Lost Partition/Lost FAT/Lost FS
sbtm77
#1 Post by sbtm77 »
Hi everyone,
My primary disk with OS Win 7 crashed all of a sudden and got greeted with a boot disk failure. That was 1TB Seagate HD with only 1 partition (NTFS) and had only the OS and user account files.
Put in the new HD loaded windows and started TestDisk. TD could not find any partition even after deep search, didn't find any file system and certainly says FAT is corrupt!
I really need to get to the "Program Files" and "Users" folders and that's it! Don't need nothing else!
Anyway I can get those two folders?
Thanks.
--Sadiq
Re: Lost Partition/Lost FAT/Lost FS
Run TestDisk, Advanced, Boot, RebuildBS, List and if you can see your files, copy them.
If you have problems, please post the testdisk.log file content.
sbtm77
#3 Post by sbtm77 »
Can't see testdisk.log in app folder. However, after carrying out what you had suggested, I get the following screen:
TestDisk 7.0-WIP, Data Recovery Utility, March 2015
Can't find cluster size
>[Ok]
I hope I can still get my files.
--Sadiq
sbtm77
#4 Post by sbtm77 »
I am getting the below message, which seems severe to me:
Disk e:\image.dd - 1000 GB / 931 GiB - CHS 121602 255 63
   P NTFS                     0   0  1 121601  80 63 1953525168
Status: Bad
Status: Bad
Sectors are not identical.
>[  Quit  ]  [Rebuild BS]  [  Dump  ]
                            Return to Advanced menu
This message was recieved after trying to Rebuild BS.
Appreciate any direction.
--Sadiq
sbtm77
#5 Post by sbtm77 »
cgrenier wrote:Run TestDisk, Advanced, Boot, RebuildBS, List and if you can see your files, copy them.
Looks like my situation is really bad. Can you still help?
#6 Post by cgrenier »
I really need the testdisk.log file content, not a screenshot.
In the worst case, use PhotoRec. It will recover your data but without the original filenames.
sbtm77
#7 Post by sbtm77 »
cgrenier wrote:I really need the testdisk.log file content, not a screenshot.
Here you go!
testdisk.zip
(1.36 KiB) Downloaded 857 times
#8 Post by cgrenier »
Can you force the type of the partition to NTFS (7) and try again Boot, RebuildBS, List.
If you can see your files, choose Write and confirm.
Please post the new log file.
sbtm77
#9 Post by sbtm77 »
cgrenier wrote:Can you force the type of the partition to NTFS (7) and try again Boot, RebuildBS, List.
Hi Cgrenier,
Latest logs are attached!
--Sadiq
testdisk.zip
(1.53 KiB) Downloaded 822 times
#10 Post by Fiona »
I've only got some information that you've changed your partition type Fat16<32M to NTFS using the menu Advanced / Type.
As the result, either there is no NTFS boot sector or both are invalid?
Did you already run RebuildBS?
When you were running Quick and Deeper Search, did you get any message of unrecoverable partitions?
