number of heads/cylinder mismatches 255 (NTFS)
tchup
#1 Post by tchup »
Bonjour à tous,
Une amie m'aimerait que je récupère ses données de son HDD externe Seagate Barracuda 7200.12 1T
J'ai déjà réussi auparavant cette opération sur divers disques mais là, le problème semble différent... plus sérieux. :|
Ne voulant pas faire de bêtise, je m'adresse à qui veux bien m'aider.
J'ai un warning : number of heads/cylinder mismatches 255 (NTFS) != 1 (HD)
Voici différentes étapes :
Disk /dev/sdb - 1000 GB / 931 GiB - ST310005 28AS
     CHS 31008336 1 63 - sector size=512
>[ Analyse  ] Analyse current partition structure and search for lost partitions
 [ Advanced ] Filesystem Utils
 [ Options  ] Modify options
 [ MBR Code ] Write TestDisk MBR code to first sector
 [ Delete   ] Delete all data in the partition table
 [ Quit     ] Return to disk selection
Note: Correct disk geometry is required for a successful recovery. 'Analyse'
process may give some warnings if it thinks the logical geometry is mismatched.
>>>>>>>>>>>>>>> Analyse
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 31008336 1 63
Warning: number of heads/cylinder mismatches 255 (NTFS) != 1 (HD)
 1 * HPFS - NTFS              1   0  1 31008255   0 63 1953520065
>[Quick Search]  [ Backup ]
                            Try to locate partition
>>>>>>>>>>>>>>> Quick Search
Warning: the current number of heads per cylinder is 1
but the correct value may be 128.
You can use the Geometry menu to change this value.
It's something to try if
- some partitions are not found by TestDisk
- or the partition table can not be written because partitions overlaps.
[ Continue ]
>>>>>>>>>>>>>>> Continue
 1 P HPFS - NTFS              1   0  1 31008255   0 63 1953520065
 [  Quit  ] >[Deeper Search]  [ Write  ]
>>>>>>>>>>>>>>> Deeper Search
Analyse cylinder 32768/31008335: 00%
[root@localhost ~]#
>>>>>>>>>>>>>>> Advanced > List
>>>>>>>>>>>>>>> Advanced > Boot
Status: OK
Status: OK
Sectors are identical.
>>>>>>>>>>>>>>> Advanced > Boot > RepairMFT
>>>>>>>>>>>>>>> SCAN long...
The harddisk (1000 GB / 931 GiB) seems too small! (< 4271 GB / 3977 GiB)
>  FAT16 >32M           13708107   0 57 69940067   0 13 3542613437
   FAT32 LBA            18815817   0 58 58164475   0 46 2478965443
   FAT16 <32M           35158015   0 12 56390621   0 38 1337654205
   FAT32                70003932   0 51 132414928   0 33 3931892731
[ Continue ]
1813 GB / 1689 GiB
Après j'ai décidé de cloner le disque :
[root@localhost ~]# dd if=/dev/sdc1 of=/dev/sdb conv=noerror,sync
1953520065+0 enregistrements lus
1953520065+0 enregistrements écrits
1000202273280 octets (1,0 TB) copiés, 51440,9 s, 19,4 MB/s
avec 14H de duplication...
Merci d'avance pour votre aide.
Re: number of heads/cylinder mismatches 255 (NTFS)
Attention, vous avez cloner une partition vers un disque et non disque vers disque.
Essayez TestDisk, Advanced, Boot, RebuildBS, List et si les fichiers sont visibles, choisir Write et confirmer.
Si cela ne fonctionne pas, vous pouvez utiliser PhotoRec pour récupérer les données, mais les noms d'origine des fichiers ne seront pas récupérés.
tchup
#3 Post by tchup »
>>>>>>>>>>>>>>> Advanced > Boot > RebuildBS
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 31008336 1 63
filesystem size           1953520065 1953520065
sectors_per_cluster	  8 8
mft_lcn                   4 786432
mftmirr_lcn               122095004 2
clusters_per_mft_record   -10 -10
clusters_per_index_record 1 1
 [  Dump  ] >[  List  ]  [ Write  ]  [  Quit  ]
                           List directories and files
>>>>>>>>>>>>>>> Advanced > Boot > RebuildBS > List
:cry:
