Sky box changed 2 NTFS partitions to Linux - help!
electron1948
#1 Post by electron1948 »
I've used Testdisk to recover damaged NTFS before but this has me beaten - any help would be much appreciated! Daughter's 1Tb ext drive(almost full!). Connected to a Sky TV box which gabbed it and changed 2 NTFS partitions to Linux.
The files are still there and many have been recovered with TestDisk/PhotoRec but would like the original partitions back.
TestDisk finds:
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Seagate Backup+ SL,
then:
Disk /dev/sdd - 1000 GB / 931 GiB - Seagate Backup+ SL
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
check_part_i386 1 type 88: no test
check_part_i386 2 type 8A: no test
1 P Sys=88 0 1 1 124 254 62 2008061
Bad sector count.
2 P Sys=8A 124 254 63 121600 254 63 1951511941
then:
Linux 0 1 1 124 254 63 2008062
EXT3 Sparse superblock, 1028 MB / 980 MiB
Linux 124 254 63 121600 254 58 1951511936
XFS 6.2+ - bitmap version, 999 GB / 930 GiB
Puzzled why TestDisk reports: Partition table type: Intel and then goes on to find only Linux partitions. Any hope that the partitions may be recoverd?
Many thanks for any help.
Re: Sky box changed 2 NTFS partitions to Linux - help!
After Quick Search, use Deeper Search, if the NTFS partition are found, set them to P(rimary) and on next screen, choose Write, confirm, if asked, choose BackupBS and confirm, Quit
