Space conflict leads to unmountable written partition
danzcgsecurity
#1 Post by danzcgsecurity »
I get a space conflict as per the log below. Even when I set the heads to 8 as suggested, go through the process, I end up with an unmountable disk.
I'm using OSX. They were all MAC OS Extended (Journaled) Partitions of one 3TB disk.
The files on the disk are recoverable with photorec, yet I seem unable to restore the partition. Is there anything else I can try?
Sat Apr  4 23:02:45 2015
OS: Darwin, kernel 14.1.0 (Darwin Kernel Version 14.1.0: Thu Feb 26 19:26:47 PST 2015; root:xnu-2782.1
Compiler: GCC 4.0
Compilation date: 2011-11-15T08:36:43
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226
Disk /dev/disk0 - 121 GB / 113 GiB - CHS 236978176 1 1 (RO), sector size=512
Disk /dev/disk2 - 3000 GB / 2794 GiB - CHS 1565565873 1 1, sector size=512
Disk /dev/rdisk0 - 121 GB / 113 GiB - CHS 236978176 1 1 (RO), sector size=512
Disk /dev/rdisk1 - 120 GB / 111 GiB - CHS 234643592 1 1, sector size=512
Disk /dev/rdisk2 - 3000 GB / 2794 GiB - CHS 1565565873 1 1, sector size=512
Analyse Disk /dev/rdisk2 - 3000 GB / 2794 GiB - CHS 1565565874 1 1
Geometry from i386 MBR: head=8 sector=1
HFS+ magic value at 614448/0/1
HFS+ magic value at 1465720368/0/1
check_part_i386 failed for partition type AF
get_geometry_from_list_part_aux head=1 nbr=6
get_geometry_from_list_part_aux head=16 nbr=4
 1 * HFS                       614448 1465458223 1464843776
Warning: Bad starting head (CHS and LBA don't match)
 2 P HFS                   1465720368 4395407919 2929687552
No HFS or HFS+ structure
 3 P HFS                   4294967295 5759568214 1464600920
Ask the user for vista mode
search_vista_part: 0
check_FAT: Incorrect number of bytes per sector 4096 (FAT) != 512 (HD)
part_size 1464843776
     HFS+, 750 GB / 698 GiB
part_size 2929687552
     HFS+, 1500 GB / 1396 GiB
HFS+ magic value at 100702768/0/1
part_size 1464600920
     HFS                   4395670064 5860270983 1464600920
     HFS+, 749 GB / 698 GiB
get_geometry_from_list_part_aux head=8 nbr=6
get_geometry_from_list_part_aux head=16 nbr=5
Warning: the current number of heads per cylinder is 1 but the correct value may be 8.
   P HFS                   4395670064 5860270983 1464600920
 3 P HFS                   4395670064 5860270983 1464600920
Re: Space conflict leads to unmountable written partition
You can try to restore only one partition, after a reboot, mount it and copy the files. And try to recover the second partition.
