I use Linux Mint or Ubuntu and I installed Testdisk using:
sudo apt-get install testdiskhttp://www.cgsecurity.org/wiki/PhotoRec_Step_By_Step
it states that under Unix/Linux/BSD, you need to be root to run PhotoRec:
i.e.
sudo testdisk-6.13/photorec_staticThis did not work and it took me a little while to realise that I should have simply used:
sudo photorec Thanks for two great programs.
