is it possible to generate a log file only using a scripted run? I would like to create log files of several disks without having to copy everything to another drive first?
Richard
possible to generate log file only, without copying files?
Re: possible to generate log file only, without copying file
If you want a lidt of all the files of the first partition, you can use something like
testdisk /cmd /dev/sda advanced,1,list,recursiveRe: possible to generate log file only, without copying file
Thanks!
I tried your suggestion in testdisk and it worked. However, when I try it with photorec I only get an overview of the partitions, not the files.
I was hoping to get something like the photorec XML that describes the files with an offset and length, so that I can use something like dd to copy individual files. Is that possible?
best,
Richard
best,
Richard
PhotoRec 6.14, Data Recovery Utility, July 2013
OS: Darwin, kernel 14.0.0 (Darwin Kernel Version 14.0.0: Fri Sep 19 00:26:44 PDT 2014; root:xnu-2782.1
Compiler: GCC 4.2
Compilation date: 2014-11-19T17:26:05
ext2fs lib: none, ntfs lib: none, ewf lib: none, libjpeg: 80
Disk /dev/disk2 - 9064 KB / 8852 KiB - 17704 sectors (RO), sector size=512
Disk /dev/disk2 - 9064 KB / 8852 KiB (RO)
Partition table type: EFI GPT
Unknown 0 17703 17704 [Whole disk]
1 P MS Data 2048 10239 8192 [UNTITLED 1] [UNTITLED 1]
FAT12, blocksize=1024, 4194 KB / 4096 KiB
2 P MS Data 10240 16383 6144 [UNTITLED 2] [UNTITLED 2]
FAT12, blocksize=1024, 3145 KB / 3072 KiB
PhotoRec exited normally.- cgrenier
Currently it's not possible, it's something that will have to be implemented if you really need this feature.
Maybe http://www.sleuthkit.org/ , a free and open source forensics utility, will provide the feature you are looking for.
