NAS Issues
Re: NAS Issues
#11 Post by Fiona »
Did you run a RebuidBS?
Your length of your partition and info about the length of your partition in your boot sector are slightly different.
Info: size boot_sector 2930277042, partition 2930288067
In case, can you run a RebuildBS and copy and paste the content of your log file again?
agcereniv
Re: NAS Issues
#12 Post by agcereniv »
Ok, I'm working on RebuildBS. Is that supposed to take a while? I've been looking at the attached screen for several minutes. Here's the log so far with the RebuildBS in process...
Thu Apr 23 11:37:08 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592977920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1500301908992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592977920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1500301908992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=120031543296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500104691712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1500307490304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=20123648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=2048
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=3000579915776
Disk /dev/sdb - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Disk /dev/sde - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Drive C: - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Drive D: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Drive F: - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Drive G: - 20 MB / 19 MiB - CHS 4 64 32, sector size=2048
Drive J: - 2048 B - CHS 1 64 32, sector size=2048
Drive Z: - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096
FAT32 at 0/1/1
FAT1 : 32-357644
FAT2 : 357645-715257
start_rootdir : 715258 root cluster : 2
Data : 715258-2930276985
sectors : 2930277042
cluster_size : 64
no_of_cluster : 45774402 (2 - 45774403)
fat_length 357613 calculated 357613
1 * FAT32 LBA 0 1 1 182401 254 63 2930288067 [CERENMEDIA]
FAT32, blocksize=32768, 1500 GB / 1397 GiB
fat32_boot_sector
FAT32 at 0/1/1
FAT1 : 32-357644
cluster_size : 64
FAT32 at 0/1/1
FAT1 : 32-357644
cluster_size : 64
OK
OK
Sectors are identical.
Re: NAS Issues
#13 Post by Fiona »
Yes somtetimes it takes a bit longer.
Please finish it, and copy your log and a screen shot of your result after RebuildBS would be appreciated too.
agcereniv
Re: NAS Issues
#14 Post by agcereniv »
Fiona - I'm a little concerned as I'm still looking at the same screen and it has been hours later. Can I close it out and start over? It isn't responding to any key commands (the computer is, just not testdisk).
Re: NAS Issues
#15 Post by Fiona »
If it hangs, you should stop it!
Often due to a faulty file system?
In case, you should copy/backup your data.
