Rebuilt BS
delyaqui
Rebuilt BS
#1 Post by delyaqui »
Hi
After running REBUILD BS i get this error :
Can't find cluster size
boot and backup : BAD
what mean this error ??
what could do to recovery the information on disk ???
Best Regards
Re: Rebuilt BS
Do you have the right partition in your partition table?
It's abolutely required to run a boot sector diagnose.
Otherwise testdisk can't find any information regarding to your file system.
Can you copy and paste the content og your testdisk.log into your next post.
Also information running testdisk Analyse would be appreciated.
delyaqui
Re: Rebuilt BS
#3 Post by delyaqui »
Hi Fiona
Thanks for your attention
here i send you de log file
yes, i run the DIAGNOSE first
thanks
delyaqui
Re: Rebuilt BS
#4 Post by delyaqui »
Hi Fiona
thanks
testdisk.rar
(1.16 KiB) Downloaded 1055 times
delyaqui
Re: Rebuilt BS
#5 Post by delyaqui »
this is the disk :
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - TOSHIBA MQ01ABD100
Re: Rebuilt BS
#6 Post by Fiona »
Your boot sector and its backup are not valid or not available.
The start of your partition is unusual and should be something like 0 32 33 etc.. and is 0 0 33.
That's why it's possible that testdisk doesn't find the clustersize etc..
Can you run Quick and if nothing would be found Deeper Search also?
If a partition would be found, please have select ist and have another try to list your files.
Within your testdisk folder, ypu'll find a file testdisk.log.
Can you open it using a wordprocessor like wordpad and copy and paste the content of your log file inrto your next post?
