Recover files of Formatted External WD
Config
#1 Post by Config »
Hello people,
I am trying to recover all files (documents, images, other extentions) from my external Western Digital harddrive that I´ve formatted. Since then I didn't do anything with the WD, so the files are hopefully retraceble. First question; should I use TestDisk or PhotoRec? At this moment I used TestDisk.
The Steps I took:
  1. Create now log file
  • Choose Disk /dev/sdf -320/298GiB - WD External
  • Choose Intel
  • Choose Analyse
(status: Bad sector count. No partition is bootable)
  • Choose Quick Search
  • Choose HPFS NTFS
(only option)
  • Choose Deeper Search
(status: Analyzing cylinder.. x / 38912)
At this moment I got the following announcement;
Disk /dev/sdf - 320 GB / 298 GiB - CHS 38913 255 63
The harddisk (320 GB / 298 GiB) seems too small! (< 640 GB / 596 GiB)
HPFS - NTFS 38912 254 63 77825 253 62 625137282
NTFS, blocksize=4096, 320 GB / 298 GiB
  • Does this means that there are more files found than my WD can store?
    How can I store all the files? (because I want to make sure I don't skip important files)
    Does TestDrive store the files directly on my WD or can I choose a location on my computer?
Is TestDisk the solution for my problem and how should I continue?
Full TestDisk.log (some lines strangly in Dutch)
Sat Dec  6 18:40:11 2014
OS: Windows XP SP3
Compilation date: 2014-11-13T18:59:50
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=320072933376
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Onjuiste functie.
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Onjuiste functie.
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Onjuiste functie.
filewin32_getfilesize(\\.\PhysicalDrive4) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\PhysicalDrive4) SetFilePointer err Onjuiste functie.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=72529551360
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=7485940224
filewin32_getfilesize(\\.\E:) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Onjuiste functie.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=211392512
filewin32_getfilesize(\\.\G:) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Onjuiste functie.
filewin32_getfilesize(\\.\H:) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Onjuiste functie.
filewin32_getfilesize(\\.\I:) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Onjuiste functie.
filewin32_getfilesize(\\.\J:) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Onjuiste functie.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=320070288384
Disk /dev/sda - 80 GB / 74 GiB - CHS 10337 240 63, sector size=512 - ST380011A, S/N:4a354b5648474246202020202020202020202020, FW:8.11
Disk /dev/sdf - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WD 3200BMV External, FW:1.05
Drive F: - 211 MB / 201 MiB - CHS 50 64 32, sector size=2048 - IDE-CD R/RW 48xC, FW:RW07
Disk /dev/sdf - 320 GB / 298 GiB - WD 3200BMV External
Analyse Disk /dev/sdf - 320 GB / 298 GiB - CHS 38913 255 63
NTFS at 0/1/1
 1 P HPFS - NTFS              0   1  1 38912 254 63  625137282
Bad sector count.
NTFS at 0/1/1
filesystem size           625137282
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
file_pread(5,2,buffer,625143808(38913/102/38)) lseek err Invalid argument
file_pread(5,1,buffer,625143808(38913/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,625142463(38913/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,625142463(38913/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,625142591(38913/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,625142719(38913/85/20)) lseek err Invalid argument
file_pread(5,8,buffer,625142847(38913/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,625142975(38913/89/24)) lseek err Invalid argument
file_pread(5,8,buffer,625143103(38913/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,625143231(38913/93/28)) lseek err Invalid argument
file_pread(5,8,buffer,625143359(38913/95/30)) lseek err Invalid argument
file_pread(5,8,buffer,625143487(38913/97/32)) lseek err Invalid argument
file_pread(5,8,buffer,625143615(38913/99/34)) lseek err Invalid argument
file_pread(5,8,buffer,625143743(38913/101/36)) lseek err Invalid argument
file_pread(5,1,buffer,625143807(38913/102/37)) lseek err Invalid argument
file_pread(5,14,buffer,625143809(38913/102/39)) lseek err Invalid argument
file_pread(5,3,buffer,625143823(38913/102/53)) lseek err Invalid argument
file_pread(5,3,buffer,625143870(38913/103/37)) lseek err Invalid argument
file_pread(5,8,buffer,625143886(38913/103/53)) lseek err Invalid argument
file_pread(5,11,buffer,625143933(38913/104/37)) lseek err Invalid argument
file_pread(5,2,buffer,625145855(38913/135/6)) lseek err Invalid argument
   * HPFS - NTFS              0   1  1 38912 254 63  625137282
 1 * HPFS - NTFS              0   1  1 38912 254 63  625137282
NTFS at 0/1/1
mftmirr_lcn               2
file_pread(5,16,buffer,69517209(4327/62/49)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,69521424(4327/129/43)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484299318(30146/60/49)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484321406(30147/156/24)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484321414(30147/156/32)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484325502(30147/221/25)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484327487(30147/252/57)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484327503(30147/253/10)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484327508(30147/253/15)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484329488(30148/29/42)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484329488(30148/29/42)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484331448(30148/60/49)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484333584(30148/94/43)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484344644(30149/15/15)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484360772(30150/16/15)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484375941(30151/2/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484377926(30151/33/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484393086(30152/19/10)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484393090(30152/19/14)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484401152(30152/147/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484401152(30152/147/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484401153(30152/147/13)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484401154(30152/147/14)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484401164(30152/147/24)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484408071(30153/2/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484408087(30153/2/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484408094(30153/2/24)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484408077(30153/2/7)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484889958(30183/1/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484891943(30183/32/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484891944(30183/32/34)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,13,buffer,484889961(30183/1/4)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484900990(30183/176/8)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,484900996(30183/176/14)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,484906086(30184/2/1)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,484906102(30184/2/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484908071(30184/33/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484906092(30184/2/7)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,484907087(30184/17/57)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484907090(30184/17/60)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,484909056(30184/49/10)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,484909055(30184/49/9)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484909058(30184/49/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484909070(30184/49/24)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,484909072(30184/49/26)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484909062(30184/49/16)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,484937400(30185/244/4)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484972670(30188/38/57)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484972672(30188/38/59)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484974655(30188/70/26)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484976640(30188/101/58)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484976639(30188/101/57)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484976642(30188/101/60)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484976644(30188/101/62)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484980736(30188/166/59)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484980735(30188/166/58)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484980738(30188/166/61)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,484980746(30188/167/6)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,484980752(30188/167/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485482559(30219/227/24)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485507198(30221/108/30)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485509136(30221/139/15)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485533775(30223/20/21)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485580000(30225/244/4)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485586944(30226/99/18)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,485586945(30226/99/19)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485596754(30226/254/63)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485596755(30227/0/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485596756(30227/0/2)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,485596759(30227/0/5)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485596771(30227/0/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,485596771(30227/0/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485596761(30227/0/7)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,485611583(30227/235/24)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,485611584(30227/235/25)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,486113359(30259/40/5)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,486117392(30259/104/6)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,486117392(30259/104/6)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,486142031(30260/240/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,486142031(30260/240/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,486146856(30261/61/49)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,486168592(30262/151/50)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,486191302(30264/2/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,486191309(30264/2/24)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,486193231(30264/32/56)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487254016(30330/40/47)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487254015(30330/40/46)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487254018(30330/40/49)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,487254025(30330/40/56)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487278655(30331/176/53)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487303294(30333/57/59)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,487303303(30333/58/5)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487305231(30333/88/43)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487305232(30333/88/44)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487329871(30334/224/50)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,487329877(30334/224/56)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487913472(30371/53/19)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487913471(30371/53/18)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487913474(30371/53/21)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,487913484(30371/53/31)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487928291(30372/33/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487938111(30372/189/25)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487962750(30374/70/31)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487964688(30374/101/16)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,487974517(30375/2/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,487974522(30375/2/22)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489611327(30476/228/24)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489631118(30478/32/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489630155(30478/17/15)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489635966(30478/109/30)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,489635970(30478/109/34)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489666560(30480/85/6)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489666559(30480/85/5)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489666562(30480/85/8)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,489666565(30480/85/11)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489677344(30481/1/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489691199(30481/221/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,489697158(30482/60/49)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,489697159(30482/60/50)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490207248(30513/252/28)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490231887(30515/133/34)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490235920(30515/197/35)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,490235921(30515/197/36)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490260559(30517/78/41)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,490260560(30517/78/42)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490287120(30518/245/16)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490303879(30520/1/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,490303882(30520/1/20)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490311759(30520/126/22)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490819928(30552/32/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490818965(30552/17/15)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490854400(30554/69/44)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490854399(30554/69/43)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490854402(30554/69/46)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,490854404(30554/69/48)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490879039(30555/205/50)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490903678(30557/86/56)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,490903682(30557/86/60)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490905615(30557/117/40)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,490905616(30557/117/41)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,490905617(30557/117/42)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,491492689(30594/1/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,491492689(30594/1/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,491499599(30594/110/60)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,492013694(30626/111/12)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,492015632(30626/141/60)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,492040271(30628/23/3)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,492095504(30631/134/48)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,497227125(30950/244/4)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497234046(30951/98/58)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497234050(30951/98/62)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497235983(30951/129/42)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497235984(30951/129/43)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497235985(30951/129/44)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497244839(30952/15/15)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497260623(30953/10/49)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497260624(30953/10/50)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497287168(30954/177/8)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497287167(30954/177/7)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497287170(30954/177/10)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497287177(30954/177/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,497287184(30954/177/24)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497292154(30955/1/17)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497296029(30955/62/49)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497311807(30956/58/14)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497311823(30956/58/30)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497315856(30956/122/31)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,497315857(30956/122/32)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497340495(30958/3/37)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497340496(30958/3/38)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497813630(30987/118/42)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497815568(30987/149/27)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497821530(30987/244/4)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497838284(30988/254/63)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,497838284(30988/254/63)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,497838286(30989/0/2)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497838294(30989/0/10)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497839244(30989/15/15)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497840207(30989/30/33)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497844224(30989/94/18)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497844223(30989/94/17)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497844226(30989/94/20)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497844238(30989/94/32)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497844240(30989/94/34)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,497844240(30989/94/34)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,497868863(30990/230/24)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497868879(30990/230/40)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,497868879(30990/230/40)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,497888528(30992/32/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,497888528(30992/32/33)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497887565(30992/17/15)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497890434(30992/62/49)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497891407(30992/78/14)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497891409(30992/78/16)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497893502(30992/111/30)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497895424(30992/141/62)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497895423(30992/141/61)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497895442(30992/142/17)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497920063(30994/23/5)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,497920079(30994/23/21)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497944702(30995/159/11)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,497944708(30995/159/17)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497946639(30995/189/58)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,497946640(30995/189/59)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,498407487(31024/109/61)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,498407503(31024/110/14)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,1,buffer,498407503(31024/110/14)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,498421760(31025/81/33)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,498421759(31025/81/32)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,498421762(31025/81/35)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,498421771(31025/81/44)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,4,buffer,498421772(31025/81/45)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,498472960(31028/129/14)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,498472959(31028/129/13)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,498472962(31028/129/16)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,498472969(31028/129/23)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,6,buffer,498472970(31028/129/24)) ReadFile Gegevensfout (cyclische redundantiecontrole)
file_pread(5,16,buffer,498485374(31029/71/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,498485375(31029/71/18)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,498499647(31030/42/52)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,498499648(31030/42/53)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499036286(31063/145/57)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,499036287(31063/145/58)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499050559(31064/117/29)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499064832(31065/89/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499064831(31065/88/63)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499064834(31065/89/3)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,499064835(31065/89/4)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499089487(31066/225/23)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499091354(31066/254/63)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499091355(31067/0/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499091356(31067/0/2)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,499091359(31067/0/5)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,8,buffer,499091363(31067/0/9)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499091361(31067/0/7)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,499101759(31067/165/10)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500744191(31169/225/32)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,500744191(31169/225/32)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500746049(31169/254/63)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500746050(31170/0/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500746051(31170/0/2)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,500746056(31170/0/7)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500762178(31171/1/1)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500762181(31171/1/4)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,500762190(31171/1/13)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500768847(31171/106/55)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500778322(31172/2/17)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,500778325(31172/2/20)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500783120(31172/78/27)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500795391(31173/18/13)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,1,buffer,500795391(31173/18/13)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500820047(31174/154/36)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
file_pread(5,16,buffer,500834320(31175/126/8)) ReadFile Kan de opdracht niet uitvoeren door een fout in een I/O-apparaat.
NTFS at 38912/254/63
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 320 GB / 298 GiB
mftmirr_lcn               2
file_pread(5,1024,buffer,631431872(39304/208/9)) lseek err Invalid argument
file_pread(5,1,buffer,631431872(39304/208/9)) lseek err Invalid argument
NTFS: Can't read MFT
This partition ends after the disk limits. (start=625137344, size=625137282, end=1250274625, disk end=625142448)
Thanks!
Re: Recover files of Formatted External WD
Run TestDisk, Analyse, Quick Search, choose Stop, Deeper Search, your partition will be found at the very end, set the partition to P(rimary), choose Write, confirm, BackupBS, confirm, Quit.
Config
#3 Post by Config »
Thanks for your quick reply! Are the files being restored on my external WD or on my HDD?
