I hope I'm posting this in the right please. If not, please let me know.
A few days a go I accidentally erased the wrong external hard drive using the Mac disk utility tool. The disk is empty and there is a new partition with a different name. I didn't write anything on the disk yet. I would like to restore the disk to find my files with filenames intact, but can't seem to find the files using testdisk.
When I run other programs I can see almost all of my files, so it looks like they are still there. The quick search couldn't find the deleted partition, only the current one. It's doing a deep search now for the last 22 hours and it's not even half finished. Should I let it finish the search or am I doing something wrong here? This is the result from halfway:
Disk /dev/rdisk3 - 1000 GB / 931 GiB - 1953458176 sectors
Analyse sector 682885120/1953458175: 00%
FAT12 1556595431 5190242366 3633646936
Invalid NTFS or EXFAT boot
0 D HPFS - NTFS 558472061 3585789623 3027317563
Invalid FAT boot sector
0 D FAT32 1379219530 3932626660 2553407131
0 D HPFS - NTFS 1494949931 1734614059 239664129
0 D FAT32 4298700828 7689588505 3390887678
Stop
Any advice would really be appreciated. Thanks!
Erased External ExFat Drive - not finding partition
Re: Erased External ExFat Drive - not finding partition
ExFAT is a kind of confusing.
It uses a NTFS-Partition but if you format it, the file system and boot sector are exFAT.
That's why your found partition will be listed as NTFS but at the bottom of the screen you'll get info about your boot sector and should be exFAT.
Currently exFAT boot sector repair is not available but if your boot sector or its backup are ok and you can list your files, you can copy them to another healthy disk or partition.
If your files are recovered you can consider to run chkdsk driveletter: /r to try to repair your file system.
Hi Fiona,
Thanks for your reply! It just finished scanning this morning. The results are attached to this message. I think the highlighted one should be my partition based on the size, but it's FAT 16. When I tried to do anything with the result it gave back te error: No partitions found. I checked my drives and noticed that the external drive was disconnected. Three days of scanning for nothing. Is there anything I can do without scanning for three days again?
- testdisk.jpg (156.61 KiB) Viewed 5548 times
I assume that your FAT16 partition is not correct?
Would it be possible to check the first found partition?
Check the bottom of the screen, is there an exFAT boot sector displayed?
Can you list your files?
I lost these results because the drive disconnected during the night. When I start testdisk now the only thing I can do is:
- select the drive: Disk /dev/rdisk3 - 1000 GB / 931 GiB
1953458176 sectors - sector size=512
Partition type should be Intel? Is that correct?
- Analyse:
When I chose that partition it just says:
I think this is my current partition, not the deleted one. Anything I can do here to get the old partition back?
When I go to list files it only shows this:
- Analyse:
1 P HPFS - NTFS 2 1953458175 1953458174
No partition is bootableCode: Select all
>* HPFS - NTFS 2 1953458175 1953458174
Enter: to continue
exFAT, blocksize=131072, 1000 GB / 931 GiBWhen I go to list files it only shows this:
>-rwxr-xr-x 0 0 4096 29-Apr-2015 17:18 ._.Trashes
drwxr-xr-x 0 0 131072 29-Apr-2015 17:18 .Trashes
drwxr-xr-x 0 0 131072 15-May-2015 06:24 .fseventsd
drwxr-xr-x 0 0 131072 29-Apr-2015 17:18 .Spotlight-V100Re: Erased External ExFat Drive - not finding partition
It's recommended to finish Deeper Search.
Also, your current partition contains already some data.
If you have reformatted your partition identically, it'll override your previous file system.
In case you need datarecovery software like photorec which reads underlying data ignoring the file system.
Did you reformat your partition?A few days a go I accidentally erased the wrong external hard drive using the Mac disk utility tool. The disk is empty and there is a new partition with a different name.
