Partition found and all my files are there but...
jimmcwibb
#1 Post by jimmcwibb »
...I can'tm get the partition to recover properly. Can someone point me in the right direction? This is what happens:
I click continue, next screen:
I can go into the files and see that they're all there. Is the characteristics correct? This is an external drive and I've never used it as a bootable drive. Next screen:
I click write and it all seems good. But then when I plug the drive into a windows machine it says there's no filesystem and it needs to be formatted. :|
Thanks
Re: Partition found and all my files are there but...
Run Testdisk, Advanced, Boot, if available, choose BackupBS and confirm.
Run "cmd" (right click run as administrator), "chkdsk /f d:" (replace d: by the correct drive letter).
jimmcwibb
#3 Post by jimmcwibb »
Thanks cgrenier, I'll try that once I have all my data backed backed up from it.
jimmcwibb
#4 Post by jimmcwibb »
The backup boot sector is "bad" and backupBS isn't an option.
At least I'm getting all my files off. Nothing is corrupted at all.
