Lost Partition/Lost FAT/Lost FS
sbtm77
Re: Lost Partition/Lost FAT/Lost FS
#11 Post by sbtm77 »
Fiona wrote:I've only got some information that you've changed your partition type Fat16<32M to NTFS using the menu Advanced / Type.
As the result, either there is no NTFS boot sector or both are invalid?
Did you already run RebuildBS?
When you were running Quick and Deeper Search, did you get any message of unrecoverable partitions?
Hi Fiona,
RebuildBS was already done and nothing came out of it. Re-running it now as we speak.
With Quick and Deeper Search, I have never gotten these messages before. I will run them as well and send across the log file.
--Sadiq
#12 Post by Fiona »
You can copy and paste the content of your testdisk.log running Analyse, Quick and Deeper Search into your next post!
Could be more detailed about your situation finding any boot sector and a backup of it at another location?
sbtm77
#13 Post by sbtm77 »
Good morning Fiona,
Ran all searches along with RebuildBS and tried to List as well. No success. Before running all this, I ran qphotorec_win and all I got was 1 pst file and a lot of mp3, which FYI I didn't have a single mp3 on that disk!
Anyways, here are is the log for testdisk run:
Fri Apr 24 22:52:37 2015
TestDisk 7.0-WIP, Data Recovery Utility, March 2015
Compilation date: 2015-03-09T19:49:55
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500000882688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=699004928
Disk /dev/sda - 500 GB / 465 GiB - CHS 64601 240 63, sector size=512 - ST500DM002-1BD142, S/N:202020202020202020202020365a45454c453645, FW:KC48
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1ER164, S/N:202020202020202020202020345a315a4e373231, FW:CC25
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1ER164, S/N:202020202020202020202020345a315a4e373844, FW:CC25
Disk /dev/sdh - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST310005 24AS, S/N:152D20337A0C
Drive L: - 699 MB / 666 MiB - CHS 341311 1 1, sector size=2048
Disk /dev/sdh - 1000 GB / 931 GiB - ST310005 24AS
test_FAT()
 1 P FAT16 >32M               0  32 33 121601  25 24 1953519616
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
Change partition type:
 1 P HPFS - NTFS              0  32 33 121601  25 24 1953519616
Analyse Disk /dev/sdh - 1000 GB / 931 GiB - CHS 121601 255 63
test_FAT()
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
Invalid FAT boot sector
file_pread(7,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(7,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(7,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(7,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(7,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(7,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(7,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(7,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(7,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
NTFS at 121601/25/24
filesystem size           2930286592
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=1000203091456, part_size=1500306735104, sector_size=512
test_FAT()
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
test_FAT()
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
fat1x_boot_sector
Bad
ntfs_boot_sector
NTFS at 0/32/33
Error: size boot_sector 2930286592 > partition 1953519616
filesystem size           1 2930286592
sectors_per_cluster       0 8
mft_lcn                   0 786432
mftmirr_lcn               0 2
clusters_per_mft_record   0 -10
clusters_per_index_record 0 1
Status: Bad
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
ntfs_boot_sector
NTFS at 0/32/33
mft_lcn                   0 786432
mftmirr_lcn               0 2
Status: Bad
Status: Bad
*Fingers crossed*
#14 Post by Fiona »
Partition information in your boot sector is far beyond your disk limit and size of your partition.
RebuildBS didn't work either.
That's why it looks that your file system is damaged.
You should use datarecovery software like PhotoRec and trying to recover data.
You should run PhotoRec on your disk and scanning the whole space.
You can use FileOpt and pressing s to deselect all file types and only activating these file types where you'd like to recover.
It saves recovering of unnecessary files.
You can test to recover first a small amount of files and test it.
You can stop PhotoRec and if you restart it, PhotoRec will ask to continue your previous session.
sbtm77
#15 Post by sbtm77 »
Many thanks Fiona for your response. I will try this immediately and hope for the best :)
--Sadiq
sbtm77
#16 Post by sbtm77 »
Hi Fiona,
The list of files PhotoRec has found is really not right. The hard drive that I am scanning used to my OS (Win7) drive and had all the program files.
The extensions it has found is:
mp3: 12180 recovered
txt: 23 recovered
ogg: 17 recovered
tib: 4 recovered
gz: 3 recovered
gpg: 2 recovered
pst: 1 recovered
I didn't have any mp3 files there and I can't see executables either. Granted the scan hasn't finished yet.
#17 Post by Fiona »
I've no idea why the result is so poor?
In case to get an overview about the condition of your data, you could download a trial of commercial software like restorer ultimate and scan your drive.
Please scan your whole disk and it's absolutely important.
Afterwards you can check all partitions found and the condition of your data, even folder?
sbtm77
#18 Post by sbtm77 »
I think I'll download the commercial software ava see what I come up with.
Let's hope for the best.
I'll report back!
sbtm77
#19 Post by sbtm77 »
Fiona wrote:restorer ultimate and scan your drive.
Hi Fiona,
Sorry for not writing back earlier. I guess I have given up.
Downloaded Restorer Ultimate and got the same exact output as earlier. It gave me a bunch of mp3 (tens of thousands) and a few here and there. This obviously doesn't seem correct because that was the OS (Win7) drive and had user folders, program files and that's it. All docs were on seperate drive.
I am tempted now to format that drive and run a scan then!
What do you think???
sbtm77
#20 Post by sbtm77 »
Btw, Fiona, I just remembered one thing; the Win7 drive had a "system reserved" partition of about 100MB.
Maybe that's whats throwing off the rescue apps? Or maybe we can recreate the partitions having this in mind? Just a thought.
