The wiki says PhotoRec should be able to generate a .log file using the /log parameter.
I'm unsure of how to do this, and am unable to generate a .log file to see if I am having any errors.
Thanks
PhotoRec not generating a .log file
Re: PhotoRec not generating a .log file
What O/S are you using? What version of photorec are you using? What have you tried so far? You just simply append the /log switch when invoking photorec from the command line...
stumpyuk wrote:What O/S are you using? What version of photorec are you using? What have you tried so far? You just simply append the /log switch when invoking photorec from the command line...
Windows
PhotoRec 7.0 WIP
Not tried anything since I'm not sure how to do it.
I get a log when I use the GUI version as it seems to generate it automatically.
Either put photorec.exe in your path (e.g \Windows\System32) and invoke with:
photorec.exe /log
OR
cd to where your executable is and invoke with:
photorec.exe /log
Stumpy
photorec.exe /log
OR
photorec.exe /log
Stumpy
