What does this mean, and what should I do?
barryjo
#1 Post by barryjo »
I have a 2TB disk that used to be visible. Now it is not. I think my data is there.
When I started after ANALYZE I got the following ...
D Linux and numbers followed
D Linux Raid and numbers followed
Then I fiddled with Testdisk and now I get, after selecting ANALYZE.....
(I think I tried to change the partition format hoping it would help)
Invalid NTSF or EXPAT boot
1 * HPSF - NTSF 0 0 2 243152 20360 3906249728
Can this be fixed?
What should I do now?
Thanks
Re: What does this mean, and what should I do?
Your message means either your bootsector is damaged or your partition table doesn't fit?
Please run Analyse, Quick Search and if no partition is found, Deeper Search also.
You'll find a testdisk.log within your testdisk folder.
Please open it using a wordprocessor like wordpad and copy and paste the content of your testdisk.log into your next post.
barryjo
#3 Post by barryjo »
I did as requested, and here is the log.
At the end of ANALYZE the screen showed the following but this is not in the log file.
D Linux 0 0 2 243152 203 60 3906249728
D Linux Raid 0 0 2 243152 208 1 3906249984
Thu Dec 11 13:26:16 2014
OS: Windows XP SP3
Compilation date: 2014-11-13T18:59:50
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=757499060224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=742694846464
Disk /dev/sda - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - SAMSUNG HD154UI, FW:1AG0
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - KWI TECH EZD-2536U3-USB-3, FW:CC32
Disk /dev/sdb - 2000 GB / 1863 GiB - KWI TECH EZD-2536U3-USB-3
1 * HPFS - NTFS 0 0 2 243152 203 60 3906249728
ntfs_boot_sector
filesystem size 18284465345357575337 1
sectors_per_cluster 26 0
mft_lcn 0 0
mftmirr_lcn 0 0
clusters_per_mft_record 0 0
clusters_per_index_record 0 0
Status: Bad
Status: Bad
Sectors are not identical.
barryjo
#4 Post by barryjo »
I am still hoping that someone would give me some advice here. I hesitate to go making changes by myself for fear I will accidentally erase my data.
