Drobo diskpart clean
moustady
#1 Post by moustady »
I have accidentally used diskpart "clean" command(no parameters) on my drobo.
I have 2 identical 1 TB harddrive
doing testdisk quickscan to dropo through usb will take about 270 days.
so I unplugged the harddrive and pluged it into SATA, it will take now 2.5 hours
now how can I undo what the clean command did to my drobo drives.
Please help!!!
Re: Drobo diskpart clean
After Quick Search and/or Deeper Search, il all your partitions are listed, set them as P(rimary) and on next screen, choose Write, confirm, Quit
moustady
#3 Post by moustady »
hey cgrenier,
thank you for the reply.
just to make sure I understand you correctly.
1st remove the 2 hard drive from drobo
2nd use diskpart on the 2 drives using quick or deeper search.
3rd if I find any partition I will set "all" of them to primary
4th re-install the drives to drobo
Finish :)
one other question..
what shall I choose the partition table type?
Kind Regards,
Moustady
Use TestDisk, not diskpart again.
