WDC 20 GB Lost? testdisk 6.14
asadz
#1 Post by asadz »
TestDisk 6.14, I have tried to repair WDC ROM MODEL-SCORPIO and the repair was unsuccessful due to "read errors". I have attached testdisk.log as well.
I think this is due to fact i cannot find any disk part to repair or fix.
Where should i go about now? Any clues , suggestion thanks.
Re: WDC 20 GB Lost? testdisk 6.14
If there are bad sectors, you must clone the disk first:
asadz
#3 Post by asadz »
Ok I will clone using ddrescue and get back to you. Would it not making any difference if testdisk cannot locate any portions as of yet?
asadz
#4 Post by asadz »
cgrenier wrote:If there are bad sectors, you must clone the disk first:
The output of both commands
./ddrescue -n /dev/old_disk /dev/new_disk rescued.log
# then try to recover as much of the dicy areas as possible:
./ddrescue -r 1 /dev/old_disk /dev/new_disk rescued.log
on ddrescue output screen shows
rescued: 0 B
ANY help
DorianWD
#5 Post by DorianWD »
Hi there,
I'm sorry to hear that you are facing such issues with your drive. You could download Data Lifeguard Diagnostic tool to try to repair the drive. Here is a link to the website: http://products.wdc.com/support/kb.ashx?id=xIkq0v
A cloning software such as Acronis True Image should let you skip the bad sectors. Here is a similar topic I've found: http://forums.anandtech.com/showthread.php?t=2295490
Hope this helps.
