Sandisk 16G thumb drive
longcaster
Re: Sandisk 16G thumb drive
#11 Post by longcaster »
Disk /dev/sdb – 16 GB / 14 GiB – CHS 1948 255 63
P FAT32 0 0 1 1948 111 18 31301631
#12 Post by Fiona »
Please press p to list your data.
Did you see your data or an error message?
longcaster
#13 Post by longcaster »
Let's see if this works, I created a word doc out of a screen shot, since I can't post a jpeg.
Rat's, that doesn't work.
Anyway, I am back to trying to "rebuild a boot sector"
It says no FAT found searching subdirectry
longcaster
#14 Post by longcaster »
How do I rebuild the FAT data?
#15 Post by Fiona »
Sry for delay!
Repeat your steps through analyze until you get to the following;
I assume it has been partition table type intel and not None.
None means, no partition table, so it's not possible to write any partition.
Just press enter, highlight Write and press enter and y to confirm.
Now you registererd you partition to the partition table and you should be able to diagnose your thumb drive using rebuild bs.
Please use partition table type intel!
longcaster
#16 Post by longcaster »
Fiona wrote:Sry for delay!
I don't understand the "highlight" part of the instructions. I don't know how to highlight something in DOS.
#17 Post by Fiona »
If you press enter at this screen;
The next screen appears and at the bootom of the screen you will see;
Quit...Deeper Search...Write.
I meant, highlight or choose Write using your arrow key.
Another easy solution to repeat it, is;
Confirm in testdisk through, until you see;
"Quit...Deeper Search...Write" at the bottom of the screen.
Please, close TestDisk using Quit.
In your testdisk folder, you'll find a file testdisk.log
Can you copy and paste the content here?
longcaster
#18 Post by longcaster »
Is this what you require?
Mon Mar 5 10:58:28 2012
TestDisk 6.14-WIP, Data Recovery Utility, January 2012
OS: Windows XP SP3
Compilation date: 2012-02-26T19:38:17
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=16026435072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=16026435072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=155737451520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=0
Fix disk size using CHS
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ST9160314AS, FW:D005DEM1
Disk /dev/sdb - 16 GB / 14 GiB - CHS 1948 255 63, sector size=512 - SanDisk Cruzer, FW:8.02
Disk /dev/sdb - 16 GB / 14 GiB - SanDisk Cruzer
Analyse Disk /dev/sdb - 16 GB / 14 GiB - CHS 1948 255 63
Ask the user for vista mode
search_vista_part: 1
file_pread(5,2,buffer,31301632(1948/111/20)) lseek err Invalid argument
file_pread(5,1,buffer,31301632(1948/111/20)) lseek err Invalid argument
file_pread(5,7,buffer,31301633(1948/111/21)) lseek err Invalid argument
file_pread(5,8,buffer,31301640(1948/111/28)) lseek err Invalid argument
file_pread(5,3,buffer,31301648(1948/111/36)) lseek err Invalid argument
file_pread(5,3,buffer,31301695(1948/112/20)) lseek err Invalid argument
file_pread(5,8,buffer,31301711(1948/112/36)) lseek err Invalid argument
file_pread(5,11,buffer,31301758(1948/113/20)) lseek err Invalid argument
file_pread(5,2,buffer,31303680(1948/143/52)) lseek err Invalid argument
file_pread(5,1,buffer,31301631(1948/111/19)) ReadFile The request could not be performed because of an I/O device error.
A new copy of MBR code has been written.
You have to reboot for the change to take effect.
#19 Post by Fiona »
Yes, it's exactly what I required.
Ther is no difference.
Partition table type intel didn't find anything.
Also, your thumb drive is available but RAW (unformatted).
To have a check for better results, you could test Deeper Search and partition table type None.
If a partition is found and your data are listed, you could copy them.
But I've seen an error also;
In case, try PhotoRec to recover your data.
Please scan your complete disk.
longcaster
#20 Post by longcaster »
Norton 360 has a program called "Sonar" that doesn't like PhotoRec. When I tried to run the program, it would shut me down and get rid of the program.
With persistance, I was able to accept PhotoRec as a program safe to run, here is the log file result;
<?xml version="1.0" encoding="UTF-8" ?>
- <dfxml xmloutputversion="1.0">
- <metadata xmlns="http://www.forensicswiki.org/wiki/Categ ... ensics_XML" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:dc="http://purl.org/dc/elements/1.1/">
<dc:type>Carve Report</dc:type>
</metadata>
- <creator>
<package>PhotoRec</package>
<version>6.14-WIP</version>
- <build_environment>
<compiler>GCC 4.6, Cygwin 1007.9</compiler>
<compilation_date>2012-03-05T23:17:37</compilation_date>
<library name="libext2fs" version="1.41.8" />
<library name="libewf" version="20100226" />
<library name="libjpeg" version="80" />
<library name="libntfs" version="10:0:0" />
</build_environment>
- <execution_environment>
<os_sysname>Windows</os_sysname>
<os_release>Windows XP SP3</os_release>
<os_version>Windows XP SP3</os_version>
<host>D9F9DCD1</host>
<arch>i686</arch>
<uid>0</uid>
<start_time>2012-03-09T11:55:37-0500</start_time>
</execution_environment>
</creator>
- <source>
<image_filename>/dev/sdb</image_filename>
<sectorsize>512</sectorsize>
<device_model>SanDisk Cruzer</device_model>
<image_size>16026435072</image_size>
- <volume>
- <byte_runs>
<byte_run offset="0" img_offset="0" len="16026435072" />
</byte_runs>
</volume>
</source>
<configuration />
</dfxml>
