How to fetch data out of dumped .diskimage and .dss files?
amar
#1 Post by amar »
I ran photorec on my OSX drive and I ended up with four files:
[*]f53789331.diskimage (59.8GB)
[*]f212235002.dss (11.8GB)
[*]report.xml (2.6kB)
[*]f169876700.mp3 (2.6 kB)
in a directory named recup_dir.1.
I had ran photorec on my main disk as I had mistakenly deleted a lot of data from my OSX user folder - including photos, videos, and other files.
Is there anyway I can salvage files from the files above mentioned?
I am linking report.xml - http://pastebin.com/cQ5kMqNa.
PS. To be honest I am not sure whether I had run photorec or testdisk. I had used one of the available tutorials. I had never used the software before that day.
Re: How to fetch data out of dumped .diskimage and .dss file
Have you enable data compression (available since Mac OS X Snow Leopard 10.6) or logical volume encryption (known as FileVault 2, available since Mac OS X Lion 10.7) ? It may explain why no valid files has been recovered (3 false positives).
amar
#3 Post by amar »
cgrenier wrote: FileVault .
Yes, I had enabled FireVault (the disk encryption). So, there is no way to get the data back?
I am not sure but how does it work? I mean when I ran the program I was logged into the system and hence the disks were decrypted.
