Resized Lion Created HFS+ Partition in Snow Leopard
wondering1
#1 Post by wondering1 »
2TB external USB drive had been formatted GUID in Lion with a bootable Lion partition of 100GB and the rest of the 2TB was a Time Machine backup (containing many symbolic links making data recovery methods questionable at best).
In Lion, the bootable partition was reduced in size. The remaining space was turned into "free space". At this point, the Time Machine backup partition was resized to take advantage of the extra free space.
I suspect that the "free space" may have been created in Snow Leopard mistakenly instead of in Lion. Regardless of which OS was employed to create the free space, the Time Machine backup partition was damaged and simply named disk1s4.
What steps might I take from the below log to fix the partition?
"Untitled 1" below is Bootable and still mounts/boots successfully.
"Recovery HD" below is the Lion Recovery partition and still mounts/boots successfully.
"Untitled 2" below is the missing partition formerly known as the Time Machine backup.
Untitled 2 was HFS+ Journaled when it was not damaged.
Thu May 17 13:17:28 2012
OS: Darwin, kernel 11.4.0 (Darwin Kernel Version 11.4.0: Mon Apr 9 19:32:15 PDT 2012; root:xnu-1699.2
Compiler: GCC 4.0
Compilation date: 2012-05-08T10:52:24
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
User is not root!
Disk /dev/disk1 - 2000 GB / 1863 GiB - CHS 3907024896 1 1 (RO), sector size=512
Disk /dev/disk2 - 1499 GB / 1396 GiB - CHS 2928904192 1 1 (RO), sector size=512
Disk /dev/rdisk1 - 2000 GB / 1863 GiB - CHS 3907024896 1 1 (RO), sector size=512
Disk /dev/rdisk2 - 1499 GB / 1396 GiB - CHS 2928904192 1 1 (RO), sector size=512
Media is opened in read-only.
Disk /dev/rdisk1 - 2000 GB / 1863 GiB (RO)
Partition table type: EFI GPT
Analyse Disk /dev/rdisk1 - 2000 GB / 1863 GiB - CHS 3907024896 1 1 (RO)
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907024895 (expected 3907024895)
hdr_lba_start=34
hdr_lba_end=3907024862
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
4 P Mac HFS 65773976 3906762711 3840988736 [Untitled 2]
1 P EFI System 40 409639 409600 [EFI System Partition]
2 P Mac HFS 409640 64504431 64094792 [Untitled 1]
3 P Mac Boot 64504432 65773975 1269544 [Recovery HD]
No HFS or HFS+ structure
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 64094792
HFS+ blocksize=4096, 32 GB / 30 GiB
HFS+ magic value at 64504432/0/1
part_size 1269544
Mac HFS 64504432 65773975 1269544
HFS+ blocksize=4096, 650 MB / 619 MiB
Thank you very much!
