Partition table mismatch External drive 1TB-WD10 Topic is solved
europanorama
#1 Post by europanorama »
Thu Dec 18 09:05:23 2014
OS: Windows XP SP3
Compilation date: 2014-11-13T18:59:50
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Unzulässige Funktion.
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=38724585984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=51457319424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=409915054080
filewin32_getfilesize(\\.\M:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\M:) SetFilePointer err Unzulässige Funktion.
Warning: can't get size for \\.\M:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=1000200994816
filewin32_getfilesize(\\.\Q:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\Q:) SetFilePointer err Unzulässige Funktion.
Warning: can't get size for \\.\Q:
filewin32_getfilesize(\\.\T:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\T:) SetFilePointer err Unzulässige Funktion.
Warning: can't get size for \\.\T:
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - SATA WDC WD50
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - SATA WDC WD10
Disk /dev/sdb - 1000 GB / 931 GiB - SATA WDC WD10
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 121600 247 55 1953517568
NTFS at 0/32/33
filesystem size 1953517568
mftmirr_lcn 122094847
NTFS at 121600/254/63
HPFS - NTFS 0 39 41 121600 254 63 1953517568
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
file_pread(5,1024,buffer,1959814592(121992/208/9)) lseek err Invalid argument
file_pread(5,1,buffer,1959814592(121992/208/9)) lseek err Invalid argument
NTFS: Can't read MFT
HPFS - NTFS 121600 254 63 243201 215 22 1953517568
This partition ends after the disk limits. (start=1953520064, size=1953517568, end=3907037631, disk end=1953525168)
file_pread(5,8,buffer,1953525185(121601/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525185(121601/81/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525313(121601/83/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525441(121601/85/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525569(121601/87/24)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,1953525697(121601/89/26)) lseek err Invalid argument
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 2000 GB / 1863 GiB)
This partitiontable shows data but not the other one
what should be done? changing geometry pls explain the procedure. is there a manual for that?
I changed the first one to P and tried to write and reboot, did not work. i simply dont understand what must be done.
btw: desaster began when i forgot to switch docking-station form usb to esata(orico 6515 series) after cloning a different drive which has overlapping problem on first and second partition.
so i had external drive on usb3.0(pc has usb 2.0 only). when i saw no data later i panicked attached it accidentally as first drive(both sata-cables have same color....) could have used the third slower channel.. so autochk(run almost 2hrs) messed up partition table.
pls fiona delete or dont start my german thread. i will stay here.
Re: Partition table mismatch External drive 1TB-WD10
The partition table contains a single NTFS partition that match the disk size.
Run Testdisk, Advanced, select the NTFS partition, choose Boot, RebuildBS, List.
If you see your files, choose Write, confirm, Quit
europanorama
#3 Post by europanorama »
After listing the files i dont see "Write".
used dos-version. drive attached as usb. as sata(second channel) did not work. cannot go through recognition on P4.
Will now try from hirens boot-cd.
How about offering an iso to create boot-cd?
europanorama
#4 Post by europanorama »
I tried everything, change external case, from docking-station to enclosure. maybe i must use simple usb-sata-adapter?
Tried to write after going back from listing to analyze etc. NOTHING HELPED.
Instructions are unclear. there is no write after listing data.
What will be done with this writing? writing partition table?
maybe i can use a different tool.
Thank you very much for clarifications. i have been spending almost 2 months with this an my other two-booting-drives. one is a clone. people from sysopt.com forum could not help
europanorama
#5 Post by europanorama »
Christophe, what must be done?
Have now a cloned drive.
Have another systemdrive(winxp) with messed up partition table on partition D. Drive is booting correctly.
will clone that too.
Thank you very much.
europanorama
#6 Post by europanorama »
your instruction:
"The partition table contains a single NTFS partition that match the disk size.
If you see your files, choose Write, confirm, Quit"
If i see three partitions all marked D(deleted) what must be done then with them
mark the one with folders as P-primary? what next, display files with p?
I think my clone is now messed up all over, will do a new clean one.
europanorama
#7 Post by europanorama »
I see testdisk version 6.14 on your site but i have found version 7.0 and i am puzzled. which one should i use?
europanorama
#8 Post by europanorama »
Does this instruction referr to a bootdrive or also external-drive without GPT like mine?
- i will now go through all instructions here:
http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
Sorry if i have confused you.
I not only switched the drives but changings were also made on clone using both tools...
its about WD10EZRX(clone)
europanorama
#9 Post by europanorama »
Did a fresh scan in windows with newest testdisk 7.0
Did what was in the instructions plus what you have told. boot, rebuildbs, List
" If you see your files, choose write, confirm, Quit
After seeing the files here too.
i dont see confirm only quit.
here you can see:
#10 Post by Fiona »
If you cannot run a diagnose under windows, you can you use a Live-CD like Knoppix?
DOS doesn't support long file names, NTFS support to copy data etc..
Might be possible that you get better results!
Knoppix already contain testdisk.
Open the start menu, select Knoppix and root terminal.
Type in su testdisk and repeat your diagnose!
