testdisk can see my partitions but cannot recover them all
boranblok
#1 Post by boranblok »
Hi, my NAS got a corrupted partition table yesterday (I don't know the cause)
Now I run testdisk and I get this in the first analyze step:
However when I run quick scan it clearly sees my partitions:
    Disk /dev/sdf - 15 GB / 14 GiB - CHS 15072 64 32
    >  Linux                    0  63 31   243  63 30     497664
       Linux                    1   0  1 15070  63 32   30863360
         Enter: to continue
    ext2 blocksize=1024 Sparse superblock Backup superblock, 254 MB / 243 MiB
partition 1 is also correctly seen as:
    ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 15 GB / 14 G
So far everything is OK. However I cannot seem to recover both partitions.
If I select 0 as primary bootable (I think it is the /boot partition) I cannot make any valid selection for 1 (It does not allow me to chose either Logical or Extended and selecting Primary for that partition is apparently bad?)
On another (Debian) system I have this structure:
    Disk /dev/sda - 1000 GB / 931 GiB - CHS 121602 255 63
    >* Linux                    0  65  2  2549 196 15   40957952
     P Linux                 2549 196 16 121535 178 51 1911508992
     P Linux Swap           121535 178 52 121600 215  7    1046512
But if I try to set this on the corrupted disk I get an error:
     * Linux                    0  63 31   243  63 30     497664
    >P Linux                    1   0  1 15070  63 32   30863360
    Structure: Bad. Use Up/Down Arrow keys to select partition.
if I set one as primary boot (all I can do apparently) I get this on the next screen:
     1 * Linux                    0  63 31   243  63 30     497664
     [  Quit  ] >[Deeper Search]  [ Write  ]
I am very afraid to write only one partition to the device with the knowledge that it actually has two (/boot and /). How can I ensure that that second partition gets recovered as well?
