Info su Photorec
Creatt
Info su Photorec
#1 Post by Creatt »
I would like to understand the operation of photorec.
And the first time I use it, I get to find all the directories, I show you an example:
Please select a destination to save the recovered files.
Do not choose to write the files to the same partition they were stored on.
Keys: Arrow keys to select another directory
      C When the destination is correct
      Q to quit
/ Home / joseph
> Drwxr-xr-x 1000 1000 4096 7-May-2015 15:30.
 drwxr-xr-x 0 0 4096 30-Apr-2015 12:10 ..
 drwxr-xr-x 1000 1000 4096 30-Apr-2015 12:58 Documents
 drwxr-xr-x 1000 1000 4096 7-May-2015 13:10 Images
 drwxr-xr-x 1000 1000 4096 30-Apr-2015 12:58 Models
 drwxr-xr-x 1000 1000 4096 30-Apr-2015 12:58 Music
Now I select the C and I saved the file, but the bytes were zero.
I ask you for advice, I think there were not data, but I wonder if I run everything right.
I may have done something wrong I?
It can use the software, as the case is not subject to any bytes, even if there are?
Thanks, and sorry for my indiscretion.
Hello hello.
Re: Info su Photorec
Did you use TestDisk or PhotoRec?
It looks like that you used testdisk?
If you list your directories, did you enter a folder through mark it and using the right arrow key on your keybord to watch your files?
Please let me know did you use testdisk or photorec?
Info will follow.
Creatt
#3 Post by Creatt »
Ciao, ho usato Photorec, quando sono arrivato ai file, con il tasto freccia giu della tastiera, ho selezionato la directory documenti e poi ho pigiato il tasto c sulla tastiera.
Ciao ciao e grazie.
