Your disk should be listed exactly as it was here;
If the values in TestDisk are 255 at heads and sectors 63 it could be changed in the menu geometry.Disk /dev/sdc - 1000 GB / 931 GiB - CHS 969010 32 63
1 P EFI System 40 409639 409600
Warning: number of heads/cylinder mismatches 255 (NTFS) != 32 (HD)
2 P MS Data 409640 1953262983 1952853344 [Time Machine]
In case let me know.
Confirm in TestDisk through until you see Analyse.
Choose your partition MS Data!
If it appears as Unknown, please go to Type and change it to your previous file system NTFS.
If the menu Boot is not available you must change it to NTFS using Type also.
Confirm at Boot and provide info about your boot sector and its backup.
Please run Rebuild BS.
As long as you don't confirm at Write afterwards, youll not going to change anything.
If "Rebuild BS" was succesful you should see the menu List!
Have a try to list your files at the menu List.
Do you see your files or an error message!
