I'm still in a bit of shock. On friday three SATA drives stopped working at the same time. When I came home the PC was still running but the screen was black and unresponsive. Did a hard reboot and then it got stuck at POST. Turned out only 2 of 5 drives were working.
I'm still going through them one by one. One isn't even detected by BIOS, or parted magic or anything. But one is being listed in BIOS, I can see it in Parted Magic, HDD health should be good according to SMART data, TestDrive finds a partition and all my files are still on it. I can browse through it.
My question is, what can I expect from this drive that works? Can I expect to be able to save all the data? I'm too afraid to do anything on my own just yet so I don't make anything worse. Is it possible that I will never be able to get my data back despite being able to see everything just sitting there?
Thanks.
SATA system damaged, what to expect?
Re: SATA system damaged, what to expect?
The topic has been approved but unfortunately won't do any good. I've found out that none of the damaged drives will spin. Probably a fried PCB on all three.
Still wondering how TestDisk was able to browse through all the folders without the head spinning.
