No Files After Boot Sector Rebuild
FerozXBL
Re: No Files After Boot Sector Rebuild
#11 Post by FerozXBL »
Hi Fiona
Thanks for your response. Just to let you know, ive connected the drive to the computer again and now all of a sudden the drive is accessible within windows. However it reads as 2TB within windows and I can access the files on the drive within windows but its still not all my files are showing. This I assume is because of it only reading as 2TB instead of 3TB.
I ran a deep search, took very long and came up with the results below.
FerozXBL
#12 Post by FerozXBL »
Mon Jun 15 21:25:16 2015
OS: Windows 7 (7600)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=335439462400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=664656674816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2199023255040
Disk /dev/sda - 1000 GB / 931 GiB - CHS 129201 240 63, sector size=512
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive C: - 335 GB / 312 GiB - CHS 43330 240 63, sector size=512
Drive D: - 664 GB / 619 GiB - CHS 85856 240 63, sector size=512
Drive E: - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Partition table type: EFI GPT
Trying alternate GPT
NTFS at 1/5/5
filesystem size 4294967295
mftmirr_lcn 2
clusters_per_mft_record 1
NTFS part_offset=8388608, part_size=2199023255040, sector_size=512
NTFS at 1/5/5
mftmirr_lcn 2
MS Data 16384 4294983678 4294967295 [Seagate Expansion Drive]
NTFS, blocksize=4096, 2199 GB / 2047 GiB
P MS Data 16384 4294983678 4294967295 [Seagate Expansion Drive]
gpt_change_part_type
Change partition type:
P MBR 16384 4294983678 4294967295 [Seagate Expansion Drive]
P NTFS 16384 4294983678 4294967295 [Seagate Expansion Drive]
1 P MBR 16384 4294983678 4294967295 [Seagate Expansion Drive]
NTFS at 1/5/5
mftmirr_lcn 2
NTFS at 1/5/5
mftmirr_lcn 2
Unknown 739528268 3616244795 2876716528
FATX, 1472 GB / 1371 GiB
Partition not added.
HFS magic value at 80270/102/34
part_size 41953314
Mac HFS 1289544009 1331497322 41953314
HFS blocksize=524288, 21 GB / 20 GiB
HFS magic value at 80270/102/36
part_size 41953314
Mac HFS 1247590699 1289544012 41953314
HFS found using backup sector!, 21 GB / 20 GiB
SYSV4 Marker at 101910/77/27
recover_sysv4
Unknown 1637189027 260392241826 258755052800 [ðl§L¿k]
SysV4, 132 TB / 120 TiB
HFS magic value at 119714/195/4
part_size 4227330
Mac HFS 1923217698 1927445027 4227330
HFS blocksize=65536, 2164 MB / 2064 MiB
HFS magic value at 119714/195/6
part_size 4227330
Mac HFS 1918990372 1923217701 4227330
HFS found using backup sector!, 2164 MB / 2064 MiB
LVM magic value at 145284/154/7
cramfs Marker at 160114/52/36
recover_cramfs
MS Data 2572234721 2575797716 3562995 [˜:›íé”ìk@.¡°Ý´]
cramfs, 1824 MB / 1739 MiB
cramfs Marker at 160114/52/37
recover_cramfs
MS Data 2572234722 2575797717 3562995 [˜:›íé”ìk@.¡°Ý´]
cramfs Marker at 201881/234/54
recover_cramfs
MS Data 3243233060 3249933476 6700416 [%åÊh V½£â=¹¿Ë]
cramfs, 3430 MB / 3271 MiB
cramfs Marker at 201881/234/55
recover_cramfs
MS Data 3243233061 3249933477 6700416 [%åÊh V½£â=¹¿Ë]
NTFS at 267350/94/7
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 2199 GB / 2047 GiB
NTFS at 267350/94/7
mftmirr_lcn 2
MS Data 4294983678 8589950972 4294967295
This partition ends after the disk limits. (start=4294983678, size=4294967295, end=8589950972, disk end=5860533168)
NTFS at 364800/190/55
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
filesystem size 732563456
sectors_per_cluster 1
mftmirr_lcn 2
MS Data 16377 5860524024 5860507648
NTFS found using backup sector, blocksize=4096, 3000 GB / 2794 GiB
mftmirr_lcn 2
file_pread(5,8,buffer,1571848208(365192/95/40)) lseek err Invalid argument
file_pread(5,1,buffer,1571848208(365192/95/40)) lseek err Invalid argument
NTFS: Can't read MFT
MS Data 5860524024 11721031671 5860507648
This partition ends after the disk limits. (start=5860524024, size=5860507648, end=11721031671, disk end=5860533168)
file_pread(5,1,buffer,1565565872(364801/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565886(364801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565888(364801/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565889(364801/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565891(364801/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565892(364801/81/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565565893(364801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565895(364801/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565565896(364801/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565565897(364801/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565898(364801/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565565899(364801/81/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565565900(364801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565565901(364801/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565903(364801/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565904(364801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565905(364801/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565913(364801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565916(364801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565917(364801/81/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565919(364801/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565926(364801/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565932(364801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565935(364801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565936(364801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565938(364801/82/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565942(364801/82/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565944(364801/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565946(364801/82/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565947(364801/82/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565948(364801/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565951(364801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565954(364801/82/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565955(364801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565565956(364801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565565957(364801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565958(364801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565565959(364801/82/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565565960(364801/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565961(364801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565565962(364801/82/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565565963(364801/82/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565565964(364801/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565565965(364801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565966(364801/82/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565967(364801/82/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565968(364801/82/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565969(364801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565970(364801/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565565971(364801/82/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565973(364801/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565974(364801/82/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565976(364801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565977(364801/82/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565979(364801/82/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565980(364801/82/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565982(364801/82/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565983(364801/82/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565985(364801/82/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565988(364801/82/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565989(364801/82/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565991(364801/82/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565993(364801/82/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565994(364801/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565995(364801/82/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565996(364801/82/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565997(364801/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565998(364801/83/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565999(364801/83/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566000(364801/83/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566001(364801/83/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566002(364801/83/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566003(364801/83/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566004(364801/83/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566005(364801/83/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566006(364801/83/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566007(364801/83/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566008(364801/83/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566009(364801/83/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566010(364801/83/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566011(364801/83/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566012(364801/83/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566013(364801/83/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566014(364801/83/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566015(364801/83/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566016(364801/83/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566017(364801/83/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566018(364801/83/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566019(364801/83/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566020(364801/83/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566021(364801/83/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566022(364801/83/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566023(364801/83/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566024(364801/83/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566025(364801/83/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566026(364801/83/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566027(364801/83/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566028(364801/83/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566029(364801/83/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566030(364801/83/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566031(364801/83/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566032(364801/83/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566033(364801/83/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566034(364801/83/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566035(364801/83/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566036(364801/83/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566037(364801/83/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566038(364801/83/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566039(364801/83/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566040(364801/83/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566041(364801/83/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566042(364801/83/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566043(364801/83/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566044(364801/83/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566045(364801/83/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566046(364801/83/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566047(364801/83/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566048(364801/83/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566049(364801/83/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566050(364801/83/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566051(364801/83/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566052(364801/83/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566053(364801/83/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566054(364801/83/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566055(364801/83/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566056(364801/83/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566057(364801/83/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566058(364801/83/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566059(364801/83/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566060(364801/83/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566061(364801/84/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566062(364801/84/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566063(364801/84/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566064(364801/84/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566065(364801/84/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566066(364801/84/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566067(364801/84/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566068(364801/84/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566069(364801/84/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566070(364801/84/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566071(364801/84/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566072(364801/84/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566073(364801/84/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566074(364801/84/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566075(364801/84/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566076(364801/84/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566077(364801/84/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566078(364801/84/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566079(364801/84/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566080(364801/84/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566081(364801/84/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566082(364801/84/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566083(364801/84/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566084(364801/84/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566085(364801/84/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566086(364801/84/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566087(364801/84/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566088(364801/84/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566089(364801/84/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566090(364801/84/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566091(364801/84/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566092(364801/84/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566093(364801/84/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566094(364801/84/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566095(364801/84/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566096(364801/84/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566097(364801/84/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566098(364801/84/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566099(364801/84/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566100(364801/84/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566101(364801/84/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566102(364801/84/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566103(364801/84/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566104(364801/84/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566105(364801/84/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566106(364801/84/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566107(364801/84/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566108(364801/84/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566109(364801/84/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566110(364801/84/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566111(364801/84/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566112(364801/84/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566113(364801/84/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566114(364801/84/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566115(364801/84/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566116(364801/84/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566117(364801/84/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566118(364801/84/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566119(364801/84/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566120(364801/84/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566121(364801/84/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566122(364801/84/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566123(364801/84/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566124(364801/85/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566125(364801/85/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566126(364801/85/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566127(364801/85/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566128(364801/85/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566129(364801/85/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566130(364801/85/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566131(364801/85/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566132(364801/85/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566133(364801/85/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566134(364801/85/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566135(364801/85/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566136(364801/85/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566137(364801/85/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566138(364801/85/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566139(364801/85/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566140(364801/85/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566141(364801/85/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566142(364801/85/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566143(364801/85/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566144(364801/85/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566145(364801/85/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566146(364801/85/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566147(364801/85/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566148(364801/85/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566149(364801/85/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566150(364801/85/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566151(364801/85/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566152(364801/85/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566153(364801/85/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566154(364801/85/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566155(364801/85/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566156(364801/85/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566157(364801/85/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566158(364801/85/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566159(364801/85/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566160(364801/85/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566161(364801/85/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566162(364801/85/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566163(364801/85/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566164(364801/85/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566165(364801/85/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566166(364801/85/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566167(364801/85/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566168(364801/85/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566169(364801/85/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566170(364801/85/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566171(364801/85/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566172(364801/85/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566173(364801/85/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566174(364801/85/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566175(364801/85/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566176(364801/85/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566177(364801/85/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566178(364801/85/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566179(364801/85/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566180(364801/85/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566181(364801/85/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566182(364801/85/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566183(364801/85/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566184(364801/85/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566185(364801/85/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566186(364801/85/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566187(364801/86/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566188(364801/86/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566189(364801/86/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566190(364801/86/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566191(364801/86/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566192(364801/86/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566193(364801/86/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566194(364801/86/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566195(364801/86/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566196(364801/86/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566197(364801/86/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566198(364801/86/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566199(364801/86/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566200(364801/86/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566201(364801/86/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566202(364801/86/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566203(364801/86/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566204(364801/86/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566205(364801/86/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566206(364801/86/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566207(364801/86/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566208(364801/86/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566209(364801/86/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566210(364801/86/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566211(364801/86/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566212(364801/86/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566213(364801/86/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566214(364801/86/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566215(364801/86/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566216(364801/86/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566217(364801/86/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566218(364801/86/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566219(364801/86/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566220(364801/86/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566221(364801/86/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566222(364801/86/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566223(364801/86/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566224(364801/86/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566225(364801/86/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566226(364801/86/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566227(364801/86/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566228(364801/86/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566229(364801/86/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566230(364801/86/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566231(364801/86/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566232(364801/86/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566233(364801/86/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566234(364801/86/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566235(364801/86/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566236(364801/86/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566237(364801/86/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566238(364801/86/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566239(364801/86/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566240(364801/86/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566241(364801/86/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566242(364801/86/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566243(364801/86/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566244(364801/86/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566245(364801/86/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566246(364801/86/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566247(364801/86/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566248(364801/86/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566249(364801/86/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566250(364801/87/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566251(364801/87/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566252(364801/87/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566253(364801/87/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566254(364801/87/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566255(364801/87/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566256(364801/87/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566257(364801/87/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566258(364801/87/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566259(364801/87/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566260(364801/87/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566261(364801/87/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566262(364801/87/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566263(364801/87/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566264(364801/87/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566265(364801/87/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566266(364801/87/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566267(364801/87/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566268(364801/87/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566269(364801/87/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566270(364801/87/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566271(364801/87/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566272(364801/87/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566273(364801/87/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566274(364801/87/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566275(364801/87/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566276(364801/87/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566277(364801/87/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566278(364801/87/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566279(364801/87/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566280(364801/87/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566281(364801/87/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566282(364801/87/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566283(364801/87/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566284(364801/87/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566285(364801/87/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566286(364801/87/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566287(364801/87/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566288(364801/87/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566289(364801/87/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566290(364801/87/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566291(364801/87/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566292(364801/87/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566293(364801/87/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566294(364801/87/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566295(364801/87/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566296(364801/87/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566297(364801/87/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566298(364801/87/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566299(364801/87/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566300(364801/87/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566301(364801/87/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566302(364801/87/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566303(364801/87/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566304(364801/87/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566305(364801/87/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566306(364801/87/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566307(364801/87/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566308(364801/87/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566309(364801/87/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566310(364801/87/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566311(364801/87/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566312(364801/87/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566313(364801/88/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566314(364801/88/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566315(364801/88/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566316(364801/88/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566317(364801/88/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566318(364801/88/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566319(364801/88/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566320(364801/88/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566321(364801/88/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566322(364801/88/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566323(364801/88/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566324(364801/88/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566325(364801/88/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566326(364801/88/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566327(364801/88/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566328(364801/88/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566329(364801/88/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566330(364801/88/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566331(364801/88/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566332(364801/88/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566333(364801/88/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566334(364801/88/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566335(364801/88/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566336(364801/88/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566337(364801/88/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566338(364801/88/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566339(364801/88/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566340(364801/88/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566341(364801/88/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566342(364801/88/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566343(364801/88/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566344(364801/88/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566345(364801/88/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566346(364801/88/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566347(364801/88/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566348(364801/88/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566349(364801/88/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566350(364801/88/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566351(364801/88/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566352(364801/88/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566353(364801/88/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566354(364801/88/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566355(364801/88/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566356(364801/88/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566357(364801/88/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566358(364801/88/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566359(364801/88/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566360(364801/88/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566361(364801/88/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566362(364801/88/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566363(364801/88/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566364(364801/88/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566365(364801/88/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566366(364801/88/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566367(364801/88/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566368(364801/88/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566369(364801/88/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566370(364801/88/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566371(364801/88/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566372(364801/88/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566373(364801/88/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566374(364801/88/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566375(364801/88/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566376(364801/89/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566377(364801/89/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566378(364801/89/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566379(364801/89/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566380(364801/89/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566381(364801/89/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566382(364801/89/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566383(364801/89/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566384(364801/89/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566385(364801/89/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566386(364801/89/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566387(364801/89/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566388(364801/89/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566389(364801/89/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566390(364801/89/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566391(364801/89/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566392(364801/89/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566393(364801/89/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566394(364801/89/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566395(364801/89/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566396(364801/89/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566397(364801/89/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566398(364801/89/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566399(364801/89/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566400(364801/89/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566401(364801/89/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566402(364801/89/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566403(364801/89/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566404(364801/89/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566405(364801/89/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566406(364801/89/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566407(364801/89/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566408(364801/89/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566409(364801/89/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566410(364801/89/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566411(364801/89/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566412(364801/89/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566413(364801/89/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566414(364801/89/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566415(364801/89/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566416(364801/89/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566417(364801/89/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566418(364801/89/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566419(364801/89/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566420(364801/89/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566421(364801/89/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566422(364801/89/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566423(364801/89/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566424(364801/89/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566425(364801/89/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566426(364801/89/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566427(364801/89/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566428(364801/89/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566429(364801/89/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566430(364801/89/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566431(364801/89/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566432(364801/89/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566433(364801/89/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566434(364801/89/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566435(364801/89/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566436(364801/89/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566437(364801/89/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566438(364801/89/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566439(364801/90/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566440(364801/90/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566441(364801/90/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566442(364801/90/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566443(364801/90/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566444(364801/90/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566445(364801/90/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566446(364801/90/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566447(364801/90/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566448(364801/90/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566449(364801/90/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566450(364801/90/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566451(364801/90/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566452(364801/90/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566453(364801/90/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566454(364801/90/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566455(364801/90/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566456(364801/90/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566457(364801/90/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566458(364801/90/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566459(364801/90/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566460(364801/90/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566461(364801/90/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566462(364801/90/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566463(364801/90/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566464(364801/90/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566465(364801/90/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566466(364801/90/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566467(364801/90/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566468(364801/90/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566469(364801/90/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566470(364801/90/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566471(364801/90/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566472(364801/90/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566473(364801/90/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566474(364801/90/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566475(364801/90/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566476(364801/90/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566477(364801/90/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566478(364801/90/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566479(364801/90/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566480(364801/90/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566481(364801/90/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566482(364801/90/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566483(364801/90/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566484(364801/90/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566485(364801/90/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566486(364801/90/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566487(364801/90/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566488(364801/90/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566489(364801/90/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566490(364801/90/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566491(364801/90/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566492(364801/90/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566493(364801/90/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566494(364801/90/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566495(364801/90/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566496(364801/90/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566497(364801/90/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566498(364801/90/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566499(364801/90/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566500(364801/90/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566501(364801/90/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566502(364801/91/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566503(364801/91/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566504(364801/91/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566505(364801/91/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566506(364801/91/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566507(364801/91/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566508(364801/91/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566509(364801/91/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566510(364801/91/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566511(364801/91/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566512(364801/91/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566513(364801/91/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566514(364801/91/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566515(364801/91/14)) lseek err Invalid argument
file_
FerozXBL
#13 Post by FerozXBL »
pread(5,1,buffer,1565566516(364801/91/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566517(364801/91/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566518(364801/91/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566519(364801/91/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566520(364801/91/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566521(364801/91/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566522(364801/91/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566523(364801/91/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566524(364801/91/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566525(364801/91/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566526(364801/91/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566527(364801/91/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566528(364801/91/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566529(364801/91/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566530(364801/91/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566531(364801/91/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566532(364801/91/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566533(364801/91/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566534(364801/91/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566535(364801/91/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566536(364801/91/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566537(364801/91/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566538(364801/91/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566539(364801/91/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566540(364801/91/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566541(364801/91/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566542(364801/91/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566543(364801/91/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566544(364801/91/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566545(364801/91/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566546(364801/91/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566547(364801/91/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566548(364801/91/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566549(364801/91/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566550(364801/91/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566551(364801/91/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566552(364801/91/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566553(364801/91/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566554(364801/91/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566555(364801/91/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566556(364801/91/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566557(364801/91/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566558(364801/91/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566559(364801/91/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566560(364801/91/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566561(364801/91/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566562(364801/91/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566563(364801/91/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566564(364801/91/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566565(364801/92/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566566(364801/92/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566567(364801/92/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566568(364801/92/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566569(364801/92/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566570(364801/92/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566571(364801/92/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566572(364801/92/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566573(364801/92/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566574(364801/92/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566575(364801/92/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566576(364801/92/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566577(364801/92/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566578(364801/92/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566579(364801/92/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566580(364801/92/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566581(364801/92/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566582(364801/92/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566583(364801/92/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566584(364801/92/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566585(364801/92/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566586(364801/92/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566587(364801/92/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566588(364801/92/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566589(364801/92/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566590(364801/92/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566591(364801/92/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566592(364801/92/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566593(364801/92/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566594(364801/92/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566595(364801/92/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566596(364801/92/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566597(364801/92/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566598(364801/92/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566599(364801/92/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566600(364801/92/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566601(364801/92/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566602(364801/92/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566603(364801/92/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566604(364801/92/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566605(364801/92/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566606(364801/92/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566607(364801/92/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566608(364801/92/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566609(364801/92/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566610(364801/92/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566611(364801/92/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566612(364801/92/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566613(364801/92/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566614(364801/92/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566615(364801/92/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566616(364801/92/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566617(364801/92/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566618(364801/92/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566619(364801/92/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566620(364801/92/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566621(364801/92/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566622(364801/92/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566623(364801/92/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566624(364801/92/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566625(364801/92/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566626(364801/92/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566627(364801/92/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566628(364801/93/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566629(364801/93/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566630(364801/93/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566631(364801/93/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566632(364801/93/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566633(364801/93/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566634(364801/93/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566635(364801/93/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566636(364801/93/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566637(364801/93/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566638(364801/93/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566639(364801/93/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566640(364801/93/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566641(364801/93/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566642(364801/93/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566643(364801/93/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566644(364801/93/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566645(364801/93/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566646(364801/93/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566647(364801/93/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566648(364801/93/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566649(364801/93/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566650(364801/93/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566651(364801/93/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566652(364801/93/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566653(364801/93/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566654(364801/93/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566655(364801/93/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566656(364801/93/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566657(364801/93/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566658(364801/93/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566659(364801/93/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566660(364801/93/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566661(364801/93/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566662(364801/93/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566663(364801/93/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566664(364801/93/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566665(364801/93/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566666(364801/93/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566667(364801/93/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566668(364801/93/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566669(364801/93/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566670(364801/93/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566671(364801/93/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566672(364801/93/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566673(364801/93/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566674(364801/93/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566675(364801/93/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566676(364801/93/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566677(364801/93/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566678(364801/93/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566679(364801/93/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566680(364801/93/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566681(364801/93/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566682(364801/93/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566683(364801/93/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566684(364801/93/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566685(364801/93/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566686(364801/93/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566687(364801/93/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566688(364801/93/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566689(364801/93/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566690(364801/93/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566691(364801/94/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566692(364801/94/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566693(364801/94/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566694(364801/94/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566695(364801/94/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566696(364801/94/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566697(364801/94/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566698(364801/94/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566699(364801/94/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566700(364801/94/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566701(364801/94/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566702(364801/94/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566703(364801/94/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566704(364801/94/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566705(364801/94/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566706(364801/94/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566707(364801/94/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566708(364801/94/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566709(364801/94/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566710(364801/94/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566711(364801/94/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566712(364801/94/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566713(364801/94/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566714(364801/94/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566715(364801/94/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566716(364801/94/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566717(364801/94/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566718(364801/94/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566719(364801/94/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566720(364801/94/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566721(364801/94/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566722(364801/94/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566723(364801/94/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566724(364801/94/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566725(364801/94/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566726(364801/94/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566727(364801/94/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566728(364801/94/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566729(364801/94/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566730(364801/94/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566731(364801/94/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566732(364801/94/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566733(364801/94/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566734(364801/94/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566735(364801/94/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566736(364801/94/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566737(364801/94/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566738(364801/94/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566739(364801/94/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566740(364801/94/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566741(364801/94/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566742(364801/94/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566743(364801/94/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566744(364801/94/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566745(364801/94/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566746(364801/94/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566747(364801/94/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566748(364801/94/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566749(364801/94/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566750(364801/94/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566751(364801/94/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566752(364801/94/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566753(364801/94/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566754(364801/95/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566755(364801/95/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566756(364801/95/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566757(364801/95/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566758(364801/95/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566759(364801/95/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566760(364801/95/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566761(364801/95/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566762(364801/95/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566763(364801/95/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566764(364801/95/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566765(364801/95/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566766(364801/95/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566767(364801/95/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566768(364801/95/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566769(364801/95/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566770(364801/95/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566771(364801/95/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566772(364801/95/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566773(364801/95/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566774(364801/95/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566775(364801/95/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566776(364801/95/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566777(364801/95/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566778(364801/95/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566779(364801/95/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566780(364801/95/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566781(364801/95/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566782(364801/95/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566783(364801/95/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566784(364801/95/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566785(364801/95/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566786(364801/95/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566787(364801/95/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566788(364801/95/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566789(364801/95/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566790(364801/95/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566791(364801/95/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566792(364801/95/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566793(364801/95/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566794(364801/95/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566795(364801/95/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566796(364801/95/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566797(364801/95/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566798(364801/95/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566799(364801/95/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566800(364801/95/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566801(364801/95/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566802(364801/95/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566803(364801/95/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566804(364801/95/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566805(364801/95/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566806(364801/95/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566807(364801/95/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566808(364801/95/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566809(364801/95/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566810(364801/95/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566811(364801/95/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566812(364801/95/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566813(364801/95/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566814(364801/95/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566815(364801/95/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566816(364801/95/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566817(364801/96/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566818(364801/96/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566819(364801/96/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566820(364801/96/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566821(364801/96/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566822(364801/96/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566823(364801/96/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566824(364801/96/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566825(364801/96/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566826(364801/96/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566827(364801/96/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566828(364801/96/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566829(364801/96/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566830(364801/96/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566831(364801/96/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566832(364801/96/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566833(364801/96/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566834(364801/96/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566835(364801/96/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566836(364801/96/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566837(364801/96/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566838(364801/96/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566839(364801/96/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566840(364801/96/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566841(364801/96/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566842(364801/96/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566843(364801/96/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566844(364801/96/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566845(364801/96/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566846(364801/96/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566847(364801/96/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566848(364801/96/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566849(364801/96/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566850(364801/96/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566851(364801/96/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566852(364801/96/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566853(364801/96/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566854(364801/96/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566855(364801/96/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566856(364801/96/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566857(364801/96/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566858(364801/96/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566859(364801/96/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566860(364801/96/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566861(364801/96/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566862(364801/96/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566863(364801/96/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566864(364801/96/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566865(364801/96/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566866(364801/96/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566867(364801/96/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566868(364801/96/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566869(364801/96/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566870(364801/96/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566871(364801/96/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566872(364801/96/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566873(364801/96/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566874(364801/96/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566875(364801/96/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566876(364801/96/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566877(364801/96/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566878(364801/96/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566879(364801/96/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566880(364801/97/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566881(364801/97/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566882(364801/97/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566883(364801/97/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566884(364801/97/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566885(364801/97/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566886(364801/97/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566887(364801/97/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566888(364801/97/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566889(364801/97/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566890(364801/97/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566891(364801/97/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566892(364801/97/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566893(364801/97/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566894(364801/97/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566895(364801/97/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566896(364801/97/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566897(364801/97/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566898(364801/97/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566899(364801/97/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566900(364801/97/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566901(364801/97/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566902(364801/97/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566903(364801/97/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566904(364801/97/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566905(364801/97/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566906(364801/97/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566907(364801/97/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566908(364801/97/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566909(364801/97/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566910(364801/97/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566911(364801/97/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566912(364801/97/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566913(364801/97/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566914(364801/97/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566915(364801/97/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566916(364801/97/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566917(364801/97/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566918(364801/97/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566919(364801/97/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566920(364801/97/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566921(364801/97/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566922(364801/97/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566923(364801/97/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566924(364801/97/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566925(364801/97/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566926(364801/97/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566927(364801/97/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566928(364801/97/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566929(364801/97/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566930(364801/97/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566931(364801/97/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566932(364801/97/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566933(364801/97/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566934(364801/97/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566935(364801/97/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566936(364801/97/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566937(364801/97/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566938(364801/97/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566939(364801/97/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566940(364801/97/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566941(364801/97/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566942(364801/97/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566943(364801/98/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566944(364801/98/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566945(364801/98/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566946(364801/98/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566947(364801/98/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566948(364801/98/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566949(364801/98/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566950(364801/98/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566951(364801/98/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566952(364801/98/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566953(364801/98/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566954(364801/98/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566955(364801/98/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566956(364801/98/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566957(364801/98/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566958(364801/98/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566959(364801/98/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566960(364801/98/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566961(364801/98/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566962(364801/98/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566963(364801/98/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566964(364801/98/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566965(364801/98/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566966(364801/98/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566967(364801/98/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566968(364801/98/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566969(364801/98/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566970(364801/98/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566971(364801/98/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566972(364801/98/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566973(364801/98/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566974(364801/98/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566977(364801/98/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566978(364801/98/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566979(364801/98/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566980(364801/98/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566981(364801/98/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566982(364801/98/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566983(364801/98/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566984(364801/98/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566985(364801/98/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566986(364801/98/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566987(364801/98/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566988(364801/98/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566989(364801/98/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566990(364801/98/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566991(364801/98/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566992(364801/98/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566993(364801/98/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566994(364801/98/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566995(364801/98/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566996(364801/98/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566997(364801/98/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566998(364801/98/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566999(364801/98/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567000(364801/98/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567001(364801/98/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567002(364801/98/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567003(364801/98/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567004(364801/98/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567005(364801/98/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567006(364801/99/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567007(364801/99/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567008(364801/99/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567009(364801/99/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567010(364801/99/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567011(364801/99/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567012(364801/99/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567013(364801/99/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567014(364801/99/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567015(364801/99/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567016(364801/99/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567017(364801/99/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567018(364801/99/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567019(364801/99/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567020(364801/99/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567021(364801/99/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567022(364801/99/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567023(364801/99/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567024(364801/99/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567025(364801/99/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567026(364801/99/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567027(364801/99/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567028(364801/99/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567029(364801/99/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567030(364801/99/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567031(364801/99/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567032(364801/99/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567033(364801/99/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567034(364801/99/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567035(364801/99/30)) lseek err Invalid a
FerozXBL
Re: No Files After Boot Sector Rebuild
#14 Post by FerozXBL »
rgument
file_pread(5,1,buffer,1565567036(364801/99/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567037(364801/99/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567039(364801/99/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567040(364801/99/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567041(364801/99/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567042(364801/99/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567043(364801/99/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567044(364801/99/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567045(364801/99/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567046(364801/99/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567047(364801/99/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567048(364801/99/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567049(364801/99/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567050(364801/99/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567051(364801/99/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567052(364801/99/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567053(364801/99/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567054(364801/99/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567055(364801/99/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567056(364801/99/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567057(364801/99/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567058(364801/99/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567059(364801/99/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567060(364801/99/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567061(364801/99/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567062(364801/99/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567063(364801/99/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567064(364801/99/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567065(364801/99/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567066(364801/99/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567067(364801/99/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567068(364801/99/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567069(364801/100/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567070(364801/100/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567071(364801/100/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567072(364801/100/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567073(364801/100/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567074(364801/100/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567075(364801/100/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567076(364801/100/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567077(364801/100/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567078(364801/100/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567079(364801/100/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567080(364801/100/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567081(364801/100/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567082(364801/100/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567083(364801/100/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567084(364801/100/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567085(364801/100/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567086(364801/100/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567087(364801/100/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567088(364801/100/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567089(364801/100/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567090(364801/100/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567091(364801/100/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567092(364801/100/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567093(364801/100/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567094(364801/100/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567095(364801/100/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567096(364801/100/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567097(364801/100/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567098(364801/100/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567099(364801/100/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567100(364801/100/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567102(364801/100/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567103(364801/100/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567104(364801/100/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567105(364801/100/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567106(364801/100/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567107(364801/100/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567108(364801/100/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567109(364801/100/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567110(364801/100/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567111(364801/100/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567112(364801/100/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567113(364801/100/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567114(364801/100/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567115(364801/100/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567116(364801/100/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567117(364801/100/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567118(364801/100/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567119(364801/100/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567120(364801/100/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567121(364801/100/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567122(364801/100/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567123(364801/100/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567124(364801/100/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567125(364801/100/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567126(364801/100/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567127(364801/100/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567128(364801/100/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567129(364801/100/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567130(364801/100/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567131(364801/100/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567132(364801/101/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567133(364801/101/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567134(364801/101/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567135(364801/101/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567136(364801/101/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567137(364801/101/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567138(364801/101/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567139(364801/101/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567140(364801/101/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567141(364801/101/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567142(364801/101/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567143(364801/101/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567144(364801/101/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567145(364801/101/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567146(364801/101/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567147(364801/101/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567148(364801/101/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567149(364801/101/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567150(364801/101/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567151(364801/101/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567152(364801/101/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567153(364801/101/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567154(364801/101/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567155(364801/101/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567156(364801/101/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567157(364801/101/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567158(364801/101/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567159(364801/101/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567160(364801/101/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567161(364801/101/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567162(364801/101/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567163(364801/101/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567164(364801/101/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567165(364801/101/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567166(364801/101/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567167(364801/101/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567168(364801/101/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567169(364801/101/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567170(364801/101/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567171(364801/101/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567172(364801/101/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567173(364801/101/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567174(364801/101/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567175(364801/101/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567176(364801/101/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567177(364801/101/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567178(364801/101/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567179(364801/101/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567180(364801/101/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567181(364801/101/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567182(364801/101/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567183(364801/101/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567184(364801/101/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567185(364801/101/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567186(364801/101/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567187(364801/101/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567188(364801/101/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567189(364801/101/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567190(364801/101/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567191(364801/101/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567192(364801/101/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567193(364801/101/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567194(364801/101/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567195(364801/102/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567196(364801/102/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567197(364801/102/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567198(364801/102/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567199(364801/102/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567200(364801/102/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567201(364801/102/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567202(364801/102/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567203(364801/102/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567204(364801/102/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567205(364801/102/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567206(364801/102/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567207(364801/102/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567208(364801/102/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567209(364801/102/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567210(364801/102/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567211(364801/102/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567212(364801/102/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567213(364801/102/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567214(364801/102/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567215(364801/102/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567216(364801/102/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567217(364801/102/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567218(364801/102/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567219(364801/102/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567220(364801/102/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567221(364801/102/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567222(364801/102/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567223(364801/102/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567224(364801/102/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567225(364801/102/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567226(364801/102/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567227(364801/102/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567228(364801/102/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567229(364801/102/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567230(364801/102/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567231(364801/102/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567232(364801/102/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567233(364801/102/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567234(364801/102/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567235(364801/102/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567236(364801/102/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567237(364801/102/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567238(364801/102/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567239(364801/102/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567240(364801/102/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567241(364801/102/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567242(364801/102/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567243(364801/102/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567244(364801/102/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567245(364801/102/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567246(364801/102/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567247(364801/102/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567248(364801/102/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567249(364801/102/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567250(364801/102/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567251(364801/102/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567252(364801/102/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567253(364801/102/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567254(364801/102/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567255(364801/102/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567256(364801/102/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567257(364801/102/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567258(364801/103/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567259(364801/103/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567260(364801/103/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567261(364801/103/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567262(364801/103/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567263(364801/103/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567264(364801/103/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567265(364801/103/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567266(364801/103/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567267(364801/103/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567268(364801/103/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567269(364801/103/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567270(364801/103/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567271(364801/103/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567272(364801/103/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567273(364801/103/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567274(364801/103/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567275(364801/103/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567276(364801/103/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567277(364801/103/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567278(364801/103/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567279(364801/103/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567280(364801/103/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567281(364801/103/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567282(364801/103/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567283(364801/103/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567284(364801/103/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567285(364801/103/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567286(364801/103/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567287(364801/103/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567288(364801/103/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567289(364801/103/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567290(364801/103/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567291(364801/103/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567292(364801/103/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567293(364801/103/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567294(364801/103/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567295(364801/103/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567296(364801/103/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567297(364801/103/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567298(364801/103/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567299(364801/103/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567300(364801/103/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567301(364801/103/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567302(364801/103/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567303(364801/103/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567304(364801/103/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567305(364801/103/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567306(364801/103/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567307(364801/103/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567308(364801/103/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567309(364801/103/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567310(364801/103/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567311(364801/103/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567312(364801/103/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567313(364801/103/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567314(364801/103/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567315(364801/103/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567316(364801/103/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567317(364801/103/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567318(364801/103/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567319(364801/103/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567320(364801/103/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567321(364801/104/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567322(364801/104/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567323(364801/104/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567324(364801/104/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567325(364801/104/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567326(364801/104/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567327(364801/104/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567328(364801/104/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567329(364801/104/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567330(364801/104/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567331(364801/104/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567332(364801/104/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567333(364801/104/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567334(364801/104/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567335(364801/104/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567336(364801/104/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567337(364801/104/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567338(364801/104/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567339(364801/104/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567340(364801/104/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567341(364801/104/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567342(364801/104/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567343(364801/104/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567344(364801/104/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567345(364801/104/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567346(364801/104/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567347(364801/104/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567348(364801/104/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567349(364801/104/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567350(364801/104/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567351(364801/104/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567352(364801/104/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567353(364801/104/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567354(364801/104/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567355(364801/104/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567356(364801/104/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567357(364801/104/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567358(364801/104/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567359(364801/104/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567360(364801/104/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567361(364801/104/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567362(364801/104/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567363(364801/104/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567364(364801/104/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567365(364801/104/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567366(364801/104/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567367(364801/104/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567368(364801/104/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567369(364801/104/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567370(364801/104/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567371(364801/104/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567372(364801/104/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567373(364801/104/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567374(364801/104/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567375(364801/104/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567376(364801/104/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567377(364801/104/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567378(364801/104/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567379(364801/104/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567380(364801/104/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567381(364801/104/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567382(364801/104/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567383(364801/104/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567384(364801/105/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567385(364801/105/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567386(364801/105/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567387(364801/105/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567388(364801/105/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567389(364801/105/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567390(364801/105/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567391(364801/105/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567392(364801/105/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567393(364801/105/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567394(364801/105/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567395(364801/105/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567396(364801/105/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567397(364801/105/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567398(364801/105/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567399(364801/105/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567400(364801/105/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567401(364801/105/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567402(364801/105/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567403(364801/105/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567404(364801/105/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567405(364801/105/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567406(364801/105/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567407(364801/105/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567408(364801/105/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567409(364801/105/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567410(364801/105/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567411(364801/105/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567412(364801/105/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567413(364801/105/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567414(364801/105/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567415(364801/105/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567416(364801/105/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567417(364801/105/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567418(364801/105/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567419(364801/105/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567420(364801/105/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567421(364801/105/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567422(364801/105/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567423(364801/105/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567424(364801/105/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567425(364801/105/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567426(364801/105/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567427(364801/105/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567428(364801/105/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567429(364801/105/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567430(364801/105/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567431(364801/105/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567432(364801/105/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567433(364801/105/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567434(364801/105/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567435(364801/105/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567436(364801/105/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567437(364801/105/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567438(364801/105/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567439(364801/105/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567440(364801/105/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567441(364801/105/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567442(364801/105/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567443(364801/105/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567444(364801/105/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567445(364801/105/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567446(364801/105/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567447(364801/106/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567448(364801/106/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567449(364801/106/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567450(364801/106/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567451(364801/106/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567452(364801/106/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567453(364801/106/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567454(364801/106/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567455(364801/106/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567456(364801/106/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567457(364801/106/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567458(364801/106/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567459(364801/106/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567460(364801/106/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567461(364801/106/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567462(364801/106/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567463(364801/106/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567464(364801/106/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567465(364801/106/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567466(364801/106/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567467(364801/106/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567468(364801/106/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567469(364801/106/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567470(364801/106/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567471(364801/106/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567472(364801/106/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567473(364801/106/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567474(364801/106/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567475(364801/106/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567476(364801/106/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567477(364801/106/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567478(364801/106/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567479(364801/106/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567480(364801/106/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567481(364801/106/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567482(364801/106/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567483(364801/106/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567484(364801/106/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567485(364801/106/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567486(364801/106/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567487(364801/106/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567488(364801/106/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567489(364801/106/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567490(364801/106/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567491(364801/106/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567492(364801/106/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567493(364801/106/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567494(364801/106/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567495(364801/106/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567496(364801/106/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567497(364801/106/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567498(364801/106/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567499(364801/106/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567500(364801/106/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567501(364801/106/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567502(364801/106/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567503(364801/106/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567504(364801/106/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567505(364801/106/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567506(364801/106/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567507(364801/106/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567508(364801/106/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567509(364801/106/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567510(364801/107/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567511(364801/107/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567512(364801/107/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567513(364801/107/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567514(364801/107/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567515(364801/107/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567516(364801/107/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567517(364801/107/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567518(364801/107/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567519(364801/107/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567520(364801/107/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567521(364801/107/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567522(364801/107/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567523(364801/107/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567524(364801/107/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567525(364801/107/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567526(364801/107/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567527(364801/107/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567528(364801/107/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567529(364801/107/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567530(364801/107/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567531(364801/107/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567532(364801/107/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567533(364801/107/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567534(364801/107/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567535(364801/107/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567536(364801/107/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567537(364801/107/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567538(364801/107/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567539(364801/107/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567540(364801/107/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567541(364801/107/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567542(364801/107/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567543(364801/107/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567544(364801/107/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567545(364801/107/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567546(364801/107/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567547(364801/107/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567548(364801/107/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567549(364801/107/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567550(364801/107/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567551(364801/107/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567552(364801/107/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567553(364801/107/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567554(364801/107/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567555(364801/107/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567556(364801/107/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567557(364801/107/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567$MFT has invalid magic.
ntfs_mft_load(): Failed.
558(364801/107/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567559(364801/107/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567560(364801/107/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567561(364801/107/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567562(364801/107/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567563(364801/107/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567564(364801/107/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567565(364801/107/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567566(364801/107/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567567(364801/107/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567568(364801/107/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567569(364801/107/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567570(364801/107/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567571(364801/107/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567572(364801/107/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567573(364801/108/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567574(364801/108/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567575(364801/108/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567576(364801/108/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567577(364801/108/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567578(364801/108/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567579(364801/108/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567580(364801/108/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567581(364801/108/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567582(364801/108/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567583(364801/108/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567584(364801/108/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567585(364801/108/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567586(364801/108/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567587(364801/108/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567588(364801/108/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567589(364801/108/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567590(364801/108/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567591(364801/108/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567592(364801/108/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567593(364801/108/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567594(364801/108/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567595(364801/108/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567596(364801/108/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567597(364801/108/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567598(364801/108/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567599(364801/108/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567600(364801/108/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567601(364801/108/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567602(364801/108/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567603(364801/108/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567604(364801/108/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567605(364801/108/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567606(364801/108/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567607(364801/108/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567608(364801/108/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567609(364801/108/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567610(364801/108/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567611(364801/108/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567612(364801/108/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567613(364801/108/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567614(364801/108/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567615(364801/108/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567616(364801/108/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567617(364801/108/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567618(364801/108/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567619(364801/108/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567620(364801/108/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567621(364801/108/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567622(364801/108/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567623(364801/108/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567624(364801/108/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567625(364801/108/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567626(364801/108/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567627(364801/108/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567628(364801/108/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567629(364801/108/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567630(364801/108/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567631(364801/108/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567632(364801/108/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567633(364801/108/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567634(364801/108/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567635(364801/108/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567636(364801/109/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567637(364801/109/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567638(364801/109/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567639(364801/109/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567640(364801/109/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567641(364801/109/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567642(364801/109/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567643(364801/109/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567644(364801/109/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567645(364801/109/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567646(364801/109/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567647(364801/109/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567648(364801/109/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567649(364801/109/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567650(364801/109/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567651(364801/109/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567652(364801/109/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567653(364801/109/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567654(364801/109/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567655(364801/109/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567656(364801/109/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567657(364801/109/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567658(364801/109/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567659(364801/109/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567660(364801/109/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567661(364801/109/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567662(364801/109/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567663(364801/109/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567664(364801/109/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567665(364801/109/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567666(364801/109/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567667(364801/109/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567668(364801/109/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567669(364801/109/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567670(364801/109/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567671(364801/109/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567672(364801/109/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567673(364801/109/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567674(364801/109/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567675(364801/109/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567676(364801/109/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567677(364801/109/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567678(364801/109/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567679(364801/109/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567680(364801/109/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567681(364801/109/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567682(364801/109/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567683(364801/109/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567684(364801/109/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567685(364801/109/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567686(364801/109/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567687(364801/109/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567688(364801/109/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567689(364801/109/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567690(364801/109/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567691(364801/109/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567692(364801/109/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567693(364801/109/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567694(364801/109/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567695(364801/109/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567696(364801/109/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567697(364801/109/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567698(364801/109/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567699(364801/110/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567700(364801/110/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567701(364801/110/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567702(364801/110/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567703(364801/110/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567704(364801/110/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567705(364801/110/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567706(364801/110/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567707(364801/110/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567708(364801/110/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567709(364801/110/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567710(364801/110/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567711(364801/110/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567712(364801/110/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567713(364801/110/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567714(364801/110/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567715(364801/110/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567716(364801/110/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567717(364801/110/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567718(364801/110/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567719(364801/110/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567720(364801/110/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567721(364801/110/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567722(364801/110/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567723(364801/110/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567724(364801/110/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567725(364801/110/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567726(364801/110/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567727(364801/110/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567728(364801/110/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567729(364801/110/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567730(364801/110/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567731(364801/110/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567732(364801/110/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567733(364801/110/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567734(364801/110/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567735(364801/110/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567736(364801/110/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567737(364801/110/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567738(364801/110/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567739(364801/110/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567740(364801/110/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567741(364801/110/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567742(364801/110/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567743(364801/110/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567744(364801/110/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567745(364801/110/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567746(364801/110/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567747(364801/110/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567748(364801/110/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567749(364801/110/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567750(364801/110/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567751(364801/110/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567752(364801/110/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567753(364801/110/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567754(364801/110/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567755(364801/110/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567756(364801/110/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567757(364801/110/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567758(364801/110/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567759(364801/110/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567760(364801/110/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567761(364801/110/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567762(364801/111/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567763(364801/111/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567764(364801/111/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567765(364801/111/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567766(364801/111/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567767(364801/111/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567768(364801/111/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567769(364801/111/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567770(364801/111/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567771(364801/111/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567772(364801/111/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567773(364801/111/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567774(364801/111/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567775(364801/111/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567776(364801/111/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567777(364801/111/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567778(364801/111/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567779(364801/111/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567780(364801/111/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567781(364801/111/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567782(364801/111/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567783(364801/111/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567784(364801/111/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565872(364801/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1565567785(364801/111/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567786(364801/111/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567787(364801/111/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567788(364801/111/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567789(364801/111/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567790(364801/111/29)) lseek err Invalid argument
file_pread(5,11,buffer,1565565868(364801/80/60)) ReadFile The drive cannot find the sector requested
FerozXBL
#15 Post by FerozXBL »
file_pread(5,1,buffer,1565567791(364801/111/30)) lseek err Invalid argument
file_pread(5,7,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567792(364801/111/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567793(364801/111/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567794(364801/111/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567795(364801/111/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567796(364801/111/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567797(364801/111/36)) lseek err Invalid argument
file_pread(5,11,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567798(364801/111/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565886(364801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567799(364801/111/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567800(364801/111/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565888(364801/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567801(364801/111/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565889(364801/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567802(364801/111/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567803(364801/111/42)) lseek err Invalid argument
file_pread(5,11,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567804(364801/111/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565565892(364801/81/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567805(364801/111/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565893(364801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567806(364801/111/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567807(364801/111/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565895(364801/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567808(364801/111/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565896(364801/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567809(364801/111/48)) lseek err Invalid argument
file_pread(5,11,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567810(364801/111/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565898(364801/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567811(364801/111/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565899(364801/81/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567812(364801/111/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565900(364801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567813(364801/111/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565901(364801/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567814(364801/111/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567815(364801/111/54)) lseek err Invalid argument
file_pread(5,11,buffer,1565565893(364801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567816(364801/111/55)) lseek err Invalid argument
file_pread(5,11,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567817(364801/111/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565905(364801/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567818(364801/111/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567819(364801/111/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567820(364801/111/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567821(364801/111/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567822(364801/111/61)) lseek err Invalid argument
file_pread(5,11,buffer,1565565900(364801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567823(364801/111/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567824(364801/111/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567825(364801/112/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565913(364801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567826(364801/112/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567827(364801/112/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567828(364801/112/4)) lseek err Invalid argument
file_pread(5,11,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567829(364801/112/5)) lseek err Invalid argument
file_pread(5,11,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567830(364801/112/6)) lseek err Invalid argument
file_pread(5,11,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567831(364801/112/7)) lseek err Invalid argument
file_pread(5,11,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567832(364801/112/8)) lseek err Invalid argument
file_pread(5,11,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567833(364801/112/9)) lseek err Invalid argument
file_pread(5,11,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567834(364801/112/10)) lseek err Invalid argument
file_pread(5,11,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567835(364801/112/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567836(364801/112/12)) lseek err Invalid argument
file_pread(5,8,buffer,1565565867(364801/80/59)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567837(364801/112/13)) lseek err Invalid argument
file_pread(5,4,buffer,1565565872(364801/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(5,11,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567838(364801/112/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565926(364801/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567839(364801/112/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567840(364801/112/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567841(364801/112/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567842(364801/112/18)) lseek err Invalid argument
file_pread(5,8,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,11,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567843(364801/112/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567844(364801/112/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565932(364801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567845(364801/112/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567846(364801/112/22)) lseek err Invalid argument
file_pread(5,8,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,11,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567847(364801/112/23)) lseek err Invalid argument
file_pread(5,8,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565935(364801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567848(364801/112/24)) lseek err Invalid argument
file_pread(5,8,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565936(364801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567849(364801/112/25)) lseek err Invalid argument
file_pread(5,8,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,11,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567850(364801/112/26)) lseek err Invalid argument
file_pread(5,8,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565938(364801/82/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567851(364801/112/27)) lseek err Invalid argument
file_pread(5,8,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567852(364801/112/28)) lseek err Invalid argument
file_pread(5,8,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,11,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567853(364801/112/29)) lseek err Invalid argument
file_pread(5,8,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567854(364801/112/30)) lseek err Invalid argument
file_pread(5,8,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565942(364801/82/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567855(364801/112/31)) lseek err Invalid argument
file_pread(5,8,buffer,1565565886(364801/81/15)) lseek err Invalid argument
file_pread(5,11,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567856(364801/112/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565944(364801/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567857(364801/112/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567858(364801/112/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565946(364801/82/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567859(364801/112/35)) lseek err Invalid argument
file_pread(5,8,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(5,11,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567860(364801/112/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565565948(364801/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567861(364801/112/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567862(364801/112/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567863(364801/112/39)) lseek err Invalid argument
file_pread(5,8,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,11,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567864(364801/112/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567865(364801/112/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565903(364801/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567866(364801/112/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565904(364801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565954(364801/82/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567867(364801/112/43)) lseek err Invalid argument
file_pread(5,8,buffer,1565565898(364801/81/27)) lseek err Invalid argument
file_pread(5,11,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567868(364801/112/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565956(364801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567869(364801/112/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565957(364801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567870(364801/112/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565958(364801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567871(364801/112/47)) lseek err Invalid argument
file_pread(5,8,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(5,11,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567872(364801/112/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565960(364801/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567873(364801/112/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565961(364801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567874(364801/112/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565891(364801/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565962(364801/82/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567875(364801/112/51)) lseek err Invalid argument
file_pread(5,8,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,11,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567876(364801/112/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565964(364801/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567877(364801/112/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565965(364801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567878(364801/112/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565916(364801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565966(364801/82/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567879(364801/112/55)) lseek err Invalid argument
file_pread(5,8,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,11,buffer,1565565957(364801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567880(364801/112/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565897(364801/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565968(364801/82/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567881(364801/112/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565919(364801/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565969(364801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567882(364801/112/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565970(364801/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567883(364801/112/59)) lseek err Invalid argument
file_pread(5,8,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(5,11,buffer,1565565961(364801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567884(364801/112/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567885(364801/112/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565973(364801/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567886(364801/112/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565974(364801/82/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567887(364801/112/63)) lseek err Invalid argument
file_pread(5,8,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(5,11,buffer,1565565965(364801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567888(364801/113/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565976(364801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567889(364801/113/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565977(364801/82/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567890(364801/113/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567891(364801/113/4)) lseek err Invalid argument
file_pread(5,8,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,11,buffer,1565565969(364801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567892(364801/113/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565980(364801/82/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567893(364801/113/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567894(364801/113/7)) lseek err Invalid argument
file_pread(5,8,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,11,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567895(364801/113/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565983(364801/82/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567896(364801/113/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567897(364801/113/10)) lseek err Invalid argument
file_pread(5,8,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,11,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567898(364801/113/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567899(364801/113/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567900(364801/113/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565917(364801/81/46)) lseek err Invalid argument
file_pread(5,8,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,11,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567901(364801/113/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565989(364801/82/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567902(364801/113/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567903(364801/113/16)) lseek err Invalid argument
file_pread(5,8,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,11,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567904(364801/113/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567905(364801/113/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565993(364801/82/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567906(364801/113/19)) lseek err Invalid argument
file_pread(5,14,buffer,1565565860(364801/80/52)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,3,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,8,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,11,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,2,buffer,1565567906(364801/113/19)) lseek err Invalid argument
file_pread(5,14,buffer,1565565861(364801/80/53)) ReadFile The drive cannot find the sector requested.
file_pread(5,2,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,3,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,8,buffer,1565565938(364801/82/4)) lseek err Invalid argument
file_pread(5,11,buffer,1565565985(364801/82/51)) lseek err Invalid argument
file_pread(5,2,buffer,1565567907(364801/113/20)) lseek err Invalid argument
file_pread(5,14,buffer,1565565862(364801/80/54)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(5,3,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(5,8,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,11,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,2,buffer,1565567908(364801/113/21)) lseek err Invalid argument
file_pread(5,14,buffer,1565565863(364801/80/55)) ReadFile The drive cannot find the sector requested.
file_pread(5,4,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,3,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,8,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,11,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,2,buffer,1565567909(364801/113/22)) lseek err Invalid argument
file_pread(5,14,buffer,1565565864(364801/80/56)) ReadFile The drive cannot find the sector requested.
file_pread(5,5,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,3,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,8,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,11,buffer,1565565988(364801/82/54)) lseek err Invalid argument
file_pread(5,2,buffer,1565567910(364801/113/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565999(364801/83/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567912(364801/113/25)) lseek err Invalid argument
file_pread(5,14,buffer,1565565866(364801/80/58)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,3,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,8,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,11,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567913(364801/113/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565951(364801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566001(364801/83/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567914(364801/113/27)) lseek err Invalid argument
file_pread(5,14,buffer,1565565868(364801/80/60)) ReadFile The drive cannot find the sector requested.
file_pread(5,8,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,3,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,3,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,8,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,11,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567915(364801/113/28)) lseek err Invalid argument
file_pread(5,10,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566003(364801/83/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567916(364801/113/29)) lseek err Invalid argument
file_pread(5,14,buffer,1565565870(364801/80/62)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,3,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,8,buffer,1565565947(364801/82/13)) lseek err Invalid argument
file_pread(5,11,buffer,1565565994(364801/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567917(364801/113/30)) lseek err Invalid argument
file_pread(5,12,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565955(364801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566005(364801/83/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567918(364801/113/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566006(364801/83/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567919(364801/113/32)) lseek err Invalid argument
file_pread(5,2,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,8,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(5,11,buffer,1565565997(364801/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567920(364801/113/33)) lseek err Invalid argument
file_pread(5,14,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566008(364801/83/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567921(364801/113/34)) lseek err Invalid argument
The harddisk (3000 GB / 2794 GiB) seems too small! (< 6001 GB / 5589 GiB)
MS Data 4294983678 8589950972 4294967295
NTFS, blocksize=4096, 2199 GB / 2047 GiB
MS Data 5860524024 11721031671 5860507648
MS Data 16377 5860524024 5860507648
NTFS found using backup sector, blocksize=4096, 3000 GB / 2794 GiB
MS Data 16384 4294983678 4294967295 [Seagate Expansion Drive]
Mac HFS 1247590699 1289544012 41953314
HFS found using backup sector!, 21 GB / 20 GiB
Mac HFS 1289544009 1331497322 41953314
HFS blocksize=524288, 21 GB / 20 GiB
Mac HFS 1918990372 1923217701 4227330
HFS found using backup sector!, 2164 MB / 2064 MiB
Mac HFS 1923217698 1927445027 4227330
HFS blocksize=65536, 2164 MB / 2064 MiB
MS Data 2572234721 2575797716 3562996 [˜:›íé”ìk@.¡°Ý´]
cramfs, 1824 MB / 1739 MiB
MS Data 2572234722 2575797717 3562996 [˜:›íé”ìk@.¡°Ý´]
MS Data 3243233060 3249933476 6700417 [%åÊh V½£â=¹¿Ë]
cramfs, 3430 MB / 3271 MiB
MS Data 3243233061 3249933477 6700417 [%åÊh V½£â=¹¿Ë]
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 16-Jun-2015 20:27 .
5 dr-xr-xr-x 0 0 0 16-Jun-2015 20:27 ..
83 dr-xr-xr-x 0 0 0 16-Apr-2013 01:39 $RECYCLE.BIN
121 dr-xr-xr-x 0 0 0 22-May-2013 01:15 Movies
1718 dr-xr-xr-x 0 0 0 1-May-2013 09:48 Series
46 dr-xr-xr-x 0 0 0 13-Apr-2013 17:56 Setup Files
12560 dr-xr-xr-x 0 0 0 15-Apr-2013 21:23 System Volume Information
17 dr-xr-xr-x 0 0 0 1-May-2013 01:31 found.000
20 dr-xr-xr-x 0 0 0 25-May-2013 20:00 found.001
1341 -r--r--r-- 0 0 21 1-Jan-1970 04:41 .cm0012
1342 -r--r--r-- 0 0 784384 1-Jan-1970 16:48 .cmdb
23 -r--r--r-- 0 0 0 16-Jun-2015 20:27 Login.txt
Support for this filesystem hasn't been implemented.
gpt_change_part_type
Change partition type:
Solaris Reserved5 3243233061 3249933477 6700417 [%åÊh V½£â=¹¿Ë]
NTFS 3243233061 3249933477 6700417 [%åÊh V½£â=¹¿Ë]
Solaris Reserved5 16377 5860524024 5860507648
NTFS 16377 5860524024 5860507648
NTFS 1247590699 1289544012 41953314
NTFS 1289544009 1331497322 41953314
NTFS 1918990372 1923217701 4227330
NTFS 1923217698 1927445027 4227330
MS Reserved 2572234721 2575797716 3562996 [˜:›íé”ìk@.¡°Ý´]
NTFS 2572234721 2575797716 3562996 [˜:›íé”ìk@.¡°Ý´]
NTFS 2572234722 2575797717 3562996 [˜:›íé”ìk@.¡°Ý´]
NTFS 3243233060 3249933476 6700417 [%åÊh V½£â=¹¿Ë]
Trying alternate GPT
Re: No Files After Boot Sector Rebuild
#16 Post by Fiona »
Looks like that chkdsk was running too?
Can you copy/backup important files first?
Does your found000 folders contain *.chk-files?
In case, you can copy your found000-folders to another healthy disk or partition and try to recover files.
Info:
https://www.raymond.cc/blog/how-to-reco ... -scandisk/
The sector size of your disk is still not recognized correctly.
Can you run msinfo32 and check it?
Should be something like Data storage device?
Did you try to install Intel RST as recommeded in my post above, to get 4k sector support?
