What settings to use to increase recovery success?
amskuay
#1 Post by amskuay »
Thanks for this awesome program. I have been able to recover jpg files from an SD card which had been formatted. Thankyou for all the hard work you've put in!
Unfortunately, I had a little accident yesterday - I was trying to fix a thumbdrive with disk part and used the format recommended override function. Unfortunately, I specified the wrong volume and it targeted my 2TB secondary HDD. I realised 1% in and quickly stopped the procedure. When I then checked the secondary HDD, I saw that it was RAW. The bad news does not stop there. When tried to access the drive through Windows explorer, it said I needed to format the drive in order to access it. I thought that format doesn't really delete the data so I pressed ok to format. The process only took 2 seconds. Obviously the secondary HDD is now empty, but at least I can access it.
So I have used photorec to try and recover the data - it is all photos. But nothing has turned up. I had 181GB worth of photos there and it cannot seem to recover any of it. What settings would you recommend to increase my chance of recovery success? Thanks so much... My wife is close to kicking me out!
Re: What settings to use to increase recovery success?
Run TestDisk, Advanced, select the partition, choose Boot, RebuildBS, List, if you see your files, choose Write and confirm, Quit
Please post the testdisk.log content if it doesn't work.
amskuay
#3 Post by amskuay »
Thanks for the reply. This is what I came back with:
Wed Jan 21 18:24:45 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249690062848
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=19365888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000396746752
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 EVO 250GB, S/N:S1DBNSCF102454N, FW:EXT0BB6Q
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1CH164, S/N:W1E7VXWV, FW:CC27
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1CH164, S/N:W1E7VTWQ, FW:CC27
Drive D: - 19 MB / 18 MiB - CHS 4 64 32, sector size=2048 - HL-DT-ST BD-RE BH16NS40, FW:1.01
Disk /dev/sdc - 2000 GB / 1863 GiB - ST2000DM001-1CH164
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 243201 45 44 3907024896
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size 3907024896
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 16, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
mftmirr_lcn 2
5 dr-xr-xr-x 0 0 0 19-Jan-2015 22:48 .
5 dr-xr-xr-x 0 0 0 19-Jan-2015 22:48 ..
37 dr-xr-xr-x 0 0 0 18-Jan-2015 21:45 $RECYCLE.BIN
35 dr-xr-xr-x 0 0 0 19-Jan-2015 21:24 System Volume Information
Directory /$RECYCLE.BIN
37 dr-xr-xr-x 0 0 0 18-Jan-2015 21:45 .
38 dr-xr-xr-x 0 0 0 18-Jan-2015 21:45 S-1-5-21-772128391-2832168975-2335427895-1001
Directory /$RECYCLE.BIN/S-1-5-21-772128391-2832168975-2335427895-1001
38 dr-xr-xr-x 0 0 0 18-Jan-2015 21:45 .
37 dr-xr-xr-x 0 0 0 18-Jan-2015 21:45 ..
40 -r--r--r-- 0 0 129 18-Jan-2015 21:45 desktop.ini
Directory /System Volume Information
35 dr-xr-xr-x 0 0 0 19-Jan-2015 21:24 .
99 -r--r--r-- 0 0 131072 21-Jan-2015 16:14 001.dat
39 -r--r--r-- 0 0 131072 19-Jan-2015 21:23 002.dat
36 -r--r--r-- 0 0 76 18-Jan-2015 21:02 IndexerVolumeGuid
41 -r--r--r-- 0 0 20480 19-Jan-2015 21:24 tracking.log
mftmirr_lcn 2
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
I had previously tried aggressive search also, but it was still running after 36hrs, so decided to stop.
Try PhotoRec, in Options, enable the expert mode, start a recovery, use a blocksize of 512, use the default settings otherwise. Do you recover your pictures this way ?
amskuay
#5 Post by amskuay »
I've tried that too and it didn't really do much. I Don't understand where it could have all gone.
