I tried the receipe in the following tutorial to undelete a file. The title seems to indicate it's to undelete a file in a FAT partition.
http://www.cgsecurity.org/wiki/TestDisk ... le_for_FAT
As I want to be sure I know how it works, before trying to recover my file, I tried to undelete files with a FAT USB Key and tried again with another FAT32 USB key. I get the same results everytime. it's not working.
Everything is OK till after I pick "advanced". Then it shows 4 lines :
4 * Sys=0D
2 * Netware 3.11+
1 * Sys=72
3 * Sys=79
No FAT partition appears. It's like testdisk is first looking for a deleted partition or bootable partition. Then I tried Analyse but again no partition can be found. In the information I got with analyse, I understood it's is looking for a Bootable partition.
I start testdisk.exe without anything else. Is my problem there ?
I must say that I tried to undelete the file with PhotoRec but it didn't work for my file. Could it be too large (around 500mb) ?
Thanks in advance J Guy
Undelete file in a working FAT partition
Re: Undelete file in a working FAT partition
Choose None for the partition table type.
