029413(243201/84/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029414(243201/84/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029415(243201/84/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029416(243201/84/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029417(243201/84/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029418(243201/84/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029419(243201/84/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029420(243201/85/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029421(243201/85/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029422(243201/85/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029423(243201/85/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029424(243201/85/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029425(243201/85/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029426(243201/85/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029427(243201/85/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029428(243201/85/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029429(243201/85/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029430(243201/85/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029431(243201/85/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029432(243201/85/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029433(243201/85/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029434(243201/85/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029435(243201/85/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029436(243201/85/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029437(243201/85/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029438(243201/85/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029439(243201/85/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029440(243201/85/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029441(243201/85/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029442(243201/85/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029443(243201/85/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029444(243201/85/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029445(243201/85/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029446(243201/85/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029447(243201/85/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029448(243201/85/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029449(243201/85/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029450(243201/85/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029451(243201/85/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029452(243201/85/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029453(243201/85/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029454(243201/85/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029455(243201/85/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029456(243201/85/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029457(243201/85/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029458(243201/85/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029459(243201/85/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029460(243201/85/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029461(243201/85/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029462(243201/85/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029463(243201/85/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029464(243201/85/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029465(243201/85/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029466(243201/85/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029467(243201/85/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029468(243201/85/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029469(243201/85/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029470(243201/85/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029471(243201/85/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029472(243201/85/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029473(243201/85/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029474(243201/85/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029475(243201/85/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029476(243201/85/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029477(243201/85/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029478(243201/85/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029479(243201/85/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029480(243201/85/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029481(243201/85/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029482(243201/85/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029483(243201/86/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029484(243201/86/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029485(243201/86/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029486(243201/86/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029487(243201/86/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029488(243201/86/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029489(243201/86/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029490(243201/86/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029491(243201/86/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029492(243201/86/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029493(243201/86/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029494(243201/86/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029495(243201/86/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029496(243201/86/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029497(243201/86/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029498(243201/86/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029499(243201/86/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029500(243201/86/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029501(243201/86/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029502(243201/86/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029503(243201/86/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029505(243201/86/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029506(243201/86/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029507(243201/86/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029508(243201/86/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029509(243201/86/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029510(243201/86/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029511(243201/86/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029512(243201/86/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029513(243201/86/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029514(243201/86/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029515(243201/86/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029516(243201/86/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029517(243201/86/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029518(243201/86/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029519(243201/86/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029520(243201/86/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029521(243201/86/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029522(243201/86/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029523(243201/86/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029524(243201/86/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029525(243201/86/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029526(243201/86/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029527(243201/86/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029528(243201/86/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029529(243201/86/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029530(243201/86/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029531(243201/86/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029532(243201/86/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029533(243201/86/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029534(243201/86/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029535(243201/86/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029536(243201/86/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029537(243201/86/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029538(243201/86/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029539(243201/86/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029540(243201/86/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029541(243201/86/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029542(243201/86/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029543(243201/86/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029544(243201/86/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029545(243201/86/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029546(243201/87/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029547(243201/87/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029548(243201/87/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029549(243201/87/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029550(243201/87/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029551(243201/87/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029552(243201/87/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029553(243201/87/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029554(243201/87/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029555(243201/87/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029556(243201/87/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029557(243201/87/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029558(243201/87/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029559(243201/87/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029560(243201/87/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029561(243201/87/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029562(243201/87/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029563(243201/87/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029564(243201/87/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029565(243201/87/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029566(243201/87/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029567(243201/87/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029568(243201/87/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029569(243201/87/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029570(243201/87/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029571(243201/87/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029572(243201/87/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029573(243201/87/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029574(243201/87/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029575(243201/87/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029576(243201/87/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029577(243201/87/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029578(243201/87/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029579(243201/87/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029580(243201/87/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029581(243201/87/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029582(243201/87/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029583(243201/87/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029584(243201/87/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029585(243201/87/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029586(243201/87/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029587(243201/87/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029588(243201/87/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029589(243201/87/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029590(243201/87/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029591(243201/87/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029592(243201/87/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029593(243201/87/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029594(243201/87/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029595(243201/87/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029596(243201/87/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029597(243201/87/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029598(243201/87/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029599(243201/87/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029600(243201/87/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029601(243201/87/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029602(243201/87/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029603(243201/87/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029604(243201/87/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029605(243201/87/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029606(243201/87/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029607(243201/87/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029608(243201/87/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029609(243201/88/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029610(243201/88/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029611(243201/88/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029612(243201/88/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029613(243201/88/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029614(243201/88/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029615(243201/88/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029616(243201/88/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029617(243201/88/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029618(243201/88/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029619(243201/88/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029620(243201/88/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029621(243201/88/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029622(243201/88/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029623(243201/88/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029624(243201/88/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029625(243201/88/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029626(243201/88/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029627(243201/88/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029628(243201/88/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029629(243201/88/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029630(243201/88/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029631(243201/88/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029633(243201/88/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029634(243201/88/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029635(243201/88/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029636(243201/88/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029637(243201/88/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029638(243201/88/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029639(243201/88/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029640(243201/88/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029641(243201/88/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029642(243201/88/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029643(243201/88/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029644(243201/88/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029645(243201/88/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029646(243201/88/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029647(243201/88/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029648(243201/88/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029649(243201/88/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029650(243201/88/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029651(243201/88/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029652(243201/88/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029653(243201/88/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029654(243201/88/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029655(243201/88/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029656(243201/88/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029657(243201/88/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029658(243201/88/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029659(243201/88/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029660(243201/88/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029661(243201/88/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029662(243201/88/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029663(243201/88/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029664(243201/88/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029665(243201/88/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029666(243201/88/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029667(243201/88/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029668(243201/88/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029669(243201/88/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029670(243201/88/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029671(243201/88/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029672(243201/89/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029673(243201/89/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029674(243201/89/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029675(243201/89/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029676(243201/89/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029677(243201/89/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029678(243201/89/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029679(243201/89/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029680(243201/89/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029681(243201/89/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029682(243201/89/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029683(243201/89/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029684(243201/89/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029685(243201/89/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029686(243201/89/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029687(243201/89/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029688(243201/89/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029689(243201/89/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029690(243201/89/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029691(243201/89/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029692(243201/89/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029693(243201/89/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029694(243201/89/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029695(243201/89/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029696(243201/89/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029697(243201/89/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029698(243201/89/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029699(243201/89/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029700(243201/89/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029701(243201/89/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029702(243201/89/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029703(243201/89/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029704(243201/89/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029705(243201/89/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029706(243201/89/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029707(243201/89/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029708(243201/89/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029709(243201/89/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029710(243201/89/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029711(243201/89/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029712(243201/89/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029713(243201/89/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029714(243201/89/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029715(243201/89/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029716(243201/89/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029717(243201/89/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029718(243201/89/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029719(243201/89/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029720(243201/89/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029721(243201/89/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029722(243201/89/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029723(243201/89/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029724(243201/89/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029725(243201/89/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029726(243201/89/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029727(243201/89/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029728(243201/89/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029729(243201/89/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029730(243201/89/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029731(243201/89/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029732(243201/89/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029733(243201/89/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029734(243201/89/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029735(243201/90/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029736(243201/90/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029737(243201/90/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029738(243201/90/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029739(243201/90/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029740(243201/90/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029741(243201/90/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029742(243201/90/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029743(243201/90/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029744(243201/90/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029745(243201/90/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029746(243201/90/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029747(243201/90/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029748(243201/90/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029749(243201/90/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029750(243201/90/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029751(243201/90/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029752(243201/90/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029753(243201/90/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029754(243201/90/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029755(243201/90/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029756(243201/90/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029757(243201/90/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029758(243201/90/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029759(243201/90/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029761(243201/90/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029762(243201/90/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029763(243201/90/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029764(243201/90/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029765(243201/90/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029766(243201/90/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029767(243201/90/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029768(243201/90/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029769(243201/90/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029770(243201/90/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029771(243201/90/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029772(243201/90/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029773(243201/90/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029774(243201/90/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029775(243201/90/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029776(243201/90/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029777(243201/90/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029778(243201/90/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029779(243201/90/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029780(243201/90/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029781(243201/90/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029782(243201/90/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029783(243201/90/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029784(243201/90/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029785(243201/90/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029786(243201/90/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029787(243201/90/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029788(243201/90/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029789(243201/90/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029790(243201/90/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029791(243201/90/57)) lseek err Invalid argument
janoatthe
#14 Post by janoatthe »
janoatthe
#15 Post by janoatthe »
file_pread(8,1,buffer,3907029792(243201/90/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029793(243201/90/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029794(243201/90/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029795(243201/90/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029796(243201/90/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029797(243201/90/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029798(243201/91/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029799(243201/91/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029800(243201/91/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029801(243201/91/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029802(243201/91/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029803(243201/91/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029804(243201/91/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029805(243201/91/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029806(243201/91/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029807(243201/91/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029808(243201/91/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029809(243201/91/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029810(243201/91/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029811(243201/91/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029812(243201/91/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029813(243201/91/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029814(243201/91/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029815(243201/91/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029816(243201/91/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029817(243201/91/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029818(243201/91/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029819(243201/91/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029820(243201/91/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029821(243201/91/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029822(243201/91/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029823(243201/91/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029824(243201/91/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029825(243201/91/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029826(243201/91/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029827(243201/91/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029828(243201/91/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029829(243201/91/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029830(243201/91/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029831(243201/91/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029832(243201/91/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029833(243201/91/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029834(243201/91/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029835(243201/91/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029836(243201/91/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029837(243201/91/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029838(243201/91/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029839(243201/91/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029840(243201/91/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029841(243201/91/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029842(243201/91/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029843(243201/91/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029844(243201/91/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029845(243201/91/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029846(243201/91/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029847(243201/91/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029848(243201/91/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029849(243201/91/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029850(243201/91/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029851(243201/91/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029852(243201/91/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029853(243201/91/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029854(243201/91/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029855(243201/91/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029856(243201/91/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029857(243201/91/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029858(243201/91/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029859(243201/91/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029860(243201/91/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029861(243201/92/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029862(243201/92/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029863(243201/92/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029864(243201/92/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029865(243201/92/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029866(243201/92/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029867(243201/92/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029868(243201/92/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029869(243201/92/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029870(243201/92/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029871(243201/92/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029872(243201/92/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029873(243201/92/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029874(243201/92/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029875(243201/92/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029876(243201/92/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029877(243201/92/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029878(243201/92/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029879(243201/92/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029880(243201/92/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029881(243201/92/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029882(243201/92/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029883(243201/92/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029884(243201/92/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029885(243201/92/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029886(243201/92/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029887(243201/92/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029889(243201/92/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029890(243201/92/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029891(243201/92/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029892(243201/92/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029893(243201/92/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029894(243201/92/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029895(243201/92/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029896(243201/92/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029897(243201/92/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029898(243201/92/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029899(243201/92/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029900(243201/92/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029901(243201/92/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029902(243201/92/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029903(243201/92/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029904(243201/92/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029905(243201/92/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029906(243201/92/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029907(243201/92/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029908(243201/92/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029909(243201/92/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029910(243201/92/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029911(243201/92/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029912(243201/92/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029913(243201/92/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029914(243201/92/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029915(243201/92/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029916(243201/92/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029917(243201/92/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029918(243201/92/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029919(243201/92/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029920(243201/92/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029921(243201/92/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029922(243201/92/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029923(243201/92/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029924(243201/93/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029925(243201/93/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029926(243201/93/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029927(243201/93/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029928(243201/93/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029929(243201/93/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029930(243201/93/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029931(243201/93/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029932(243201/93/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029933(243201/93/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029934(243201/93/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029935(243201/93/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029936(243201/93/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029937(243201/93/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029938(243201/93/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029939(243201/93/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029940(243201/93/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029941(243201/93/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029942(243201/93/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907029943(243201/93/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907029944(243201/93/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907029945(243201/93/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907029946(243201/93/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029947(243201/93/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029948(243201/93/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029949(243201/93/26)) lseek err Invalid argument
janoatthe
Re: WD20EARS partition problems
#16 Post by janoatthe »
file_pread(8,1,buffer,3907029950(243201/93/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029951(243201/93/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029952(243201/93/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029953(243201/93/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029954(243201/93/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029955(243201/93/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029956(243201/93/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029957(243201/93/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029958(243201/93/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029959(243201/93/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029960(243201/93/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029961(243201/93/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029962(243201/93/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907029963(243201/93/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029964(243201/93/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029965(243201/93/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029966(243201/93/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029967(243201/93/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029968(243201/93/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029969(243201/93/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029970(243201/93/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029971(243201/93/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029972(243201/93/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029973(243201/93/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029974(243201/93/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029975(243201/93/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029976(243201/93/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029977(243201/93/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029978(243201/93/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029979(243201/93/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029980(243201/93/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029981(243201/93/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029982(243201/93/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029983(243201/93/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029984(243201/93/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029985(243201/93/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029986(243201/93/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029987(243201/94/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029988(243201/94/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029989(243201/94/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029990(243201/94/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029991(243201/94/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029992(243201/94/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029993(243201/94/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029994(243201/94/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029995(243201/94/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029996(243201/94/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029997(243201/94/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029998(243201/94/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029999(243201/94/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030000(243201/94/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030001(243201/94/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030002(243201/94/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030003(243201/94/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030004(243201/94/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030005(243201/94/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030006(243201/94/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030007(243201/94/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030008(243201/94/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030009(243201/94/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030010(243201/94/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030011(243201/94/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030012(243201/94/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030013(243201/94/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030014(243201/94/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030015(243201/94/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030017(243201/94/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030018(243201/94/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030019(243201/94/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030020(243201/94/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030021(243201/94/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030022(243201/94/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030023(243201/94/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030024(243201/94/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030025(243201/94/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030026(243201/94/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030027(243201/94/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030028(243201/94/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030029(243201/94/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030030(243201/94/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030031(243201/94/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030032(243201/94/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030033(243201/94/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030034(243201/94/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030035(243201/94/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030036(243201/94/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030037(243201/94/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030038(243201/94/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030039(243201/94/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030040(243201/94/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030041(243201/94/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030042(243201/94/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030043(243201/94/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030044(243201/94/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030045(243201/94/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030046(243201/94/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030047(243201/94/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030048(243201/94/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030049(243201/94/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030050(243201/95/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030051(243201/95/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030052(243201/95/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030053(243201/95/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030054(243201/95/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030055(243201/95/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030056(243201/95/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030057(243201/95/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030058(243201/95/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030059(243201/95/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030060(243201/95/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030061(243201/95/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030062(243201/95/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030063(243201/95/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030064(243201/95/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030065(243201/95/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030066(243201/95/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030067(243201/95/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030068(243201/95/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030069(243201/95/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030070(243201/95/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030071(243201/95/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030072(243201/95/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030073(243201/95/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030074(243201/95/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030075(243201/95/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030076(243201/95/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030077(243201/95/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030078(243201/95/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030079(243201/95/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030080(243201/95/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030081(243201/95/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030082(243201/95/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030083(243201/95/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030084(243201/95/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030085(243201/95/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030086(243201/95/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030087(243201/95/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030088(243201/95/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030089(243201/95/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030090(243201/95/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030091(243201/95/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030092(243201/95/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030093(243201/95/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030094(243201/95/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030095(243201/95/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030096(243201/95/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030097(243201/95/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030098(243201/95/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030099(243201/95/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030100(243201/95/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030101(243201/95/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030102(243201/95/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030103(243201/95/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030104(243201/95/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030105(243201/95/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030106(243201/95/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030107(243201/95/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030108(243201/95/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030109(243201/95/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030110(243201/95/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030111(243201/95/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030112(243201/95/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030113(243201/96/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030114(243201/96/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030115(243201/96/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030116(243201/96/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030117(243201/96/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030118(243201/96/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030119(243201/96/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030120(243201/96/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030121(243201/96/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030122(243201/96/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030123(243201/96/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030124(243201/96/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030125(243201/96/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030126(243201/96/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030127(243201/96/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030128(243201/96/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030129(243201/96/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030130(243201/96/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030131(243201/96/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030132(243201/96/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030133(243201/96/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030134(243201/96/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030135(243201/96/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030136(243201/96/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030137(243201/96/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030138(243201/96/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030139(243201/96/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030140(243201/96/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030141(243201/96/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030142(243201/96/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030143(243201/96/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030145(243201/96/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030146(243201/96/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030147(243201/96/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030148(243201/96/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030149(243201/96/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030150(243201/96/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030151(243201/96/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030152(243201/96/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030153(243201/96/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030154(243201/96/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030155(243201/96/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030156(243201/96/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030157(243201/96/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030158(243201/96/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030159(243201/96/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030160(243201/96/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030161(243201/96/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030162(243201/96/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030163(243201/96/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030164(243201/96/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030165(243201/96/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030166(243201/96/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030167(243201/96/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030168(243201/96/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030169(243201/96/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030170(243201/96/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030171(243201/96/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030172(243201/96/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030173(243201/96/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030174(243201/96/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030175(243201/96/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030176(243201/97/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030177(243201/97/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030178(243201/97/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030179(243201/97/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030180(243201/97/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030181(243201/97/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030182(243201/97/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030183(243201/97/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030184(243201/97/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030185(243201/97/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030186(243201/97/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030187(243201/97/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030188(243201/97/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030189(243201/97/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030190(243201/97/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030191(243201/97/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030192(243201/97/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030193(243201/97/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030194(243201/97/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030195(243201/97/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030196(243201/97/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030197(243201/97/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030198(243201/97/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030199(243201/97/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030200(243201/97/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030201(243201/97/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030202(243201/97/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030203(243201/97/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030204(243201/97/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030205(243201/97/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030206(243201/97/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030207(243201/97/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030208(243201/97/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030209(243201/97/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030210(243201/97/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030211(243201/97/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030212(243201/97/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030213(243201/97/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030214(243201/97/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030215(243201/97/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030216(243201/97/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030217(243201/97/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030218(243201/97/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030219(243201/97/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030220(243201/97/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030221(243201/97/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030222(243201/97/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030223(243201/97/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030224(243201/97/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030225(243201/97/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030226(243201/97/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030227(243201/97/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030228(243201/97/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030229(243201/97/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030230(243201/97/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030231(243201/97/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030232(243201/97/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030233(243201/97/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030234(243201/97/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030235(243201/97/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030236(243201/97/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030237(243201/97/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030238(243201/97/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030239(243201/98/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030240(243201/98/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030241(243201/98/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030242(243201/98/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030243(243201/98/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030244(243201/98/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030245(243201/98/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030246(243201/98/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030247(243201/98/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030248(243201/98/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030249(243201/98/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030250(243201/98/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030251(243201/98/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030252(243201/98/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030253(243201/98/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030254(243201/98/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030255(243201/98/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030256(243201/98/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030257(243201/98/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030258(243201/98/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030259(243201/98/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030260(243201/98/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030261(243201/98/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030262(243201/98/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030263(243201/98/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030264(243201/98/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030265(243201/98/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030266(243201/98/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030267(243201/98/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030268(243201/98/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030269(243201/98/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030270(243201/98/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030271(243201/98/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030273(243201/98/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030274(243201/98/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030275(243201/98/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030276(243201/98/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030277(243201/98/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030278(243201/98/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030279(243201/98/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030280(243201/98/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030281(243201/98/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030282(243201/98/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030283(243201/98/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030284(243201/98/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030285(243201/98/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030286(243201/98/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030287(243201/98/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030288(243201/98/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030289(243201/98/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030290(243201/98/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030291(243201/98/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030292(243201/98/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030293(243201/98/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030294(243201/98/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030295(243201/98/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030296(243201/98/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030297(243201/98/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030298(243201/98/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030299(243201/98/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030300(243201/98/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030301(243201/98/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030302(243201/99/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030303(243201/99/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030304(243201/99/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030305(243201/99/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030306(243201/99/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030307(243201/99/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030308(243201/99/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030309(243201/99/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030310(243201/99/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030311(243201/99/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030312(243201/99/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030313(243201/99/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030314(243201/99/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030315(243201/99/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030316(243201/99/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030317(243201/99/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030318(243201/99/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030319(243201/99/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030320(243201/99/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030321(243201/99/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030322(243201/99/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030323(243201/99/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030324(243201/99/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030325(243201/99/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030326(243201/99/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030327(243201/99/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030328(243201/99/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030329(243201/99/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030330(243201/99/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030331(243201/99/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030332(243201/99/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030333(243201/99/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030334(243201/99/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030335(243201/99/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030336(243201/99/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030337(243201/99/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030338(243201/99/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030339(243201/99/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030340(243201/99/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030341(243201/99/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030342(243201/99/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030343(243201/99/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030344(243201/99/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030345(243201/99/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030346(243201/99/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030347(243201/99/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030348(243201/99/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030349(243201/99/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030350(243201/99/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030351(243201/99/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030352(243201/99/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030353(243201/99/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030354(243201/99/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030355(243201/99/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030356(243201/99/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030357(243201/99/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030358(243201/99/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030359(243201/99/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030360(243201/99/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030361(243201/99/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030362(243201/99/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030363(243201/99/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030364(243201/99/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030365(243201/100/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030366(243201/100/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030367(243201/100/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030368(243201/100/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030369(243201/100/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030370(243201/100/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030371(243201/100/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030372(243201/100/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030373(243201/100/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030374(243201/100/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030375(243201/100/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030376(243201/100/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030377(243201/100/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030378(243201/100/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030379(243201/100/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030380(243201/100/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030381(243201/100/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030382(243201/100/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030383(243201/100/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030384(243201/100/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030385(243201/100/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030386(243201/100/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030387(243201/100/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030388(243201/100/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030389(243201/100/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030390(243201/100/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030391(243201/100/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030392(243201/100/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030393(243201/100/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030394(243201/100/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030395(243201/100/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030396(243201/100/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030397(243201/100/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030398(243201/100/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030399(243201/100/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030401(243201/100/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030402(243201/100/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030403(243201/100/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030404(243201/100/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030405(243201/100/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030406(243201/100/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030407(243201/100/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030408(243201/100/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030409(243201/100/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030410(243201/100/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030411(243201/100/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030412(243201/100/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030413(243201/100/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030414(243201/100/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030415(243201/100/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030416(243201/100/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030417(243201/100/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030418(243201/100/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030419(243201/100/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030420(243201/100/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030421(243201/100/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030422(243201/100/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030423(243201/100/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030424(243201/100/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030425(243201/100/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030426(243201/100/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030427(243201/100/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030428(243201/101/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030429(243201/101/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030430(243201/101/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030431(243201/101/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030432(243201/101/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030433(243201/101/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030434(243201/101/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030435(243201/101/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030436(243201/101/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030437(243201/101/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030438(243201/101/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030439(243201/101/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030440(243201/101/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030441(243201/101/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030442(243201/101/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030443(243201/101/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030444(243201/101/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030445(243201/101/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030446(243201/101/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030447(243201/101/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030448(243201/101/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030449(243201/101/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030450(243201/101/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030451(243201/101/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030452(243201/101/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030453(243201/101/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030454(243201/101/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030455(243201/101/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030456(243201/101/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030457(243201/101/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030458(243201/101/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030459(243201/101/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030460(243201/101/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030461(243201/101/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030462(243201/101/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030463(243201/101/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030464(243201/101/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030465(243201/101/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030466(243201/101/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030467(243201/101/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030468(243201/101/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030469(243201/101/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030470(243201/101/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030471(243201/101/44)) lseek err Invalid argum
janoatthe
#17 Post by janoatthe »
file_pread(8,1,buffer,3907030472(243201/101/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030473(243201/101/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030474(243201/101/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030475(243201/101/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030476(243201/101/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030477(243201/101/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030478(243201/101/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030479(243201/101/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030480(243201/101/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030481(243201/101/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030482(243201/101/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030483(243201/101/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030484(243201/101/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030485(243201/101/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030486(243201/101/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030487(243201/101/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030488(243201/101/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030489(243201/101/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030490(243201/101/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030491(243201/102/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030492(243201/102/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030493(243201/102/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030494(243201/102/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030495(243201/102/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030496(243201/102/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030497(243201/102/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030498(243201/102/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030499(243201/102/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030500(243201/102/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030501(243201/102/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030502(243201/102/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030503(243201/102/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030504(243201/102/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030505(243201/102/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030506(243201/102/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030507(243201/102/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030508(243201/102/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030509(243201/102/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030510(243201/102/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030511(243201/102/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030512(243201/102/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030513(243201/102/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030514(243201/102/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030515(243201/102/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030516(243201/102/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030517(243201/102/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030518(243201/102/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030519(243201/102/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030520(243201/102/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030521(243201/102/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030522(243201/102/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030523(243201/102/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030524(243201/102/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030525(243201/102/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030526(243201/102/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030527(243201/102/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030529(243201/102/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030530(243201/102/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030531(243201/102/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030532(243201/102/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030533(243201/102/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030534(243201/102/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030535(243201/102/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030536(243201/102/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030537(243201/102/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030538(243201/102/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030539(243201/102/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030540(243201/102/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030541(243201/102/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030542(243201/102/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030543(243201/102/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030544(243201/102/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030545(243201/102/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030546(243201/102/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030547(243201/102/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030548(243201/102/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030549(243201/102/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030550(243201/102/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030551(243201/102/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030552(243201/102/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030553(243201/102/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030554(243201/103/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030555(243201/103/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030556(243201/103/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030557(243201/103/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030558(243201/103/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030559(243201/103/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030560(243201/103/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030561(243201/103/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030562(243201/103/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030563(243201/103/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030564(243201/103/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030565(243201/103/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030566(243201/103/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030567(243201/103/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030568(243201/103/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030569(243201/103/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030570(243201/103/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030571(243201/103/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030572(243201/103/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030573(243201/103/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030574(243201/103/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030575(243201/103/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030576(243201/103/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030577(243201/103/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030578(243201/103/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030579(243201/103/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030580(243201/103/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030581(243201/103/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030582(243201/103/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030583(243201/103/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030584(243201/103/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030585(243201/103/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030586(243201/103/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030587(243201/103/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030588(243201/103/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030589(243201/103/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030590(243201/103/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030591(243201/103/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030592(243201/103/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030593(243201/103/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030594(243201/103/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030595(243201/103/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030596(243201/103/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030597(243201/103/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030598(243201/103/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030599(243201/103/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030600(243201/103/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030601(243201/103/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030602(243201/103/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030603(243201/103/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030604(243201/103/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030605(243201/103/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030606(243201/103/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030607(243201/103/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030608(243201/103/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030609(243201/103/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030610(243201/103/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030611(243201/103/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030612(243201/103/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030613(243201/103/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030614(243201/103/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030615(243201/103/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030616(243201/103/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030617(243201/104/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030618(243201/104/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030619(243201/104/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030620(243201/104/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030621(243201/104/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030622(243201/104/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030623(243201/104/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030624(243201/104/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030625(243201/104/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030626(243201/104/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030627(243201/104/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030628(243201/104/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030629(243201/104/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030630(243201/104/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030631(243201/104/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030632(243201/104/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030633(243201/104/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030634(243201/104/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030635(243201/104/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030636(243201/104/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030637(243201/104/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030638(243201/104/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030639(243201/104/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030640(243201/104/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030641(243201/104/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030642(243201/104/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030643(243201/104/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030644(243201/104/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030645(243201/104/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030646(243201/104/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030647(243201/104/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030648(243201/104/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030649(243201/104/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030650(243201/104/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030651(243201/104/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030652(243201/104/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030653(243201/104/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030654(243201/104/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030655(243201/104/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030657(243201/104/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030658(243201/104/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030659(243201/104/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030660(243201/104/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030661(243201/104/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030662(243201/104/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030663(243201/104/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030664(243201/104/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030665(243201/104/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030666(243201/104/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030667(243201/104/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030668(243201/104/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030669(243201/104/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030670(243201/104/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030671(243201/104/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030672(243201/104/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030673(243201/104/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030674(243201/104/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030675(243201/104/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030676(243201/104/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030677(243201/104/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030678(243201/104/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030679(243201/104/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030680(243201/105/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030681(243201/105/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030682(243201/105/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030683(243201/105/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030684(243201/105/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030685(243201/105/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030686(243201/105/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030687(243201/105/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030688(243201/105/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030689(243201/105/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030690(243201/105/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030691(243201/105/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030692(243201/105/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030693(243201/105/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030694(243201/105/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030695(243201/105/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030696(243201/105/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030697(243201/105/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030698(243201/105/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030699(243201/105/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030700(243201/105/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030701(243201/105/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030702(243201/105/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030703(243201/105/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030704(243201/105/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030705(243201/105/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030706(243201/105/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030707(243201/105/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030708(243201/105/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030709(243201/105/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030710(243201/105/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030711(243201/105/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030712(243201/105/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030713(243201/105/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030714(243201/105/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030715(243201/105/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030716(243201/105/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030717(243201/105/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030718(243201/105/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030719(243201/105/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030720(243201/105/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030721(243201/105/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030722(243201/105/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030723(243201/105/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030724(243201/105/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030725(243201/105/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030726(243201/105/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030727(243201/105/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030728(243201/105/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030729(243201/105/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030730(243201/105/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030731(243201/105/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030732(243201/105/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030733(243201/105/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030734(243201/105/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030735(243201/105/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030736(243201/105/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030737(243201/105/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030738(243201/105/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030739(243201/105/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030740(243201/105/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030741(243201/105/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030742(243201/105/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030743(243201/106/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030744(243201/106/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030745(243201/106/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030746(243201/106/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030747(243201/106/5)) lseek err Invalid argument
janoatthe
Re: WD20EARS partition problems
#18 Post by janoatthe »
file_pread(8,1,buffer,3907030748(243201/106/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030749(243201/106/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030750(243201/106/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030751(243201/106/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030752(243201/106/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030753(243201/106/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030754(243201/106/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030755(243201/106/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030756(243201/106/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030757(243201/106/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030758(243201/106/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030759(243201/106/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030760(243201/106/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030761(243201/106/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030762(243201/106/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030763(243201/106/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030764(243201/106/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030765(243201/106/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030766(243201/106/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030767(243201/106/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030768(243201/106/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030769(243201/106/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030770(243201/106/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030771(243201/106/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030772(243201/106/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030773(243201/106/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030774(243201/106/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030775(243201/106/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030776(243201/106/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030777(243201/106/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030778(243201/106/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030779(243201/106/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030780(243201/106/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030781(243201/106/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030782(243201/106/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030783(243201/106/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030785(243201/106/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030786(243201/106/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030787(243201/106/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030788(243201/106/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030789(243201/106/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030790(243201/106/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030791(243201/106/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030792(243201/106/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030793(243201/106/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030794(243201/106/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030795(243201/106/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030796(243201/106/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030797(243201/106/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030798(243201/106/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030799(243201/106/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030800(243201/106/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030801(243201/106/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030802(243201/106/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030803(243201/106/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030804(243201/106/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030805(243201/106/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030806(243201/107/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030807(243201/107/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030808(243201/107/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030809(243201/107/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030810(243201/107/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030811(243201/107/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030812(243201/107/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030813(243201/107/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030814(243201/107/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030815(243201/107/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030816(243201/107/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030817(243201/107/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030818(243201/107/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030819(243201/107/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030820(243201/107/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030821(243201/107/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030822(243201/107/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030823(243201/107/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030824(243201/107/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030825(243201/107/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030826(243201/107/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030827(243201/107/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030828(243201/107/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030829(243201/107/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030830(243201/107/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030831(243201/107/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030832(243201/107/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030833(243201/107/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030834(243201/107/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030835(243201/107/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030836(243201/107/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030837(243201/107/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030838(243201/107/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030839(243201/107/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030840(243201/107/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030841(243201/107/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030842(243201/107/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030843(243201/107/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030844(243201/107/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030845(243201/107/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030846(243201/107/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030847(243201/107/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030848(243201/107/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030849(243201/107/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030850(243201/107/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030851(243201/107/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030852(243201/107/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030853(243201/107/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030854(243201/107/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030855(243201/107/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030856(243201/107/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030857(243201/107/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030858(243201/107/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030859(243201/107/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030860(243201/107/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030861(243201/107/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030862(243201/107/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030863(243201/107/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030864(243201/107/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030865(243201/107/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030866(243201/107/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030867(243201/107/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030868(243201/107/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030869(243201/108/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030870(243201/108/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030871(243201/108/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030872(243201/108/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030873(243201/108/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030874(243201/108/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030875(243201/108/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030876(243201/108/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030877(243201/108/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030878(243201/108/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030879(243201/108/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030880(243201/108/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030881(243201/108/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030882(243201/108/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030883(243201/108/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030884(243201/108/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030885(243201/108/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030886(243201/108/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030887(243201/108/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030888(243201/108/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030889(243201/108/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030890(243201/108/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030891(243201/108/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030892(243201/108/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030893(243201/108/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030894(243201/108/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030895(243201/108/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030896(243201/108/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030897(243201/108/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030898(243201/108/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030899(243201/108/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030900(243201/108/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030901(243201/108/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030902(243201/108/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030903(243201/108/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030904(243201/108/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030905(243201/108/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030906(243201/108/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030907(243201/108/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030908(243201/108/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030909(243201/108/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030910(243201/108/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030911(243201/108/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030912(243201/108/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030913(243201/108/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030914(243201/108/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030915(243201/108/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030916(243201/108/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030917(243201/108/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030918(243201/108/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030919(243201/108/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030920(243201/108/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030921(243201/108/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030922(243201/108/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030923(243201/108/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030924(243201/108/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030925(243201/108/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030926(243201/108/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030927(243201/108/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030928(243201/108/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030929(243201/108/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030930(243201/108/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030931(243201/108/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030932(243201/109/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030933(243201/109/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030934(243201/109/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030935(243201/109/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030936(243201/109/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907030937(243201/109/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907030938(243201/109/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907030939(243201/109/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907030940(243201/109/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907030941(243201/109/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907030942(243201/109/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907030943(243201/109/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907030944(243201/109/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907030945(243201/109/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907030946(243201/109/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907030947(243201/109/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907030948(243201/109/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907030949(243201/109/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907030950(243201/109/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907030951(243201/109/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907030952(243201/109/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907030953(243201/109/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907030954(243201/109/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907030955(243201/109/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907030956(243201/109/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907030957(243201/109/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907030958(243201/109/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907030959(243201/109/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907030960(243201/109/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907030961(243201/109/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907030962(243201/109/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907030963(243201/109/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907030964(243201/109/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907030965(243201/109/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907030966(243201/109/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907030967(243201/109/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907030968(243201/109/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907030969(243201/109/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907030970(243201/109/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907030971(243201/109/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907030972(243201/109/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907030973(243201/109/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907030974(243201/109/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907030975(243201/109/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907030976(243201/109/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907030977(243201/109/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907030978(243201/109/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907030979(243201/109/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907030980(243201/109/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907030981(243201/109/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907030982(243201/109/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907030983(243201/109/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907030984(243201/109/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907030985(243201/109/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907030986(243201/109/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907030987(243201/109/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907030988(243201/109/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907030989(243201/109/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907030990(243201/109/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907030991(243201/109/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907030992(243201/109/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907030993(243201/109/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907030994(243201/109/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907030995(243201/110/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907030996(243201/110/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907030997(243201/110/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907030998(243201/110/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907030999(243201/110/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907031000(243201/110/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907031001(243201/110/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907031002(243201/110/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907031003(243201/110/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907031004(243201/110/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907031005(243201/110/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907031006(243201/110/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907031007(243201/110/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907031008(243201/110/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907031009(243201/110/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907031010(243201/110/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907031011(243201/110/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907031012(243201/110/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907031013(243201/110/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907031014(243201/110/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907031015(243201/110/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907031016(243201/110/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907031017(243201/110/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907031018(243201/110/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907031019(243201/110/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907031020(243201/110/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907031021(243201/110/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907031022(243201/110/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907031023(243201/110/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907031024(243201/110/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907031025(243201/110/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907031026(243201/110/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907031027(243201/110/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907031028(243201/110/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907031029(243201/110/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907031030(243201/110/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907031031(243201/110/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907031032(243201/110/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907031033(243201/110/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907031034(243201/110/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907031035(243201/110/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907031036(243201/110/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907031037(243201/110/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907031038(243201/110/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
NTFS at 243201/78/13
filesystem size 3906764800
mftmirr_lcn 2
MS Data 264192 3907028991 3906764800
NTFS found using backup sector, blocksize=4096, 2000 GB / 1862 GiB
mftmirr_lcn 2
file_pread(8,4096,buffer,3913320447(243592/237/37)) lseek err Invalid argument
file_pread(8,1,buffer,3913320447(243592/237/37)) lseek err Invalid argument
NTFS: Can't read MFT
MS Data 3907028991 7813793790 3906764800
NTFS, blocksize=4096, 2000 GB / 1862 GiB
This partition ends after the disk limits. (start=3907028991, size=3906764800, end=3518826494, disk end=3907040130)
file_pread(8,1,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907031042(243201/110/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907031043(243201/110/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907031044(243201/110/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907031045(243201/110/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907031046(243201/110/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907031047(243201/110/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907031049(243201/110/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907031050(243201/110/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907031051(243201/110/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907031052(243201/110/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907031053(243201/110/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907031054(243201/110/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907031055(243201/110/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907031057(243201/110/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907031058(243201/111/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907031059(243201/111/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907031060(243201/111/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907031061(243201/111/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907031062(243201/111/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907031063(243201/111/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907031064(243201/111/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907031065(243201/111/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907031066(243201/111/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907031067(243201/111/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907031068(243201/111/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907031069(243201/111/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907031070(243201/111/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907031071(243201/111/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907031072(243201/111/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907031073(243201/111/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907031074(243201/111/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907031075(243201/111/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907031076(243201/111/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907031077(243201/111/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907031078(243201/111/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907031079(243201/111/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907031080(243201/111/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029168(243201/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(8,1,buffer,3907031081(243201/111/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907031082(243201/111/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907031083(243201/111/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907029171(243201/81/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907031084(243201/111/27)) lseek err Invalid argument
file_pread(8,11,buffer,3907029162(243201/80/58)) ReadFile The semaphore timeout period has expired.
file_pread(8,1,buffer,3907031085(243201/111/28)) lseek err Invalid argument
file_pread(8,5,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907031086(243201/111/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029174(243201/81/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907031087(243201/111/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029175(243201/81/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907031088(243201/111/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907031089(243201/111/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029177(243201/81/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907031090(243201/111/33)) lseek err Invalid argument
file_pread(8,11,buffer,3907029168(243201/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(8,1,buffer,3907031091(243201/111/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029179(243201/81/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907031092(243201/111/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907029180(243201/81/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907031093(243201/111/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029181(243201/81/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907031094(243201/111/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029182(243201/81/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907031095(243201/111/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029183(243201/81/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907031096(243201/111/39)) lseek err Invalid argument
file_pread(8,11,buffer,3907029174(243201/81/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907031097(243201/111/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029185(243201/81/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907031098(243201/111/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029186(243201/81/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907031099(243201/111/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029187(243201/81/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907031100(243201/111/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029188(243201/81/21)) lseek err Invalid argument
file_pread(8,1,buffer,3907031101(243201/111/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029189(243201/81/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907031102(243201/111/45)) lseek err Invalid argument
file_pread(8,11,buffer,3907029180(243201/81/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029191(243201/81/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907031104(243201/111/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029192(243201/81/25)) lseek err Invalid argument
file_pread(8,1,buffer,3907031105(243201/111/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029193(243201/81/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907031106(243201/111/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029194(243201/81/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907031107(243201/111/50)) lseek err Invalid argument
janoatthe
#19 Post by janoatthe »
_pread(8,1,buffer,3907029195(243201/81/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907031108(243201/111/51)) lseek err Invalid argument
file_pread(8,11,buffer,3907029186(243201/81/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907031109(243201/111/52)) lseek err Invalid argument
file_pread(8,11,buffer,3907029187(243201/81/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907031110(243201/111/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029198(243201/81/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907031111(243201/111/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029199(243201/81/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907031112(243201/111/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029200(243201/81/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907031113(243201/111/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029201(243201/81/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907031114(243201/111/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029202(243201/81/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907031115(243201/111/58)) lseek err Invalid argument
file_pread(8,11,buffer,3907029193(243201/81/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907031116(243201/111/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907029204(243201/81/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907031117(243201/111/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029205(243201/81/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907031118(243201/111/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029206(243201/81/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029207(243201/81/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907031120(243201/111/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029208(243201/81/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907031121(243201/112/1)) lseek err Invalid argument
file_pread(8,11,buffer,3907029199(243201/81/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907031122(243201/112/2)) lseek err Invalid argument
file_pread(8,11,buffer,3907029200(243201/81/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907031123(243201/112/3)) lseek err Invalid argument
file_pread(8,11,buffer,3907029201(243201/81/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907031124(243201/112/4)) lseek err Invalid argument
file_pread(8,11,buffer,3907029202(243201/81/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907031125(243201/112/5)) lseek err Invalid argument
file_pread(8,11,buffer,3907029203(243201/81/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029203(243201/81/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907031126(243201/112/6)) lseek err Invalid argument
file_pread(8,11,buffer,3907029204(243201/81/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907031127(243201/112/7)) lseek err Invalid argument
file_pread(8,11,buffer,3907029205(243201/81/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907031128(243201/112/8)) lseek err Invalid argument
file_pread(8,11,buffer,3907029206(243201/81/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907031129(243201/112/9)) lseek err Invalid argument
file_pread(8,11,buffer,3907029207(243201/81/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907031130(243201/112/10)) lseek err Invalid argument
file_pread(8,11,buffer,3907029208(243201/81/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907031131(243201/112/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029219(243201/81/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907031132(243201/112/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029220(243201/81/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907031133(243201/112/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029221(243201/81/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907031134(243201/112/14)) lseek err Invalid argument
file_pread(8,8,buffer,3907029165(243201/80/61)) ReadFile The semaphore timeout period has expired.
file_pread(8,11,buffer,3907029212(243201/81/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907031135(243201/112/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029223(243201/81/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907031136(243201/112/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907029224(243201/81/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907031137(243201/112/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029225(243201/81/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907031138(243201/112/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029226(243201/81/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907031139(243201/112/19)) lseek err Invalid argument
file_pread(8,8,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(8,11,buffer,3907029217(243201/81/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907031140(243201/112/20)) lseek err Invalid argument
file_pread(8,8,buffer,3907029171(243201/81/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029228(243201/81/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907031141(243201/112/21)) lseek err Invalid argument
file_pread(8,8,buffer,3907029172(243201/81/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029172(243201/81/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029229(243201/81/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907031142(243201/112/22)) lseek err Invalid argument
file_pread(8,8,buffer,3907029173(243201/81/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029173(243201/81/6)) lseek err Invalid argument
file_pread(8,11,buffer,3907029220(243201/81/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907031143(243201/112/23)) lseek err Invalid argument
file_pread(8,8,buffer,3907029174(243201/81/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907029231(243201/82/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907031144(243201/112/24)) lseek err Invalid argument
file_pread(8,8,buffer,3907029175(243201/81/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029232(243201/82/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907031145(243201/112/25)) lseek err Invalid argument
file_pread(8,8,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(8,11,buffer,3907029223(243201/81/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907031146(243201/112/26)) lseek err Invalid argument
file_pread(8,8,buffer,3907029177(243201/81/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907029234(243201/82/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907031147(243201/112/27)) lseek err Invalid argument
file_pread(8,8,buffer,3907029178(243201/81/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029178(243201/81/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029235(243201/82/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907031148(243201/112/28)) lseek err Invalid argument
file_pread(8,8,buffer,3907029179(243201/81/12)) lseek err Invalid argument
file_pread(8,11,buffer,3907029226(243201/81/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907031149(243201/112/29)) lseek err Invalid argument
file_pread(8,8,buffer,3907029180(243201/81/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029237(243201/82/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907031150(243201/112/30)) lseek err Invalid argument
file_pread(8,8,buffer,3907029181(243201/81/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029238(243201/82/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907031151(243201/112/31)) lseek err Invalid argument
file_pread(8,8,buffer,3907029182(243201/81/15)) lseek err Invalid argument
file_pread(8,11,buffer,3907029229(243201/81/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907031152(243201/112/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907029190(243201/81/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029240(243201/82/10)) lseek err Invalid argument
file_pread(8,1,buffer,3907031153(243201/112/33)) lseek err Invalid argument
file_pread(8,1,buffer,3907029241(243201/82/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907031154(243201/112/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907029242(243201/82/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907031155(243201/112/35)) lseek err Invalid argument
file_pread(8,8,buffer,3907029186(243201/81/19)) lseek err Invalid argument
file_pread(8,11,buffer,3907029233(243201/82/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907031156(243201/112/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907029244(243201/82/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907031157(243201/112/37)) lseek err Invalid argument
file_pread(8,1,buffer,3907029195(243201/81/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907029245(243201/82/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907031158(243201/112/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907029196(243201/81/29)) lseek err Invalid argument
file_pread(8,1,buffer,3907029246(243201/82/16)) lseek err Invalid argument
file_pread(8,1,buffer,3907031159(243201/112/39)) lseek err Invalid argument
file_pread(8,8,buffer,3907029190(243201/81/23)) lseek err Invalid argument
file_pread(8,11,buffer,3907029237(243201/82/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907031160(243201/112/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907031161(243201/112/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907029249(243201/82/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907031162(243201/112/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029250(243201/82/20)) lseek err Invalid argument
file_pread(8,1,buffer,3907031163(243201/112/43)) lseek err Invalid argument
file_pread(8,8,buffer,3907029194(243201/81/27)) lseek err Invalid argument
file_pread(8,11,buffer,3907029241(243201/82/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907031164(243201/112/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029252(243201/82/22)) lseek err Invalid argument
file_pread(8,1,buffer,3907031165(243201/112/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029253(243201/82/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907029254(243201/82/24)) lseek err Invalid argument
file_pread(8,1,buffer,3907031167(243201/112/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029184(243201/81/17)) lseek err Invalid argument
file_pread(8,8,buffer,3907029198(243201/81/31)) lseek err Invalid argument
file_pread(8,11,buffer,3907029245(243201/82/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907031168(243201/112/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029256(243201/82/26)) lseek err Invalid argument
file_pread(8,1,buffer,3907031169(243201/112/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029257(243201/82/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907031170(243201/112/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029258(243201/82/28)) lseek err Invalid argument
file_pread(8,1,buffer,3907031171(243201/112/51)) lseek err Invalid argument
file_pread(8,8,buffer,3907029202(243201/81/35)) lseek err Invalid argument
file_pread(8,11,buffer,3907029249(243201/82/19)) lseek err Invalid argument
file_pread(8,1,buffer,3907031172(243201/112/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907029210(243201/81/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907029260(243201/82/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907031173(243201/112/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907029211(243201/81/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907029261(243201/82/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907031174(243201/112/54)) lseek err Invalid argument
file_pread(8,1,buffer,3907029212(243201/81/45)) lseek err Invalid argument
file_pread(8,1,buffer,3907029262(243201/82/32)) lseek err Invalid argument
file_pread(8,1,buffer,3907031175(243201/112/55)) lseek err Invalid argument
file_pread(8,8,buffer,3907029206(243201/81/39)) lseek err Invalid argument
file_pread(8,11,buffer,3907029253(243201/82/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907031176(243201/112/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907029214(243201/81/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907029264(243201/82/34)) lseek err Invalid argument
file_pread(8,1,buffer,3907031177(243201/112/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907029215(243201/81/48)) lseek err Invalid argument
file_pread(8,1,buffer,3907029265(243201/82/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907031178(243201/112/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907029216(243201/81/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907029266(243201/82/36)) lseek err Invalid argument
file_pread(8,1,buffer,3907031179(243201/112/59)) lseek err Invalid argument
file_pread(8,8,buffer,3907029210(243201/81/43)) lseek err Invalid argument
file_pread(8,11,buffer,3907029257(243201/82/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907031180(243201/112/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029197(243201/81/30)) lseek err Invalid argument
file_pread(8,1,buffer,3907029218(243201/81/51)) lseek err Invalid argument
file_pread(8,1,buffer,3907029268(243201/82/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907031181(243201/112/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907029269(243201/82/39)) lseek err Invalid argument
file_pread(8,1,buffer,3907031182(243201/112/62)) lseek err Invalid argument
file_pread(8,1,buffer,3907029270(243201/82/40)) lseek err Invalid argument
file_pread(8,1,buffer,3907031183(243201/112/63)) lseek err Invalid argument
file_pread(8,8,buffer,3907029214(243201/81/47)) lseek err Invalid argument
file_pread(8,11,buffer,3907029261(243201/82/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907031184(243201/113/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907029222(243201/81/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907029272(243201/82/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907031185(243201/113/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029273(243201/82/43)) lseek err Invalid argument
file_pread(8,1,buffer,3907031186(243201/113/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029274(243201/82/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907031187(243201/113/4)) lseek err Invalid argument
file_pread(8,8,buffer,3907029218(243201/81/51)) lseek err Invalid argument
file_pread(8,11,buffer,3907029265(243201/82/35)) lseek err Invalid argument
file_pread(8,1,buffer,3907031188(243201/113/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907029276(243201/82/46)) lseek err Invalid argument
file_pread(8,1,buffer,3907031189(243201/113/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029227(243201/81/60)) lseek err Invalid argument
file_pread(8,1,buffer,3907029277(243201/82/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907031190(243201/113/7)) lseek err Invalid argument
file_pread(8,8,buffer,3907029221(243201/81/54)) lseek err Invalid argument
file_pread(8,11,buffer,3907029268(243201/82/38)) lseek err Invalid argument
file_pread(8,1,buffer,3907031191(243201/113/8)) lseek err Invalid argument
file_pread(8,1,buffer,3907029279(243201/82/49)) lseek err Invalid argument
file_pread(8,1,buffer,3907031192(243201/113/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029209(243201/81/42)) lseek err Invalid argument
file_pread(8,1,buffer,3907029230(243201/81/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907029280(243201/82/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907031193(243201/113/10)) lseek err Invalid argument
file_pread(8,8,buffer,3907029224(243201/81/57)) lseek err Invalid argument
file_pread(8,11,buffer,3907029271(243201/82/41)) lseek err Invalid argument
file_pread(8,1,buffer,3907031194(243201/113/11)) lseek err Invalid argument
file_pread(8,1,buffer,3907029282(243201/82/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907031195(243201/113/12)) lseek err Invalid argument
file_pread(8,1,buffer,3907029233(243201/82/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907029283(243201/82/53)) lseek err Invalid argument
file_pread(8,1,buffer,3907031196(243201/113/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029213(243201/81/46)) lseek err Invalid argument
file_pread(8,8,buffer,3907029227(243201/81/60)) lseek err Invalid argument
file_pread(8,11,buffer,3907029274(243201/82/44)) lseek err Invalid argument
file_pread(8,1,buffer,3907031197(243201/113/14)) lseek err Invalid argument
file_pread(8,1,buffer,3907029285(243201/82/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907031198(243201/113/15)) lseek err Invalid argument
file_pread(8,1,buffer,3907029236(243201/82/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029286(243201/82/56)) lseek err Invalid argument
file_pread(8,1,buffer,3907031199(243201/113/16)) lseek err Invalid argument
file_pread(8,8,buffer,3907029230(243201/81/63)) lseek err Invalid argument
file_pread(8,11,buffer,3907029277(243201/82/47)) lseek err Invalid argument
file_pread(8,1,buffer,3907031200(243201/113/17)) lseek err Invalid argument
file_pread(8,1,buffer,3907029217(243201/81/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907029288(243201/82/58)) lseek err Invalid argument
file_pread(8,1,buffer,3907031201(243201/113/18)) lseek err Invalid argument
file_pread(8,1,buffer,3907029239(243201/82/9)) lseek err Invalid argument
file_pread(8,1,buffer,3907029289(243201/82/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907031202(243201/113/19)) lseek err Invalid argument
file_pread(8,8,buffer,3907029162(243201/80/58)) ReadFile The semaphore timeout period has expired.
file_pread(8,3,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(8,3,buffer,3907029217(243201/81/50)) lseek err Invalid argument
file_pread(8,8,buffer,3907029233(243201/82/3)) lseek err Invalid argument
file_pread(8,11,buffer,3907029280(243201/82/50)) lseek err Invalid argument
file_pread(8,1,buffer,3907031203(243201/113/20)) lseek err Invalid argument
file_pread(8,3,buffer,3907029168(243201/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(8,3,buffer,3907029171(243201/81/4)) lseek err Invalid argument
file_pread(8,1,buffer,3907029291(243201/82/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907031204(243201/113/21)) lseek err Invalid argument
file_pread(8,8,buffer,3907029164(243201/80/60)) ReadFile The semaphore timeout period has expired.
file_pread(8,3,buffer,3907029219(243201/81/52)) lseek err Invalid argument
file_pread(8,8,buffer,3907029235(243201/82/5)) lseek err Invalid argument
file_pread(8,11,buffer,3907029282(243201/82/52)) lseek err Invalid argument
file_pread(8,1,buffer,3907031205(243201/113/22)) lseek err Invalid argument
file_pread(8,5,buffer,3907029168(243201/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(8,3,buffer,3907029173(243201/81/6)) lseek err Invalid argument
file_pread(8,1,buffer,3907029243(243201/82/13)) lseek err Invalid argument
file_pread(8,1,buffer,3907029293(243201/82/63)) lseek err Invalid argument
file_pread(8,1,buffer,3907031206(243201/113/23)) lseek err Invalid argument
file_pread(8,1,buffer,3907029294(243201/83/1)) lseek err Invalid argument
file_pread(8,1,buffer,3907031207(243201/113/24)) lseek err Invalid argument
file_pread(8,8,buffer,3907029167(243201/80/63)) ReadFile The semaphore timeout period has expired.
file_pread(8,3,buffer,3907029175(243201/81/8)) lseek err Invalid argument
file_pread(8,3,buffer,3907029222(243201/81/55)) lseek err Invalid argument
file_pread(8,8,buffer,3907029238(243201/82/8)) lseek err Invalid argument
file_pread(8,11,buffer,3907029285(243201/82/55)) lseek err Invalid argument
file_pread(8,1,buffer,3907031208(243201/113/25)) lseek err Invalid argument
file_pread(8,7,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029296(243201/83/3)) lseek err Invalid argument
file_pread(8,1,buffer,3907031209(243201/113/26)) lseek err Invalid argument
file_pread(8,6,buffer,3907029163(243201/80/59)) ReadFile The semaphore timeout period has expired.
file_pread(8,3,buffer,3907029177(243201/81/10)) lseek err Invalid argument
file_pread(8,3,buffer,3907029224(243201/81/57)) lseek err Invalid argument
file_pread(8,8,buffer,3907029240(243201/82/10)) lseek err Invalid argument
file_pread(8,11,buffer,3907029287(243201/82/57)) lseek err Invalid argument
file_pread(8,1,buffer,3907031210(243201/113/27)) lseek err Invalid argument
file_pread(8,1,buffer,3907029298(243201/83/5)) lseek err Invalid argument
file_pread(8,1,buffer,3907031211(243201/113/28)) lseek err Invalid argument
file_pread(8,6,buffer,3907029165(243201/80/61)) ReadFile The semaphore timeout period has expired.
file_pread(8,3,buffer,3907029179(243201/81/12)) lseek err Invalid argument
file_pread(8,3,buffer,3907029226(243201/81/59)) lseek err Invalid argument
file_pread(8,8,buffer,3907029242(243201/82/12)) lseek err Invalid argument
file_pread(8,11,buffer,3907029289(243201/82/59)) lseek err Invalid argument
file_pread(8,1,buffer,3907031212(243201/113/29)) lseek err Invalid argument
file_pread(8,3,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,3907029300(243201/83/7)) lseek err Invalid argument
file_pread(8,1,buffer,3907031213(243201/113/30)) lseek err Invalid argument
file_pread(8,6,buffer,3907029167(243201/80/63)) ReadFile The semaphore timeout period has expired.
file_pread(8,3,buffer,3907029181(243201/81/14)) lseek err Invalid argument
file_pread(8,3,buffer,3907029228(243201/81/61)) lseek err Invalid argument
file_pread(8,8,buffer,3907029244(243201/82/14)) lseek err Invalid argument
file_pread(8,11,buffer,3907029291(243201/82/61)) lseek err Invalid argument
file_pread(8,1,buffer,3907031214(243201/113/31)) lseek err Invalid argument
file_pread(8,1,buffer,3907029302(
janoatthe
#20 Post by janoatthe »
Hello Fiona
Sorry for the size of the log , I have left test disk running where I took the screen search.
Mike
