Problem with pendrive :(
Agusia
#1 Post by Agusia »
Hi All :)
I've got a problem with my pendrive. I've tried to use TestDisk, but I don't know how. I've made screenshots.
Please help me. :(
Re: Problem with pendrive :(
Especially the screen from Deeper Search was interesting.
http://i.imgur.com/527KN.jpg
Would it be possible to repeat Deeper Search and check each partition and press p to list your files?
Please let me know, did you see your files or an error message?
Also on which partition did you see your data?
Agusia
#3 Post by Agusia »
Hi, thanks for help. :)
With NTFS partition i get an error, with the second partition I get this:
#4 Post by Fiona »
A short explanation about your problem woud be appreciated.
How was your pen drive formatted?
FAT32 oder NTFS?
Agusia
#5 Post by Agusia »
I've been using it normally and after that, when I put it into the computer it only said that it has to be formatted.
I really don't know how it was formatted. :( I had there some space made for Xbox 360 saves.
#6 Post by Fiona »
How did you do this?
It's important to check, because I'll hope that you didn't overwrite something.
Normally pen drives are FAT32-formatted.
Currently you have a NTFS formatted drive.
Do you have some data on it?
Agusia
#7 Post by Agusia »
I've put it into the Xbox 360 and choose to make a part of it as a place for saves, the rest of the pendrive was normally for use. I've made it a long time ago, there were some hidden files from Xbox on it. The Xbox files aren't so important, I've to get back the normal files because I've had my school project there. :(
