Selected wrong partition and Write, now not found
r00tz
#1 Post by r00tz »
Unfortunately battery was about to run out and no power supply so when I had found the partitions with TestDisk, the 500GB HPFS-NTFS was found, listed as 2nd of 4 partitions on the disk.
I chose by mistake the first partition and then selected write, but the second partition (big one with all the data and OS) if what I should have selected. Now when I do quick scan and also deep search, that one I am trying to recover is not listed.
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60802 255 63
>* HPFS - NTFS 0 32 33 130 203 9 2099200 [SYSTEM ]
P HPFS - NTFS 58799 53 7 60539 151 28 27959296 [HP_RECOVERY]
P FAT32 LBA 60539 151 29 60800 172 44 4194304 [HP_TOOLS]
Is is clear that the partition which was initially found as in 2nd place there between 130 and 58799.
Before I made this testdisk Write mistake, this is what was listed:
Disk /dev/sdb - 500GB / 465 GiB - CHS 60801 255 63
1 P HPFS-NTFS 0 32 33 130 203 9 2099200
Invalid NTFS or EXFAT boot
2 * HPFS-NTFS 130 203 10 58799 53 6 942508032
3 P HPFS-NTFS 58799 53 7 60539 151 28 27959296
4 P FAT32 60539 151 29 60800 172 44 4194303 [HP_TOOLS]
So as you can see I've lost partition 2, because I selected Partition 1 in the above list, then chose Write.
Does that mean there is no way to recover partition 2 now that Testdisk no longer finds it? It is an HP Client security encrypted disk containing the Windows 7 OS and all my files.
Thank you for any help or advice if I have to give up or there is a solution? :oops:
Re: Selected wrong partition and Write, now not found
After Quick Search, use a' to manually add the missing partition
Set the first partition as P(rimary). Set the partition you have added as *(bootable).
On next screen, choose Write, confirm, Quit
You should now be back to the situation before using TestDisk.
There is probably a method to reinstall HP Client Security utility or decrypt the partition.
