Contribution - Script to sort testdisk/photorec results
datacorder
#1 Post by datacorder »
Hi all,
Those of you using testdisk/photorec free software for recovering lost files shall know what means searching specific file types as images in results.
I just did a short python script that sorts all the files extracted by testdisk/photorec in folders sorted by filetype (images, pdf, video, etc).
You can check it too in my website at http://system-tricks.com/index.php/data ... y-results/
Hope you find it useful.
#!/usr/bin/env python
# System-Tricks - http://system-tricks.com
# Copyleft 2012 - Luis A. Fernandez (datacorder@gmail.com)
# This program is free software. You can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program.  If not, see <http://www.gnu.org/licenses/>.
import os, magic
from shutil import copyfile
#================ CONFIG SECTION ================#
# Source folder with photorec/testdisk results:
testdisk_results = 'SOURCE FOLDER WHERE TESTDISK RESULTS ARE'
# Destination folder where you want to store the sorted results:
base_destdir = 'DESTINATION FOLDER WHERE YOU WANT TO STORE SORTED RESULTS'
# File types to filter out. You can add every MIME-types you are not interested on:
filter = ['application_octet-stream', 'text_plain']
#============= END OF CONFIG SECTION ============#
types = {}
mime = magic.open(magic.MAGIC_MIME)
mime.load()
for dir in os.listdir(testdisk_results):
    for filename in os.listdir(os.path.join(testdisk_results, dir)):
        file = os.path.join(testdisk_results, dir, filename)
        filetype = mime.file(file).split(';')[0].replace('/', '_').replace(" ", "_").split(',')[0]
        if filetype in filter:
            continue
        if not filetype in types:
            types[filetype] = 1
        else:
            types[filetype] += 1
        print filename + ": " + filetype
        destdir = os.path.join(base_destdir, filetype)
        destfile = os.path.join(destdir, filename)
        if os.path.exists(destdir):
            try:
                copyfile(file, destfile)
            except Exception, e:
                print "Error copying " + filename + ": " + str(e)
                continue
        else:
            os.makedirs(destdir)
            try:
                continue
print "\n** Results:\n--------------------"
for type in types:
    print type + ": " + str(types[type]) + " files"
print print "\n---------------------------\n\n* Finished. Results stored in " + base_destdir + "\n\n"
remy
Re: Contribution - Script to sort testdisk/photorec results
#2 Post by remy »
Did not try yours, but will test later.
By the way, there are already scripts like yours. Solutions are there :
http://www.cgsecurity.org/wiki/After_Using_PhotoRec
EDIT : BTW, could be a good idea to specify your licence for this script. Is it under GPL, copyleft, CCBY... ?
Your webpage is under copyleft, but nothing there tells to user for the script. ;)
datacorder
#3 Post by datacorder »
Ei remy, thank you very much. I forgotten the license. Now it's under GPL, of course.
I didn't knew about that script. Anyway I hope it's useful.
Cheers!
remy
#4 Post by remy »
I'll let you know next time I've a datarecovery to do with many filetypes. I'll try your script also and compare results, and time taken. But as far as I can see (I don't know enough python) the structure is very similar with the one in the wiki page.
BTW, are you involved in DR ?
datacorder
#5 Post by datacorder »
Great, will be great receive your feedback.
I have a small DR business for giving service to some computer repair stores in my area. Just to recovering data from non physical damages, you know. I would like to buy some stuff later in order to expand it but at the moment I'm focused on my main job.
I think on it as one of the best options for my retirement ;)
remy
#6 Post by remy »
Do not hesitate to contact me by PM. I'm in the same situation : I was a teacher (since 12 years) and I decide to change my life and create a Cie in DR. Where are you from ?
datacorder
#7 Post by datacorder »
Greaet, thank you remy, I'm sure that I will contact you forward :)
I'm from Spain. Is you DR bussines working??
remy
#8 Post by remy »
Yes, like a little Cie begining, but... good beginning.
